Replacing motor mounts Civic Si 2002
Old 04-17-2006
cmeghea's Avatar
cmeghea is an unknown quantity at this point
I am planning to replace the motor mounts myself on my 2002 Civic Si. Except the one by the transmission, which is already replaced by my mechanic. That leaves 3 of them: the 2 on the sides, and the one in the middle, by the radiator.
Question: when I replace the mounts (one by one), do I need to sustain the engine somehow? Will the engine stay in place by itself while replacing each mount? I am asking because I was told that in older cars (Hondas and non-Hondas) you had to support the engine when replacing each mount, otherwise it moves out of place (sort of "fall down") and the other mounts will get broken. One friend told me I should support the engine from underneath the car with a hydraulic lift. Any suggestions from others who replaced the mounts themselves?
Thanks a lot,
C.
cmeghea is offline
Old 04-17-2006
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
I'd like to know too....gotta get my new energy bushings installed to get rid of that nasty wheel hop
bOoStEd042dr is offline
Old 04-17-2006
cmeghea's Avatar
replacing 2002 Civic Si motor mounts
From the member "gearbox":
"for the engine mounts, i believe you need to have the engine supported with that big machine thing, um cherry picker? that thing you use to drop engines in"
However, does anybody know for sure if the engine needs to be supported?
cmeghea is offline
Old 04-17-2006
DDragon7's Avatar
I think it has to be supported some how, if not you run the chance of screwing up the rest of the mounts.
DDragon7 is offline
Old 04-17-2006
well thats nice to know cause i'm almost positive i read in a thread a while back you can do one at a time with out a engine hoist of any sort
Old 04-17-2006
cmeghea's Avatar
I read the same thing in an earlier post on this website, that you can change them one by one, with no mentioning of any support for the engine. Then, a friend told me that his older Golf needed engin support when replacing the mounts. That's exactly why I asked.
I'll suport it with a hydraulic lift underneath, just in case (put a piece of wood between the lift and the engine, otherwise it's metal on metal...).
cmeghea is offline
Old 04-17-2006
djmota's Avatar
just put a jack under the engine and trans to support the wieght while the mount being replaced is out. No big deal. you could try to do it without but I don't see the point.
djmota is offline
Old 04-17-2006
DDragon7's Avatar
Just put the jack under there for a little bit of support.
DDragon7 is offline
Dorval Andre
General 7th Gen
28
07-21-2022 05:53 PM
CarStuff
12-06-2020 12:52 PM
MN-02-CivicEx
28
05-02-2015 09:11 PM
bsmiley
04-27-2015 01:27 PM
GH04si
04-15-2015 08:13 PM
Quick Reply: Replacing motor mounts Civic Si 2002
