Oil Pan Cracked!!
Old 07-23-2005
midnightblueEX's Avatar
midnightblueEX has a little shameless behaviour in the past
Oil Pan Cracked!!
Im pissed, but anyways, its a small crack but it is dripping.. Is there something i can use to bond the crack for a few days until i get the oil pan replaced.
midnightblueEX is offline
Old 07-23-2005
DONT PANIC
turboengnr's Avatar
is it an ex or an lx?
turboengnr is offline
Old 07-23-2005
its an EX... im pissed.. do you think it will be under warranty? its a certified warranty. anyways.. will JB weld work for a temporary fix?
Old 07-23-2005
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
jb should be a temp fix
SODJAZERO is offline
Old 07-23-2005
DONT PANIC
turboengnr's Avatar
yea. JB weld will work. Just make sure it is EXTREMELY clean before you apply it.
You will want to drain all the oil out, clean it with brakleen, then apply the JB weld.
If you get to keep the pan after they replace it, lemme know. Im going to build a custom one, and i need the flange off the top of the EX pan.
PM me.
Old 07-23-2005
ill give u the pan.. but do u think if i over tightened the drain bolt it would cause the oil pan to crack.. basically what im getting at is.. If its under warranty the dealer will probably say i over tightened it.. or ask who did the oil changes and give me all kinds of crap..
Old 07-23-2005
DONT PANIC
turboengnr's Avatar
i really dont see that happening. But, i am sure it could.
I had one moron tighten my oil drain plug with an impact gun. When it came time to take it off, i was sooooo f'ing pissed.
Old 07-23-2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
i used jb for a crack on my f-150 for over a year and never had a problem. your almost better off leaving on the original oil pan with jb and a crack than trying to get another one on aswell as the factory did and not having a leak.
nick95673 is offline
Old 07-23-2005
CraigW's Avatar
JB Weld = Good (requires 24hrs to set properly)
JB Quick = Sux
CraigW is offline
Old 07-23-2005
civic01vtec's Avatar
Who in their right mind uses a impact to tighten bolts on cars.......especially a oil drain plug
civic01vtec is offline
Old 07-23-2005
BLDNPSI Mod
tfnaaf's Avatar
depending on where its cracked at , ive seen the aluminum pans welded before if you wanted to fix it, but then again you could just about buy a brand new one for what it could cost to pay to have it Tig welded
tfnaaf is offline
Old 07-23-2005
civic4dizoor's Avatar
civic4dizoor is on a distinguished road
How did u crack your oilpan ? ive been scraping alot over speedbumps , driveways , and Lumps on the road . just wondering
civic4dizoor is offline
Old 07-23-2005
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240's Avatar
Blahman240 is on a distinguished road
just checked... a new EX oil pan from hondaautomotiveparts.com is 66 bucks.
Blahman240 is offline
Old 07-23-2005
Blahman240's Avatar
HAHAH! That had to suck!
Old 07-23-2005
DONT PANIC
turboengnr's Avatar
yea, i was pissed off. Took me a 3/4" drive ratched and a 2' breaker bar to get it loose.
Old 07-23-2005
Blahman240's Avatar
lol! Thats ****'n great... If it were me I would have ended up dropping the oil pan... lol. Cuz I'm crazy/stupid like that...
Old 07-25-2005
Bigfella's Avatar
Bigfella is an unknown quantity at this point
One word of caution with swapping the pan. Measure the depth of the pan with the old one and make sure its identical in every way. A neighbour swapped his pan on a 94 civic coupe due to rust, got another one from a scrap yard fitted it, thought fine, started it up, no oil pressure, drove it to garage just down road to have it checked out. The pan he was given was a few millimeters shorter than the one he took off, hence touched bottom of oil pump = one wrecked engine. Be careful.
Bigfella is offline
Old 07-25-2005
Blahman240's Avatar
if you are buying bran new OEM this shouldn't be a problem.
Old 07-25-2005
EManEX's Avatar
EManEX will become famous soon enoughEManEX will become famous soon enough
Since the crack is next to bolt, or in the tread you are better off buying a new pan. I know cause that happened to me in my previous car.
EManEX is offline
Old 07-25-2005
Drunken Master-7thgen Ninja
MajinB's Avatar
warranty should cover it.
MajinB is offline
brags
46
01-07-2016 09:39 PM
liagreenhalgh92
07-21-2015 01:31 PM
silentz
07-09-2015 08:16 PM
671civicLX
07-09-2015 03:22 PM
hayden55
07-08-2015 11:38 PM
Quick Reply: Oil Pan Cracked!!
