Rattle in Rear (SOLVED)!!!
Old 10-29-2005
Whelan's Avatar
Whelan is an unknown quantity at this point
I figured it out last night and fixed it. On my 02 Civic Coupe there has always been this constant annoying light rattle that sounded like it was the actual backseat. So I always figured it was where the latches were when you fold the seat down. Well it turns out this issue is from a completely different source.
Your Head Liner!
So I picked up a few pieces of insulation foam and pulled down the head liner simply by using a coin to twist the center plug in the rear then prying the clips along the back edge. Then add the foam in order to keep the liner pressed and firm so the rattling will cease. My rattle was coming from the passenger side so I pust most of my foam there. But man what a difference, the car is so much quieter.
Give it a try, next time you are driving and you hear that weird rattle from the rear seat, reach your hand up and push the head liner back there up and listen, Unless its an exterior problem (wheels, suspension, etc.) Then this should be your issue.
Whelan is offline
Old 10-29-2005
hypnotic7thgen's Avatar
hypnotic7thgen is an unknown quantity at this point
nice! i hate those weird annoying rattles. i've currently got one under my car i think it a heat shield rubbing against my exhaust so no big deal.
hypnotic7thgen is offline
Old 10-29-2005
Life Begins > 6800rpms
blouisgod's Avatar
yeah welcome to the 7th gen civic. thats a big one and also the rattle of the rear deck hitting the rear window- some window foam works as a great buffer.
blouisgod is offline
Old 10-29-2005
skipbarber's Avatar
my ceiling used to rattle the first few months after i bought my car. It went away, but in my car, it always feels like the rattles just move from one place to another. I gave up trying to solve them. I have one coming from behind my dash when i drive over 60 mph, I just turn up the radio.
skipbarber is offline
Old 10-29-2005
let the devil out
eye_see_you's Avatar
there are all kinds of annoying rattles mine happens to be in my trunk lid in the center right at the edge and i've yet to stop that one
eye_see_you is offline
Old 10-29-2005
Whelan's Avatar
Yeah I had the license plate fixed before I even got the car. some rubber washers to prevent the rattle there. Other than the head liner which is now fixed I have nothing in the car that rattles or makes noises and Im sittin at 61K
Whelan is offline
Old 10-29-2005
Ashho-san 7thgen Ninja
Ashhole's Avatar
Ashhole will become famous soon enoughAshhole will become famous soon enough
yeah those rattles suck. ive got one coming from the mud flap on my front passenger side fender.
Ashhole is offline
Old 10-29-2005
manahoonie's Avatar
yeah, i have the same annoying rattle in my 02 sedan. i always thought it was in the liner (in particular i thought it was the wires for the dome light hitting the frame), but my friends always said that it sounded like it was further back. anyways, i tried silencing the wires once, but that didn't work, so now i guess i'll tyr silencing the whole liner itself!
manahoonie is offline
loosescrew84
16
08-11-2015 07:08 PM
frisbeeguy2
07-30-2015 03:00 PM
Yazan93
07-14-2015 08:56 PM
fvckbg
07-07-2015 07:08 PM
Quick Reply: Rattle in Rear (SOLVED)!!!
