Go Back   Honda Civic Forum > GENERAL > General Honda Civic Forum Archive.
Register Forgot Password?
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools Search this Thread
Old 04-20-2008   #1 (permalink)
FALKEN's Avatar
Images: 136
FALKEN is a glorious beacon of light FALKEN is a glorious beacon of light FALKEN is a glorious beacon of light FALKEN is a glorious beacon of light FALKEN is a glorious beacon of light FALKEN is a glorious beacon of light
reconditioned my headlights this morning...
STEP: 1
tape off around the headlight so you dont sand your precious paint job
STEP: 2
wetsand the headlight
(use 800 grit if the lens is really bad)
(use 1000 grit if lens has normal issues)
STEP: 3
wipe headlight dry
STEP: 4
(use 1000 grit if your first sanding was 800 grit, then move on to 2000 grit)
(use 2000 grit if your first sanding was 1000 grit)
STEP: 5
wipe headlight dry
STEP: 6
buff headlight using plastic polish/cleaner
(i used a drill attachment to speed the process)
FINAL RESULTS:
__________________
FALKEN is offline
Old 04-20-2008   #2 (permalink)
7thGenerasianCivic's Avatar
Points: 20,636, Level: 90
Points: 20,636, Level: 90 Points: 20,636, Level: 90 Points: 20,636, Level: 90
Level up: 58%, 214 Points needed
Level up: 58% Level up: 58% Level up: 58%
Activity: 1.1%
Activity: 1.1% Activity: 1.1% Activity: 1.1%
Images: 28
7thGenerasianCivic is just really nice 7thGenerasianCivic is just really nice 7thGenerasianCivic is just really nice 7thGenerasianCivic is just really nice
Re: reconditioned my headlights this morning...
sweeeeeet
__________________
i ♥ my daily hooptie- staggered- coils- frame low
7thGenerasianCivic is offline
Old 04-20-2008   #3 (permalink)
slowwhitecivic's Avatar
Points: 5,611, Level: 48
Points: 5,611, Level: 48 Points: 5,611, Level: 48 Points: 5,611, Level: 48
Level up: 31%, 139 Points needed
Level up: 31% Level up: 31% Level up: 31%
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
slowwhitecivic will become famous soon enough
the headlight in the first pic didnt look like it needed to be recondition but damn urs came out real nice and smooth...last time i try mine came out shitty and u can still see some scratches lol
slowwhitecivic is offline
Old 04-20-2008   #4 (permalink)
hvc
hvc is an unknown quantity at this point
looks good man, and yeah, the headlight in the first picture doesn't even look that bad?
I think I'm going to have to do this sometime this week.
hvc is offline
Old 04-20-2008   #5 (permalink)
A long winded 7th genr
Images: 8
Eyger has a reputation beyond repute Eyger has a reputation beyond repute Eyger has a reputation beyond repute Eyger has a reputation beyond repute Eyger has a reputation beyond repute Eyger has a reputation beyond repute Eyger has a reputation beyond repute Eyger has a reputation beyond repute Eyger has a reputation beyond repute Eyger has a reputation beyond repute Eyger has a reputation beyond repute
Send a message via AIM to Eyger
Another way you can do this same thing to your headlights, I've done it before on a different car, you can sand everything like you did, then just spray a clear coat over the whole thing, it comes out crystal clear.
Slowwitecivic, you might see scratches because you didn't use a fine enough grain, or you didn't sand enough. those would be my guesses.
Eyger is offline
Old 04-20-2008   #6 (permalink)
damian02civic's Avatar
Images: 11
damian02civic has a spectacular aura about damian02civic has a spectacular aura about damian02civic has a spectacular aura about
Send a message via AIM to damian02civic
Don't sand or buff too hard or you have the chance of warping the lens which in turn would make the light come out the lens the wrong way.. or create 'grooves' in the lens.
__________________
Vegas is my playground.
damian02civic is offline
Old 04-20-2008   #7 (permalink)
hvc
should you sand more with the higher grit, rather then more with the lower grit?
hvc is offline
Old 04-20-2008   #8 (permalink)
FALKEN's Avatar
Images: 136
Quote:
Originally Posted by slowwhitecivic View Post
the headlight in the first pic didnt look like it needed to be reconditioned
true, but im very picky and after seeing some of the fine scratches starting to appear, it was time...also, the passenger side was yellowing due to the way the sun hits it when i park at work.
last time mine came out shitty and u can still see some scratches
what grit levels were you using? you may need to go lower and then work your way up to 2000 or higher.
FALKEN is offline
Old 04-20-2008   #9 (permalink)
FALKEN's Avatar
Images: 136
Quote:
The more you sand with the lower grits, the more "layers" come off. It may be necessary to sand longer with the lower grits if your lens is deeply pitted. Just make sure that you sand the whole lens evenly and work your way through the higher grits. The lens should be very smooth right before you start to polish.
FALKEN is offline
Old 04-20-2008   #10 (permalink)
Super Moderator
Points: 139,148, Level: 100
Points: 139,148, Level: 100 Points: 139,148, Level: 100 Points: 139,148, Level: 100
Level up: 0%, 0 Points needed
Level up: 0% Level up: 0% Level up: 0%
Activity: 100.0%
Activity: 100.0% Activity: 100.0% Activity: 100.0%
Images: 178
gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute
make sure you seal it to protect what you did using a clear plastic sealer.
__________________
2002 Honda Civic EX Auto
gearbox is online now
Old 04-20-2008   #11 (permalink)
hXc drummer23 will become famous soon enough
That is pretty similar to what I did, but I started with 1500 then moved to 2000. I also used Menzerna intensive polish via rotary on a megs burgundy pad, menzerna final polish via porter cable on a megs yellow pad, then plastic x via porter cable on a LC ccs white pad. It came out perfect. The only reason I went that in depth is because I detail cars as my job.
hXc drummer23 is offline
Old 04-20-2008   #12 (permalink)
miami_em2's Avatar
Points: 4,384, Level: 42
Points: 4,384, Level: 42 Points: 4,384, Level: 42 Points: 4,384, Level: 42
Level up: 17%, 166 Points needed
Level up: 17% Level up: 17% Level up: 17%
Activity: 0%
miami_em2 will become famous soon enough
I just wet sanded mine and then cleared them....it looks so nice. But nice job falken.
miami_em2 is offline
Old 04-20-2008   #13 (permalink)
Activity: 0%
i think im gona have try this again lol..im gona try to move up to 2000 grits
Old 04-20-2008   #14 (permalink)
This is Myspace
DsevenEm2's Avatar
Points: 11,262, Level: 70
Points: 11,262, Level: 70 Points: 11,262, Level: 70 Points: 11,262, Level: 70
Level up: 3%, 388 Points needed
Level up: 3% Level up: 3% Level up: 3%
Activity: 0%
DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold
Send a message via AIM to DsevenEm2
Quote:
x2 or you can wait about a month and watch it go back to how it looked before.
__________________
"We are defined by the choices we make"
MMI Gradutate - 11-21-08
Yamaha 5-star~Honda Level1~Mercury/Mercruiser Level1~Suzuki EntryLevel1~Volvo/Diesel EntryLevel1 -- Certified
Next step: United StatesCoast Guard - BC 12-06-08
DsevenEm2 is online now
Old 04-20-2008   #15 (permalink)
You VTEC...I-VTEC
sniperscout's Avatar
Points: 8,602, Level: 62
Points: 8,602, Level: 62 Points: 8,602, Level: 62 Points: 8,602, Level: 62
Level up: 51%, 148 Points needed
Level up: 51% Level up: 51% Level up: 51%
Activity: 0%
sniperscout is a glorious beacon of light sniperscout is a glorious beacon of light sniperscout is a glorious beacon of light sniperscout is a glorious beacon of light sniperscout is a glorious beacon of light
where can you pick up plastic sealer
__________________
04 NHBP EM2
K24 Frankenstein Swap
212HP/178TQ
sniperscout is offline
Old 04-20-2008   #16 (permalink)
Super Moderator
Activity: 100.0%
Images: 178
wolfgang clear plastic sealer. i use it on my lights every month or so. it beads water and protects from sun. very good for $40 the big bottle is worth it. i still have mine for over two years its still not empty. hmm cargeek used to sell but i cant figure out what the site url is
__________________
Old 04-20-2008   #17 (permalink)
You VTEC...I-VTEC
Activity: 0%
thx i will do some searchin'
are you thinking of autogeek.net?
they have almost all of the wolfgangs products in bulk except for the sealant...go figure
__________________
04 NHBP EM2
212HP/178TQ
Old 04-21-2008   #18 (permalink)
Super Moderator
Activity: 100.0%
Images: 178
yeah autogeek is where i bought mine a while back.
__________________
Old 04-21-2008   #19 (permalink)
You VTEC...I-VTEC
Activity: 0%
so i did this and they did not turn out very good
what buffer/polisher thingy did you use?
I used the mothers red foam ball thing
__________________
04 NHBP EM2
212HP/178TQ
Old 04-21-2008   #20 (permalink)
Super Moderator
Activity: 100.0%
Images: 178
use turtle wax rubbing compound before doing the final polish like scratchx or plastx.
__________________
Old 04-21-2008   #21 (permalink)
I just burnt my tongue
ragingSPAM's Avatar
Points: 21,437, Level: 92
Points: 21,437, Level: 92 Points: 21,437, Level: 92 Points: 21,437, Level: 92
Level up: 9%, 913 Points needed
Level up: 9% Level up: 9% Level up: 9%
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Images: 8
ragingSPAM is just really nice ragingSPAM is just really nice ragingSPAM is just really nice ragingSPAM is just really nice ragingSPAM is just really nice
Send a message via AIM to ragingSPAM Send a message via Yahoo to ragingSPAM
I used to do a lot of auto body work and the easiest thing we used and the cheapest was the mothers clearcoat polish...the ultra fine stuff...its like $10 a bottle but it works the best in my opinion
__________________
2001 miata totalled
2006 RSX-S NHBP totalled
2004 Civic LX coupe SSM sold... ....i miss it...
1984 AE86 sold
1987 AE82 corolla fx-16 (redtop swapped) no longer have
1993 K20A2 swapped EG sedan
1995 Eclipse (sold)
1986 AE86 Corolla (sold)
ragingSPAM is offline
Old 04-22-2008   #22 (permalink)
drunkenmagnum's Avatar
Points: 12,750, Level: 73
Points: 12,750, Level: 73 Points: 12,750, Level: 73 Points: 12,750, Level: 73
Level up: 75%, 100 Points needed
Level up: 75% Level up: 75% Level up: 75%
Activity: 0%
Images: 21
drunkenmagnum is a glorious beacon of light drunkenmagnum is a glorious beacon of light drunkenmagnum is a glorious beacon of light drunkenmagnum is a glorious beacon of light drunkenmagnum is a glorious beacon of light
Send a message via AIM to drunkenmagnum
Looks good, now do my windshield
__________________
196 hp
194 fpt @ 10psi - Before the rebuild
"My d!ck feels like corn"-Dane Cook
R.I.P 7thgencivic.com
Type-S Fuel Injectors for sale.
WTB: 02-04 ep3 (si) rear brake assembly
T.E.A.R.S crew member #1
drunkenmagnum is offline
Old 05-09-2008   #23 (permalink)
You VTEC...I-VTEC
Activity: 0%
I have officially failed at this and am about to throw my headlights away. I followed the steps and i can not get them clear again.
__________________
04 NHBP EM2
212HP/178TQ
Old 05-09-2008   #24 (permalink)
Points: 36,750, Level: 100
Points: 36,750, Level: 100 Points: 36,750, Level: 100 Points: 36,750, Level: 100
Activity: 0%
civicsrcool has a reputation beyond repute civicsrcool has a reputation beyond repute civicsrcool has a reputation beyond repute civicsrcool has a reputation beyond repute civicsrcool has a reputation beyond repute civicsrcool has a reputation beyond repute civicsrcool has a reputation beyond repute civicsrcool has a reputation beyond repute civicsrcool has a reputation beyond repute civicsrcool has a reputation beyond repute civicsrcool has a reputation beyond repute
^^ what did you do wrong? i just did it and it came out fine! .. you probably didnt let enough water under the headlight while you were sanding. i used a sponge to squeeze on top of the area i was sanding [while sanding] to have water constantly fall under the sandpaper so it never gets dry. so sponge in one hand and sandpaper in the other for laymans terms. the most important thing is the final grade of sanding. i probably sanded with 2000 grit for 10 minutes on each headlight just to make sure everything was smoothened out then used the plastix and it came out very nice. the outside of the headlight is flawless now but the inside is kinna messed up for some reason. just redo the final grade sandpaper sniper and make sure there is always water under the sandpaper!
civicsrcool is offline
Old 05-09-2008   #25 (permalink)
Super Moderator
Activity: 100.0%
Images: 178
is it smooth? you need rubbing compound to smoothen the plastic and then you can go ahead with the plast-x to polish it up to clear. dont worry they cant be ruined and you have tons of plastic left to mess with lol. if you are lazy get an orbital polisher for the last two things to put on. it will shine up dont worry.
__________________
Old 05-09-2008   #26 (permalink)
You VTEC...I-VTEC
Activity: 0%
i sanded with 2000 for a long time and i know to keep it very wet. it seems to be extremely smooth before i polish...i am using polishing compound and then plastx.
it pisses me off cause i am normally good with this sort of stuff.
i am starting off with 600 then 800 then 1000 then 1500 then 2000
__________________
04 NHBP EM2
212HP/178TQ
Old 05-09-2008   #27 (permalink)
Images: 11
shoulda stuck with 1000-2000. 600 is way to hard unless your sanding off eyelid paste :X
__________________
Old 05-09-2008   #28 (permalink)
Activity: 0%
i actually used 400 to start off with so it should be fine. as long as you sanded all the grades of sandpaper very well it wouldnt be a problem.
Old 05-10-2008   #29 (permalink)
You VTEC...I-VTEC
Activity: 0%
maybe that is my problem... i should go longer with say 800 and 1000
__________________
04 NHBP EM2
212HP/178TQ
Old 05-11-2008   #30 (permalink)
Images: 29
CiViCPrAnInG2k1 has a reputation beyond repute CiViCPrAnInG2k1 has a reputation beyond repute CiViCPrAnInG2k1 has a reputation beyond repute CiViCPrAnInG2k1 has a reputation beyond repute CiViCPrAnInG2k1 has a reputation beyond repute CiViCPrAnInG2k1 has a reputation beyond repute CiViCPrAnInG2k1 has a reputation beyond repute CiViCPrAnInG2k1 has a reputation beyond repute CiViCPrAnInG2k1 has a reputation beyond repute CiViCPrAnInG2k1 has a reputation beyond repute CiViCPrAnInG2k1 has a reputation beyond repute
Send a message via AIM to CiViCPrAnInG2k1
is it just me or is the finish product looks kinda filmy and unclear?
CiViCPrAnInG2k1 is offline
Old 05-11-2008
CivicForums
Honda Civic
Paid Advertisement
Tags
2004 , civic , drill , forum , headlamp , headlight , headlights , honda , lens , lenses , plastic , polish , polishing , recondition , reconditioner , reconditioning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dictionary Of Automotive Terms
Looking for a 7th gen manual for free? (UPDATED!!!)
60,000 mile Transmission fluid change
ALL of Grey's DIY's...
Oil Changes
SOHC VTEC Explained
Detailed smoked out taillights DIY w/ pictures
DIY: Changing Spark Plugs w/pics (noob version)
Ask Me About DIY Stuff V2!
DIY: Trunk Shocks
Contact Us - Honda Civic Forums - Honda Civic News - Archive - Top
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Emails Backup
