P1456? loose gas cap??
Old 12-06-2007
02civicg5's Avatar
02civicg5 will become famous soon enough
hey I took my car to autozone to get my CEL checked. they told me it was P1456 code. now i understand it could be a loose gas cap so i tightened it to 3 clicks and i reset the check engine light. i drove for about 3 days and then all of a sudden it came bak on again. i took it bak to autozone and it was the same code so i bought a new cap from autozone reset the light AGAIN!! but then again 2 days later the light came bak on. can u guys help me out and tell me wat i should do?? thanks/
02civicg5 is offline
Old 12-06-2007
My Honda Loves Me ^_^
2005EM2's Avatar
Re: P1456? loose gas cap??
Hmm.. well I sure don't know why the check engine light keeps coming back, but I had a similar problem.
Right when I got my car, within 1 week, I had a check engine light on. So after I noticed it, I then took it to the dealer and they were telling me when I go and pump fuel into my car, that I had to turn the gas cap until you hear it click 3 times. They reseted the check engine light.
After that, I followed their instructions and it never came back on.
2005EM2 is offline
Old 12-06-2007
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
ive had the same problem with my k-swap forever now. i had an aftermarket gas cap, thought it was that, so i bought an OEM gas cap from the dealer, reset the code, always comes back on. i'm gonna take the whole EVAP system out here soon then just wait til I have k-pro and disable OBDII functions.
beadebaserr is offline
Old 12-06-2007
there is some kind of leak in the system. maybe even a bad seal around the tank/fill hole.
gearbox is offline
Old 12-06-2007
skipbarber's Avatar
if it isnt the gas cap, something else is letting out the gas tank pressure. a line could be busted or loose, the vent solenoid could be stuck open (depending on what code it is) or the vapor canister could be leaking. the system should be smoked or pressure tested to find the leak. There is an EVAP service port marked with a green tag near the throttle body. a shop connects a smoke machine or pressure tester to that port while a technician searches or listens for signs of leakage. There really isnt one part you can change to make the light go away. and youre only getting the code when the monitor runs, which explains the delay between reseting and the MIL setting. i think if you drive around with less than 1/3 of a tank of gas all the time, it wont ever run, but you dont want to do that forever.
skipbarber is offline
Old 12-06-2007
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
P1456 EVAP Emissions Control System Leak Detected (Fuel Tank System)
Control Canister System is P1457
and Purge Flow Switch Malfunction is P1459
http://www.canobd2.com/support/DTC_lookup.asp
bomerman19 is offline
Old 12-06-2007
Xhondatech's Avatar
Xhondatech is an unknown quantity at this point
this sounds a little rediculous but we had a problem with that at my old dealership... you could have spiders in your EVAP Canister... NO EFFIN LIE MAN
Xhondatech is offline
Old 12-07-2007
omg you just totally turned me off from trying to fix it. i'd rather have a CEL than having to deal with some nasty spiders.
Old 12-08-2007
02civicg5's Avatar
well wen i reset the light it lasts me about 2-3 days b4 it actually comes bak on. i went twice already to autozone to get the code read and they tell me its P1456. so i dunno wat the hell is going on. i mean i still get an avg of 370 miles to the tank 65% highway/35% city.
Old 12-09-2007
yeah, it honestly means nothing and won't affect performance or gas mileage. mine has been on for years now. the only downfall is that if your CEL actually comes on for something else, you won't know unless there is another vital sign. not a problem for me because i am meticulous about my car and it doesnt get driven often anyway.
Old 12-18-2007
chirpa12's Avatar
chirpa12 is an unknown quantity at this point
How do you reset the check engine light?
chirpa12 is offline
Old 12-19-2007
02civicg5's Avatar
youreset it by taking out the ecu #6 fuse under ur hood. take it out for 10 secs and then put bak and dats it
Old 09-30-2009
RED98civicLX's Avatar
RED98civicLX is an unknown quantity at this point
I have a 98 Civic that's giving the same code. Once the gas cap is tightened, does the computer have to be reset, or will the CEL go off by itself?
RED98civicLX is offline
Old 10-01-2009
eventually it will go off if the problem is fixed
gearbox is offline
liagreenhalgh92
07-21-2015 01:31 PM
Hqly2001
22
07-12-2015 06:44 PM
CivicsClass101
07-09-2015 11:14 AM
fvckbg
07-07-2015 07:08 PM
cgavin1
07-07-2015 07:10 AM
Quick Reply: P1456? loose gas cap??
