DIY: DEI (viper/clifford..) RStart/keyless/alarm INSTALL
Old 01-02-2005
Senior Member
profuse007's Avatar
profuse007 is an unknown quantity at this point
www.home.earthlink.net/~profuse007/id3.html
finally got around to do this write up..... just got camera (some pic blur)
have fun
profuse007 is offline
Old 01-03-2005
Civicly02's Avatar
cool thanks. my auto start was not working because I had no idea on how to do it
Civicly02 is offline
Old 01-03-2005
nunzio42's Avatar
nunzio42 is an unknown quantity at this point
wow, looks complicated, but thanks for the diy......been looking for one for a while
nunzio42 is offline
Old 01-03-2005
opto_isolator's Avatar
Its not easy - this is a job for someone who has done something like this in the past....
If you aren't comfortable without having your car for a day or 2, take it to a professional. It took me 2 days to install my clifford....
opto_isolator is offline
Old 01-03-2005
Senior Member
profuse007's Avatar
I broke it down into ttwo parts: 1. install the alarm/RS/keyless unit
2. install the 555I, antitheft bypass
the tutorial is planned out. read all the diagram, i marked all the wires you need and not need and maybe needed for installation. if you have ?, just ask.
whats good about this tutorial is that you can pretty much get any DEI products. theres like 10 diff type of units made by DEI that have an exact diagram.
Old 01-03-2005
Senior Member
profuse007's Avatar
it shouldnt be complicated, ive tested every wires and ensure the right connection. there are pics of the locations on where to get those wires in ur civic.
all y'all have to do is make connections.
Old 01-03-2005
< My future wife.
armieo's Avatar
Very helpful, thanks.
armieo is offline
Old 01-03-2005
Senior Member
profuse007's Avatar
Clutch Bypass
plz do not ask me about tempoarily bypassing clutch when RS. the unit is made for automatic EFI.
i nor this site dont think either of us should encourage this kind of hazard...... just email if youre just so curious.
NEXT tutorial: ill try to write up a compustar 2wss-as for MTranny civics. this unit is safe for MT's.
Old 01-03-2005
Senior Member
profuse007's Avatar
the installation time is appx ~4hrs for average isntallers out there.
the installation time is appx ~1day for DIY (better start early in the morning)
what clifford model did you used?
Old 01-03-2005
Wolfgang5884's Avatar
nice, i'm getting my alarm soon
Wolfgang5884 is offline
Old 01-03-2005
I have an intelliguard 850....
The hardest part is splicing in all of the wires, especially the ignition kill, since they are so large. Other than that, routing the wires is the second hardest thing.
Old 01-03-2005
Senior Member
profuse007's Avatar
ill install the exact unit on a buddy's 01 prelude tomorrow.
some of the wire is kinda hard to read. the ignition is the easiest place to splice through, all the honda and acura have worked on the past are very similar in guage size and insulation size.
you prolly didint open the steering wheel shroud like i did to access to top end of the harness.
Old 01-18-2005
_Viper_'s Avatar
Wow man looks hella tough wow
Thanks
alot
_Viper_ is offline
Old 01-19-2005
Senior Member
profuse007's Avatar
its all about find wires and connecting them together
here are some of the things you need to remember. these task takes practice and self torture when you first beginnin to install car alrm/RS this honda is quite simple compare to the others. as long as you read it several times and ask what you need to ask, anyone can DIY this.
Old 01-19-2005
R1Style's Avatar
can you clearify where exactly you would find each harness/wire?
R1Style is offline
Old 01-19-2005
HomerSimpson's Avatar
excellent work!
HomerSimpson is offline
Old 01-19-2005
THE FIRST LETTER!
ALPHSTER's Avatar
ALPHSTER has disabled reputation
Had one installed on the wifes Highlander. They came to my job and installed it in the parking lot. It took about 3-4 hrs. Best investment ever! Now my wife and kid won't freeze anymore waiting for the car to warm up.
The damn thing can start the car 1000 ft. away. Good when you are at the mall. By the way you still have to insert the key in the ignition and unlock the car with the remote (car stays locked while warming up). If you forget you started the car it will shut down by itself in15 to 20 min. It will also shut down when you press on the brake if the key is not in the ignition in case some a$$hole tries to jack your $hit.
All and all pretty good stuff I hope you enjoy yours.
ALPHSTER is offline
Old 01-19-2005
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
i will see if i cant add this to the DIY sections...
Injen
injencivic is offline
Old 01-19-2005
injencivic's Avatar
I added it to the electronics section on the DIY pages...
Injen
Old 01-19-2005
Senior Member
profuse007's Avatar
yeah, keep it to the DIY section, i know someone will find it useful and save some money. best alarm DIY i couldve done. best thing about it is that DEI makes a whole bunch of variation brand but same diagram.
i thot it was very orginze of the DIY. i hope everything in there are well explained.
Old 01-19-2005
Senior Member
profuse007's Avatar
ask me specificly, like the wire on the civic or the alarm?
dont forget to click on the DEI diagram to know which wire is used in the install. theres a legend(key) at the bottom, the red mark is being used in the installation and the optional feature.
NOTE: i only use 1 of the optional feature wire. i used the blue/white -200mA status output. all the other ones are optional, just leave those alone. so this should be easy enough for all noobs.
-someone PMed me about trunk popper addon. you have to use the red/white -200mA channel 2 (-) to trigger the relay that came w/ the trunk popper (assmuning youre using the accord trunk popper). the tutorial do not cover this part.
NOTE: when youre attaching wires to the IGN harness, go to the harness like i showed on the pic (where i black taped) and splice the wire through there.
BTW, for first install, the outcome of the install doesnt have to be that nice like mine....lol.....but after you get everhint working you can go back and fix it to make the underdash look nice.
mjdiaz89
06-21-2016 09:26 PM
OptimisticWay
46
10-15-2015 02:16 PM
mrwhos
08-11-2015 02:03 AM
17
07-23-2015 11:48 PM
EM_WON
07-22-2015 06:49 PM
Quick Reply: DIY: DEI (viper/clifford..) RStart/keyless/alarm INSTALL
