Milled Head
Abortion Survivor
Rep Power: 269 Milled Head
Hello i wanted to know how many people have a milled head and what is the cam gear setting set at? What are the benefits of milling the head and what are the negatives about milling the head? I am very scarred right now because my mechanic messed up my head so he milled it. I am turbo and I have the Crower Stage two cam and i am going to hook up vtec i am very scarred the valves will hit the pistons. What do you guys recommend i set the cam gear at? I was thinking Advanced 4 degrees. Please help me out. The only good thing about valves hitting pistons is i get to buy pistons and rods with the help of the mechanic. I really don't want this to happen so please help me out any way you guys can.
Rep Power: 278 Most heads have a little extra clearance to allow for milling or resurfacing. Once should be fine. You can also get a thicker head gasket to compensate. If your head was overcut, you have to replace it.
Rep Power: 0 I have had my head milled down after I blew a head gasket...I also had the shop do a Port and Polish and 4 angle valve job...Milling the head pretty much rasies the compression by a little bit...Like tinman said, you can compensate the higher compression after the milling with a thicker head gasket...You just have to make sure that the head isn't milled down too far, because there will be some clearance problems with internal parts in the head
Rep Power: 787 Milling = more compression, good for na, bad for turbo. Positives are more power with higher octane gas, but you need cam gear to adjust. I'm still waiting to get mine and tune it. Milling too much can cause problems like head bolts bottoming out, or too much timing belt slack.
Abortion Survivor
Rep Power: 269 Well **** hopefully my mechanic didn't. According to him and another mechanic they say it won't hit especially with the cam gear. One other mechanic told me i am asking for trouble. What do you guys recommend i set the gear at?
Rep Power: 787 normally with a milled head, wil will need to advance the timing a couple degrees to get back to stock. Maybe a bit more if needed. But I'm guessing between 1-4 degrees. Only a dyno will tell.
Rep Power: 787 ya i'm just saying. I wouldn't just choose something without a dyno. But yea thicker head gasket is the best way if you think he took off too much. Aren't you supposed to use domed pistons to increase compression anyway?
DONT PANIC
1 Post
Rep Power: 261 milling the head accomplished the same thing (to an extent). By making the combustion chamber smaller, you are effectively raising the compression.
You can also change the dynamic compression with valve timing (among other things). So be careful when you adjust the cam.
Abortion Survivor
Rep Power: 269 I set all the valves at stock settings and I am going to try advancing the cam 2 degrees to begin with and then go from there. On the dyno should i tell them to advance it more to see what happens or what do you guys suggest?
7thgensurvivor
08-26-2015 06:17 PM
Kyles24
07-12-2015 09:15 PM
