Displacement
Old 06-12-2005
I Hunt Goats, Rams, And Mustangs.
TransformedBG's Avatar
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Displacement
What is it? How does it work? What makes it?
TransformedBG is offline
Old 06-12-2005
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1's Avatar
4drcivic2k1 is an unknown quantity at this point
Bore x Stroke x # of cylinders.
4drcivic2k1 is offline
Old 06-13-2005
I wish I was asian
cambo's Avatar
Displacement = size of your motor.
cambo is offline
Old 06-13-2005
master of the culinary martial arts
masarak's Avatar
masarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of light
Courtesy of http://auto.howstuffworks.com/engine.htm/printable:
Displacement
The combustion chamber is the area where compression and combustion take place. As the piston moves up and down, you can see that the size of the combustion chamber changes. It has some maximum volume as well as a minimum volume. The difference between the maximum and minimum is called the displacement and is measured in liters or CCs (Cubic Centimeters, where 1,000 cubic centimeters equals a liter).
Here are some examples:
  • A chainsaw might have a 40 cc engine.
  • A motorcycle might have a 500 cc or a 750 cc engine.
  • A sports car might have a 5.0 liter (5,000 cc) engine.
Most normal car engines fall somewhere between 1.5 liter (1,500 cc) and 4.0 liters (4,000 cc) If you have a 4-cylinder engine and each cylinder displaces half a liter, then the entire engine is a "2.0 liter engine." If each cylinder displaces half a liter and there are six cylinders arranged in a V configuration, you have a "3.0 liter V-6."
Generally, the displacement tells you something about how much power an engine can produce. A cylinder that displaces half a liter can hold twice as much fuel/air mixture as a cylinder that displaces a quarter of a liter, and therefore you would expect about twice as much power from the larger cylinder (if everything else is equal). So a 2.0 liter engine is roughly half as powerful as a 4.0 liter engine.
You can get more displacement in an engine either by increasing the number of cylinders or by making the combustion chambers of all the cylinders bigger (or both).
masarak is offline
Old 06-13-2005
I see, so bassically the main avantages to haveing a larger displacemen it more power huh?
Old 06-13-2005
Jap-Euro Fusion
Boilermaker1's Avatar
Its (pi*.5*bore^2)*stroke* number of cylinders
In simple talk... thats the volume of a cylinder * the amount of cylinders there are. Convert your units. If you do the bore and stroke in mm, you'll get a displacement in cubic mm and you'll need to divide by 1000 to get it in cc.
Boilermaker1 is offline
Old 06-13-2005
Back From The Banned!
CuRiOuSfIsH's Avatar
it's also about how you make the power.... just b/c an engine is big doesnt mean it's going to make big power. ie: Fox3 Mustang GT had 5L and rated at about 200HP, many V6's now adays are rated on that power in all types of cars. And then there are some I-4's claiming that power. Big engine should have the advantage of torque and may be easier to make more power.
CuRiOuSfIsH is offline
jpandjf
08-03-2015 05:02 PM
ballmich
07-09-2015 11:59 AM
S2000man01
09-29-2008 04:08 PM
APME123
12-11-2003 11:52 PM
n00dleboy
01-29-2003 10:31 PM
Quick Reply: Displacement
