'02 Civic Automatic Transmission Fluid Change
Old 12-06-2004
stratos285's Avatar
stratos285 is an unknown quantity at this point
Does anyone have the directions for changing the fluid in an auto trans? I was told at a local shop that you have to pump out the fluid. Doesn't Honda put a filter in these things?? Thanks for any help. I'm ordering a service manual but haven't received it yet.
stratos285 is offline
Old 12-06-2004
THE FIRST LETTER!
ALPHSTER's Avatar
ALPHSTER has disabled reputation
Make sure you use Honda trans. fluid (Honda said you have to use Honda tranny fluid ). I brought the fluid from Honda and had a lube shop change it. Honda said 3 Qts. I think.
ALPHSTER is offline
Old 12-18-2004
draganjr's Avatar
draganjr is an unknown quantity at this point
Is there a filter we have to change on the auto trans?
draganjr is offline
Old 12-19-2004
NO, unless you like dismanteling the tranny.
gearbox is offline
Old 12-19-2004
Mex
Mex's Avatar
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
the filter is on the drain bolt.. it's a magnet. be sure to clean off all the metal shavings on it.
Mex is offline
Old 12-19-2004
bgoetz's Avatar
bgoetz is an unknown quantity at this point
Its just a bolt that uses a 3/4 drive socket wrench on the side of the tranny. It is a simple task
bgoetz is offline
Xuhme
21
08-07-2023 03:40 PM
mattdoc
03-14-2017 12:10 PM
bsmiley
04-27-2015 01:27 PM
alexkharden
04-23-2015 07:13 PM
Richkid23
04-19-2015 12:53 PM
Quick Reply: '02 Civic Automatic Transmission Fluid Change
