how to do oil change?
Old 11-01-2004
deploy,engage,destroy.. to fail is not an option
thrash_273's Avatar
thrash_273 is an unknown quantity at this point
can someone tell me how to do proper oil change? i wana do it myself.. what oil should be use, i know its dot 3 but i wana know some good and reliable source. tHANks!
thrash_273 is offline
Old 11-01-2004
tacheon's Avatar
tacheon is on a distinguished road
If you "know" that you're supposed to use dot 3 to do an oil change, I'd seriously take it out to get done if I were you. Dot 3 is a grade of brake fluid. If you used it for an oil change, you're going to destroy your engine. Do a search on this website or buy yourself a service manual or you'll destroy your car. You need to buy 3 things. 1. an oil filter, 2. 4 litres of 5w-20 oil, 3. a drain plug washer.
tacheon is offline
Old 11-01-2004
Broken Arm, How Am I Suppost To Shift
down_'s Avatar
down_ should not be trusteddown_ should not be trusteddown_ should not be trusted
just take it to the dealer. ...see thread oil change's
down_ is offline
Old 11-02-2004
streetglower's Avatar
you need 4 quarts of oil, not 4 liters.
streetglower is offline
Old 11-02-2004
tacheon's Avatar
Oil is sold in litres in Canada, hence the litres. You won't need all of it.
tacheon is offline
Old 11-02-2004
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
4qt = 4.2l. 4 liters will do fine.
as far as how to change the oil. my summary, even though there is a diy, but im not gonna link to it since i disagree with it.
run car to operating temperature, or at least untill the needle is above the cold mark.
put car on ramps, jack it up, whatever you want. shut off car, open hood, unscrew oil cap a little.
go under car. get 17mm wrench, preferably 6 point if you have it so theres less chance of chewing up your plug if it slips or something.
find oil pan. silver aluminum rectangle on my ex. it says OIL PLUG with an arrow, or something similar to that. not brain surgery. remove drain plug. drain oil.
and what i personally do is i jack my car up to get under it and remove the drain plug, then i lower the car to let it drain, when i see its done, i jack it back up.
clean drain plug, replace drain plug washer. its a very very cheap part, no excuses for not replacing it. clean off drain plug hole, replace plug. im sure theres a torque value for the plug, but i just tighten it until its snug.
look straight up from drain plug. find oil filter. unscrew oil filter slowly until oil starts coming out of it. put drain pan underneath until its done. (theres cleaner methods, some people have cut milk jugs, etc so that it doesnt drip down, but this is just how i personally do it.)
when the oil is done dripping down from filter. remove filter. wipe off filter mount where the gasket seals onto the block.
open new filter. pour very very small amount of fresh oil into fresh oil's bottle cap. dip finger into cap. lubricate new filter gasket. (im **** about contaminating my fresh oil so i dont dip my finger into the fresh quart.)
optional: pour small amount of oil into filter before reinstalling. since this is your first time, id just install the filter dry, with no oil.
screw filter onto filter mount. watch for when filter gasket makes contact with engine block. after the gasket makes contact, continue screwing filter on anywhere between 1/2 turn to 1 full turn. use writing/graphic on filter as a guide.
fill engine with proper amount of oil. your done. run engine. shut off engine. wait 3 minutes. check dipstick level.
*just realized you have an 04, this write up is for an 03, but im sure its still the same.
*recommended oil. pennzoil 5w-20 for conventional. motorcraft 5w-20 syn blend. red line 5w-20 synthetic, mobil1 0w-20 synthetic.
ctx66 is offline
Old 11-02-2004
gotti's Avatar
^ good instructions. I've never changed my washer tho :/
gotti is offline
Old 11-02-2004
ncirom2003's Avatar
and many people do this but... DONT REV YOUR CAR ONCE YOUR DONE AND STARTED UP! alot of people will do this cus there happy so they rev it for whatever reason...well you have a couple seconds of a time period before the oil gets in through the filter and fills up the filter..these couple of seconds you can score your cylinder walls and a bunch of other nasty things
ncirom2003 is offline
Old 11-02-2004
thrash_273's Avatar
thanks for help bro.. thanks for replies...
Old 11-02-2004
Honda > Nissan
xian's Avatar
xian is on a distinguished road
Fyi guys, you don't need to use 5W20. Feel free to use 5W30 as it will not harm your engine, actually 5W20 will as its a thinner oil.
Just do a search around. In Asia they actually recommend 5W30 for our cars. In North America 5W20 is recommended so that it passes emissions with flying colours.
But the bottom line is that 5W20 or 5W30 is safe for your car...just use the search button.
btw, ctx66 very nice DIY!!!
xian is offline
Old 11-02-2004
thrash_273's Avatar
thanks for tip bro.. i'll change it myself this thursday..
Old 11-08-2004
bradmanuwf's Avatar
bradmanuwf will become famous soon enough
dude, you are a senior member and didn't know how to change your oil. That's really messed up. I think the way that people get these labels is all screwed up. Cause I have seen lots of posts by diamond members asking about common sense things that I knew when I was 15 years old. Ok, I am done venting now.....lol Good instructions though ctx66. senior and diamond members that don't now anything about cars can definitly use them.
bradmanuwf is offline
Old 11-08-2004
mikenam's Avatar
mikenam is an unknown quantity at this point
i know its a kinda old thread but i will reply by saying read the manual. man read the honda civic manual. It covers most of the basic maintence routines and tells u wen u should do them.
mikenam is offline
Old 11-08-2004
mikenam's Avatar
oh and also i use 3qts of 0-20 mobile one. my friends all say 3 qts isn't enough. i thought 3qts isn't enough either but wen ever i check the dipstick its perfect. saves me a lil bit of money.
mikenam is offline
mattdoc
03-14-2017 12:10 PM
gearbox
Electrical DIY
72
11-27-2015 08:13 PM
BootyDo
05-07-2015 04:46 PM
SoNiCcIvIc
03-11-2002 03:37 PM
AnotherDopeStyle
01-05-2002 03:10 PM
Quick Reply: how to do oil change?
