constant 12v source....
Old 08-15-2005
fuk tha man!
djspot's Avatar
djspot is an unknown quantity at this point
what wire in the harness where our decks are, or anywhere else for that matter, provide a constant 12v current source from the battery even when the car is completely off???
djspot is offline
Old 08-15-2005
dj02's Avatar
there isnt any constant 12v source when the car is fully off.
dj02 is offline
Old 08-15-2005
7thgens official a$$hole
ajhdragon's Avatar
if yo uhave the honda civic electrical manual from honda there is an open space in the fuse box that is a constant 12v source. even when off. i want to say spot 13. but not sure i'll have to check when i get home.
ajhdragon is offline
Old 08-15-2005
um the battery is a constant 12v source. Just hook a wire to the positive terminal.
gearbox is offline
Old 08-15-2005
dj02's Avatar
ya but that will drain your batt lol.
i never knew about a open spot. that would make sense. damm i need my helm
dj02 is offline
Old 08-15-2005
fuk tha man!
djspot's Avatar
it will only drain your battery if the current is being used...that's what Im gonna do though, run a wire straight from the battery, I was just trying to find an easier route
djspot is offline
Old 08-15-2005
I am your Mom's Hero!!
KnocturnalEM2's Avatar
Wire #10 or the White and Red Wire from the deck provides a constant 12v source and is Fused to #9 (10A) under the hood! Hope this helps!!!
Straight from Factory Service Manual...
Last edited by KnocturnalEM2; 08-15-2005 at 06:14 PM. Reason: Added Picture from FSM!
KnocturnalEM2 is offline
Old 08-20-2005
kumanan's Avatar
kumanan is a jewel in the roughkumanan is a jewel in the roughkumanan is a jewel in the roughkumanan is a jewel in the rough
dont hook up neon lights to it.. when the battery jumps to 13,14 vs... the neon will break.. unless you got a transformer for the neon that keeps it at 12V constant
kumanan is offline
Old 08-20-2005
i thought every neon has a separate or built-in transformer.
gearbox is offline
Old 08-20-2005
Da1lyDr1ver's Avatar
ok, i believe you're trying to hook up your headunit and not lose the memory when the car turns off right?
to get constant power all the time, even if the car is off... run the wire to the fusebox under the steering wheel. look for the fuse thats for the headlights. run the wire to that fuse and you'll have constant power all the time. this way, you wont have to run it throught the firewall.
if you dont understand me then just say so and i'll try to expalin better.
Da1lyDr1ver is offline
Old 08-20-2005
dariusld's Avatar
dariusld is an unknown quantity at this point
There are empty spots on the fuse box that you can use. Use a test light to find them.
dariusld is offline
Old 08-20-2005
fuk tha man!
djspot's Avatar
so you guys know, here's what Im doing....if ya'll have an xbox or such in your car you know unless you hook your inverter directly to your battery, you know its a bitch that everytime you just go to ACC with your car and then crack up again, the inverter restarts because power is cut out...well I figured out how to have it so that doesnt happen, but I need constant power to achieve this...
for anybody that may be wondering, here's how to do it...
tap into an ACC line and an IGN line, put a diode on each and then combine them to make one connection. Then place a fuse to be safe, then wire up a standard 12v bosch type relay...now when you crank up your car your xbox or anything else you have hooked up to this wont turn off during crank...I'll do up a good diagram just now, and post it...
djspot is offline
Old 08-21-2005
skipbarber's Avatar
i dont think id grab constant at the radio for that purpose, go to the fuse box or ignition harness instead.
skipbarber is offline
Old 08-21-2005
CivicSky's Avatar
CivicSky is an unknown quantity at this point
one of the constant 12v sources on the fuse box is the spot # 3. Trust me on that. I am using it
CivicSky is offline
Old 08-21-2005
fuk tha man!
djspot's Avatar
here's how to wire this whole thing...
djspot is offline
h4ldol
04-24-2017 08:16 PM
68camerors
09-24-2015 06:18 PM
BJB
09-14-2015 11:16 PM
Bricoleur
09-09-2015 12:23 PM
Quick Reply: constant 12v source....
