Go Back   Honda Civic Forum > GENERAL > General Honda Civic Forum Archive.
Register Forgot Password?
Register Photo Gallery FAQ Members List Search Today's Posts Mark Forums Read Experience GarageVendors TSB & Recalls
Welcome to Honda Civic Forum
LinkBack Thread Tools Search this Thread
Old 08-17-2006   #1 (permalink)
sucanushie is an unknown quantity at this point
How to get amp power cable through firewall?
Hey guys,
I having a hard time feeding my amp power cable down through the firewall.
I have a 2002 1.7 EL. I have attached this pic with the gromet i was trying to feed the cable through.... Is this the right spot? this is the left side of the car if your looking at the hood.
www3.ns.sympatico.ca/mperrin/pic.jpg
sucanushie is offline
Old 08-17-2006   #2 (permalink)
_unclejuice is a jewel in the rough _unclejuice is a jewel in the rough _unclejuice is a jewel in the rough
Send a message via Yahoo to _unclejuice
looks like a crappy spot to me. i ran mine so that the cable comes in under the dash. id take pics but its wicked dark outside. but there is no wrong place to run it. just drill a hole, stick a grommet in it, and shove it through.
__________________
BUY MY STUFF!!!
N/A EM2 Crew!!
Don’t jump on the turbo bandwagon!!! Go Naturally Aspirated Baby!!!
R.I.P 7thgen Club Member #1
Quote:
Originally Posted by Boilermaker1 View Post
You're trying to build a motor without being "so technical"? Get the hell out of here. What do you think it is, legos?
Quote:
Originally Posted by xjollyxgiantx
well my buddy is doing my head swap and hes havin some trouble the car turns over but it doesnt stay on do i need to get ex spark plugs?
_unclejuice is offline
Old 08-17-2006   #3 (permalink)
CIVIC808's Avatar
Points: 8,418, Level: 61
Points: 8,418, Level: 61 Points: 8,418, Level: 61 Points: 8,418, Level: 61
Level up: 90%, 32 Points needed
Level up: 90% Level up: 90% Level up: 90%
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Images: 16
CIVIC808 is an unknown quantity at this point
Send a message via AIM to CIVIC808
try the ones closer to the floorboard area right below the area you was trying at.
CIVIC808 is offline
Old 08-18-2006   #4 (permalink)
Points: 7,946, Level: 59
Points: 7,946, Level: 59 Points: 7,946, Level: 59 Points: 7,946, Level: 59
Level up: 98%, 4 Points needed
Level up: 98% Level up: 98% Level up: 98%
Activity: 0%
jackburton will become famous soon enough jackburton will become famous soon enough
I went throught the gromet on the passengerside. I went through the rubber part below the original hole, where all the wires come through.
I made a small hole with a hanger, which the cable was taped to, and just pushed it through, then pulled it fromt the otherside.
__________________
Have you paid your dues jack?
The check is in the mail
jackburton is offline
Old 08-20-2006   #5 (permalink)
Images: 6
05civicFun is an unknown quantity at this point
you can take off the little trim piece under your dash, and drill a hole up in there so its hidden and you can shoot it straight into your trim and nobody would know you were running power through your car, mines right above where the clutch would be and it goes right behind the hood release into the trim under the door and all the way back and you cant even see it, even if i can guess i got at least 150 ft. of speaker wire running through there now
__________________
*insert witty and smartassed signature here*
05civicFun is offline
Old 08-20-2006   #6 (permalink)
EggRollBandit05's Avatar
EggRollBandit05 will become famous soon enough EggRollBandit05 will become famous soon enough
Send a message via AIM to EggRollBandit05
I ran mine through the gromet near the floor on the passenger side where some other wires come through, no drilling required just made a hole with needlenose pliers and pulled the wire through. Just have to pull the trim piece above the passengers feet and peel back the carpet to expose it.
EggRollBandit05 is offline
Old 08-20-2006   #7 (permalink)
Images: 6
what size wire is everyone running, i looked at those grommets and its not exactly big enough for true 4 guage let alone a good spot for the 1/0 guage that im gonna be needing to run here soon
__________________
Old 08-20-2006   #8 (permalink)
DeX
Canadian, Eh!
DeX's Avatar
Points: 17,987, Level: 85
Points: 17,987, Level: 85 Points: 17,987, Level: 85 Points: 17,987, Level: 85
Level up: 28%, 363 Points needed
Level up: 28% Level up: 28% Level up: 28%
Activity: 0%
DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all
I ran mine through the passenger side like everyone else, I have a 10 gauge and a 4 gauge wire running through there. Look under your glovebox, pull the carpet back, and all the way up in the firewall, there's a little hole that goes through to a grommet on the other side. You'll have to use a screwdriver or hanger to poke a hole through it, but make sure you don't jam it through and into what's on the other side. Do it gently. I'll take a picture with a camera phone here if I can, hold up.
Ask and you shall receive.
Click the image to open in full size.
__________________
7th Generation Member Against Street Racing Number 43
www.em2ab.com
Fully integrated carputer with W-Fi, GPS, 2000 songs/music videos, and weather
7 inch Xenarc 700TSV VGA in dash touchscreen
Compustar 2 way paging alarm/starter system
35% tint excluding windshield
D.I.Y. Blacked Out Headlights
D.I.Y. Debadge
D.I.Y. Remote Trunk Release
D.I.Y. Trunk Air Shocks (Scouting Parts)
Air Ride Suspension Setup (Awaiting Parts)
DeX is offline
Old 08-20-2006   #9 (permalink)
im runnin 4 guage right now. when i get my trunk finished im movin the battery to the trunk and gonna run 0 guage.
__________________
BUY MY STUFF!!!
N/A EM2 Crew!!
Old 08-20-2006   #10 (permalink)
DeX
Canadian, Eh!
DeX's Avatar
Activity: 0%
Why? Just upgrade your battery, alternator, and wiring between the 2. Shortening the wire between your battery/amps and lengthening the wire between your battery/alternator is not a solution.
__________________
www.em2ab.com
D.I.Y. Debadge
DeX is offline
Old 08-21-2006   #11 (permalink)
Images: 6
instead of moving the battery to the trunk (unless you need the space for something, then you just relocate the battery in the same area) just run 1/0 on the main 3 power, my friend just did it and hes got a stock battery and alternator and is running approx 14.5 volts now in his battery, you could just take a battery to your trunk and get a switch instead, that way when the fronts full, alt charges the rear one
i wouldnt suggest running power wire through an existing hole, its there for a reason, and you draw enough current through that thick of wire to disrupt other wires around it (alternator whine), thats why you designate its own path, run your rcas and speaker wires away from it so they never touch or come close untill their at the amp, cause i gotta kill my whine, its the biggest let down running an sq system and you get alt whine.....
__________________
Old 08-21-2006   #12 (permalink)
BERGER's Avatar
Images: 6
BERGER will become famous soon enough BERGER will become famous soon enough
Send a message via MSN to BERGER
i have 1/0 guage running from the front to the back underneath the car then up into my trunk.. this **** is big and was hard to work with but needed it for my stereo.. now i need a new alternator cause the stock 70 amp can't keep up.. sorry jack the thread here but does anyone know if a alternator that's for a d16 will work on a d17??
BERGER is offline
Old 08-21-2006   #13 (permalink)
Images: 6
get an ohio generator alternator
__________________
Old 09-10-2006   #14 (permalink)
C-Mo's Avatar
Images: 8
C-Mo is an unknown quantity at this point
I ran my wire where the clutch would be. I drive a 2002 EX (auto). It worked pretty slick and I ran the wire underneath all the trim on the driver's side of the car. You can't see the wire at all and was rather easy to put in.
__________________
(\__/)
(o.O )
(> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination
C-Mo is offline
Old 01-01-2009   #15 (permalink)
sweetbrett is an unknown quantity at this point
Re: How to get amp power cable through firewall?
i'm a newb attempting this for the first time. anyone have pics to help me visualize exactly what i need to do? i've got a 2002 lx sedan
sweetbrett is offline
Old 01-02-2009   #16 (permalink)
CanadianCivic02's Avatar
Points: 3,404, Level: 36
Points: 3,404, Level: 36 Points: 3,404, Level: 36 Points: 3,404, Level: 36
Level up: 36%, 96 Points needed
Level up: 36% Level up: 36% Level up: 36%
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
CanadianCivic02 is an unknown quantity at this point
WHY THE HELL IS EVERYONE DRILLING! =|
4gauge fits with the rst of the wires that run to the computer, just coathanger the end and slowly pull, dont drill!
__________________
Canadiancivic02 has now joined the carbon club
CanadianCivic02 is offline
Old 01-02-2009   #17 (permalink)
Points: 36,750, Level: 100
Points: 36,750, Level: 100 Points: 36,750, Level: 100 Points: 36,750, Level: 100
Level up: 0%, 0 Points needed
Level up: 0% Level up: 0% Level up: 0%
Activity: 0%
civicsrcool has a reputation beyond repute civicsrcool has a reputation beyond repute civicsrcool has a reputation beyond repute civicsrcool has a reputation beyond repute civicsrcool has a reputation beyond repute civicsrcool has a reputation beyond repute civicsrcool has a reputation beyond repute civicsrcool has a reputation beyond repute civicsrcool has a reputation beyond repute civicsrcool has a reputation beyond repute civicsrcool has a reputation beyond repute
peel back the carpet on the passenger side comparment (where your feet go, lol).. its only held in place by velcro. if you take a look farther up into the dash from the feet area, you will see a hole with some wires run through it. take a metal clothes hanger and un ravel it to make it just a big metal wire. tape the hanger around your power wire and stick the hanger with the wire on it through the hole. grab the thing from the other side.
__________________
here is my pos
civicsrcool is offline
Old 01-02-2009   #18 (permalink)
in the engine compartment, it is the rather large circular, rubber grommet on the passenger side, just below the 4"x4"x4" approx. box held on by 2 10mm screws (not sure what the part is exactly)...correct? How is that black piece of plastic by the passenger's feet held on, by snaps only? So just pull to remove?
i need to start on the engine compartment side since i'm using a wiring kit that already has the fuse and connector installed on the battery side.
Old 01-02-2009   #19 (permalink)
twiztedD17A1's Avatar
twiztedD17A1 is just really nice twiztedD17A1 is just really nice twiztedD17A1 is just really nice twiztedD17A1 is just really nice twiztedD17A1 is just really nice
Send a message via AIM to twiztedD17A1
Same here the large rubber gromet on the passenger side
twiztedD17A1 is offline
Old 01-02-2009   #20 (permalink)
got it. pushed it thru there from the engine side, and only had to undo the glove box to get to it on the interior. I then ran the wire under the door trim on the passenger side to the trunk.
Old 01-05-2009   #21 (permalink)
DeX
Canadian, Eh!
DeX's Avatar
Activity: 0%
You can also run it behind the plastic molding that goes around the edge of the headliner above the door. That's what I did, kept it away from all other audio wires to eliminate interference.
__________________
www.em2ab.com
D.I.Y. Debadge
DeX is offline
Old 01-05-2009
CivicForums
Honda Civic
Paid Advertisement
Tags
01 , 08 , amp , civic , firewall , honda , hood , panel , power , release , remove , run , running , wire , wiring , www3nssympaticocamperrinpicjpg
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dictionary Of Automotive Terms
60,000 mile Transmission fluid change
Looking for a 7th gen manual for free? (UPDATED!!!)
SOHC VTEC Explained
AC Recharge kit overcharged my system! What now?
ALL of Grey's DIY's...
Oil Changes
Detailed smoked out taillights DIY w/ pictures
Removing door panel from a 2002 civic
Automatic Transmission Flush
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Emails Backup
