Hi-milage cars. Who's got 100k miles +
Old 12-06-2009
  #211
andrew_pelkey06's Avatar
andrew_pelkey06 is an unknown quantity at this point
Re: Hi-milage cars. Who's got 100k miles +
i got 292,000 sitting on my 1997 civic and it still running great
andrew_pelkey06 is offline
Old 12-11-2009
  #212
SlimmKidd's Avatar
SlimmKidd is an unknown quantity at this point
242,867 km as of today 02 vic still get 650-680 per tank
SlimmKidd is offline
Old 12-13-2009
  #213
aircooledjames's Avatar
aircooledjames is an unknown quantity at this point
I probably have the sickest mileage number and not in a good way. 05 civic VP coupe 130k. I drove the hell out of it. Bought it brand new. NO major problems, except for cracked exhaust manifold, nothing a cat delete header couldn't fix.
aircooledjames is offline
Old 12-13-2009
  #214
imdstrbd's Avatar
imdstrbd is an unknown quantity at this point
Man I guess I dont drive mine enough. I have a 98 ex with just barely hitting 96k miles
imdstrbd is offline
Old 12-14-2009
  #215
6thgencivic908's Avatar
6thgencivic908 is an unknown quantity at this point
ive got 165k on my 00 lx , i drive on the rougher side, but i do all the maintenence and upkeep a little earlier than normal. ie oil 2500mi, sparkplugs once a year(at least check them) and so on...
6thgencivic908 is offline
Old 12-14-2009
  #216
i had the same thing with the cracked manifold, i pulled off the heatsheild to take the old header off and there was a large crack goind right down the split of 2 and 3 going to the o2 sensor
Old 12-15-2009
  #217
Yeah it's pretty much bullshit. Honda knew there was a major design flaw with the crappy manifold welds, yet they continued to use the stupid manifold/cat combo (dx/lx). A new one from the stealership is about $700, which i think is ridiculous. They should have just kept the cat and manifold separate like the ex.
Old 12-15-2009
  #218
Justinsn95's Avatar
Justinsn95 is an unknown quantity at this point
I had a Del Sol that had 355k on it, and it was still going strong when I sold it. Right now I have a 1997 civic ex coup, (automatic) with 245k on it. It gets kinda bad mileage for a honda though, imo. It only gets about 26-27 mpg city. I know that's a lot of miles on the clock but my buddy's 96 civic gets 29-30 mpg city.
Justinsn95 is offline
Old 12-15-2009
  #219
for less than $700, you can convert to a full ex exhaust system, just look for used junkyard parts or ebay.
gearbox is offline
Old 12-15-2009
  #220
Payloader's Avatar
Payloader is an unknown quantity at this point
I run a '98 DX hatch with 298 000km or 185 000 miles with no problems, no burning oil.
Payloader is offline
Old 12-17-2009
  #221
PoorFashionista's Avatar
PoorFashionista is an unknown quantity at this point
179,500-ish on my '91 but that shouldn't surprise anyone. Just got it so can't say how it's held up, other than it's good now. Except the hood release isn't working so can't see my engine. Can't check the oil. Better go back to the place from whence it came and complain. Hopefully they'll fix it no charge but considering what I paid, they'll probably want money.
PoorFashionista is offline
Old 12-23-2009
  #222
wardhaines's Avatar
wardhaines is an unknown quantity at this point
2002 ex with 248,000 because of a 112 mile commute.
I change oil every 5k
I have replaced:
cat because of weld cracks- Started cracking at about 30k miles and replaced the header at the same time (just because).
Alternator
Thermostat
Timing belt/water punp at about 180k
Clutch at the same 180k
I am pretty sure the head gasket is leaking and causing a loss of coolent through the overflow bottle.
wardhaines is offline
Old 12-24-2009
  #223
civic dewey's Avatar
civic dewey is an unknown quantity at this point
I have 187k + on my 96 civic ex coupe still running strong.
civic dewey is offline
Old 01-18-2010
  #224
dagua002's Avatar
dagua002 is an unknown quantity at this point
Originally Posted by MarkM01
Just turned 100k miles on my '01. Not one problem. Still running the stock battery.
Best milage was about 450 miles on one tank. I've never had it go under 400 miles to the tank, even hauling 4 people.
Anyone else have a hi-milage 7th gen?
i have a '00 6th gen. but how the hell do you get 400 miles per tank. the most i've gotten is 320miles. any advice on how to gte more milage?
dagua002 is offline
Old 01-18-2010
  #225
2k1_Toaster's Avatar
2k1_Toaster will become famous soon enough
With me driving like a bat out of hell, I can get 360mi a tank easily. Driving cross country at 80mph I get between 420 and 460 a tank.
If you are only getting 320, then either you arent using all your fuel before you fill up, or something is seriously wrong!
Also my front struts are leaking so my mileage should be less.
2k1_Toaster is offline
Old 01-19-2010
  #226
dagua002's Avatar
oh thats highway miles, how many miles do you get in the city per tank?
dagua002 is offline
Old 01-19-2010
  #227
In the city, 360mi per tank driving crazily.
I also do deliveries 5hours a day, so I do lots and lots and lots of stop and go, hard accelerations, and so on. Driving like this I get 360mi before I have to fill up. I generally fill up around ~340mi on the trip and usually it is 11.5xx gallons in.
There have been times where my trip odometer is at 380ish and I know I am just burning what is left in the lines because the tank has to be empty at that point lol. Always scary when you fill up your 12gallon tank with over 12 gallons of fuel.
Also the type of fuel makes a big difference. I ONLY use Shell or PetroCanada Premium. 91 in the states (at 6000ft-9000ft altitude so, "equivalent" of ~93octane) and 94 in Canada. When gas lept up to $2.30/gal and I was positive I would never pay that, I used generic gas. This ate my mileage like none other, and endup up costing more. So even through the $4/gal periods I used Shell's premium and it is worth it everytime. And if the marketing hype about it cleaning your engine junk is true, then sweet. But I do it for the mpgs...
Old 01-19-2010
  #228
dagua002's Avatar
so what would you reccommend i do to get my mpg up?
dagua002 is offline
Old 01-19-2010
  #229
What type of gas do you use?
Also I am sure there are differences between the 6th gen 00 and 7th gen 01, maybe efficiency is one of them?
Old 01-19-2010
  #230
dagua002's Avatar
i use regular lol i believe its 87
dagua002 is offline
Old 01-19-2010
  #231
Regular is 85 around here, and I have seen 83 in some pumps accross the US.
Use some good Shell gas 91/93 and see if that helps.
Old 01-19-2010
  #232
Silver96_D61Y8's Avatar
Silver96_D61Y8 is an unknown quantity at this point
I have a 6th Gen with 237,000+ on it and I get any where from 380-410 miles per tank depending on how I drive.
Silver96_D61Y8 is offline
Old 01-19-2010
  #233
shwoogie420's Avatar
shwoogie420 is an unknown quantity at this point
i have a 02 civic with 135k...... boosted 15psi all day...i beat the **** out of it and never a problem
shwoogie420 is offline
Old 01-25-2010
  #234
nk7
nk7's Avatar
nk7 is an unknown quantity at this point
312,xxx on my 01 civic. Just recently had the trans rebuilt. other than that runs like new
nk7 is offline
Old 02-11-2010
  #235
loboelprofugo's Avatar
loboelprofugo is an unknown quantity at this point
mines has 168469 so i guess i win lol, i havent done much in term of mecanic to my car...just brand new head since my car over headed and head warped ( good thing for dealer ship warranty) radiator, termostat, regualr maintanence and thats bout it. and my car is still runnin like new...dont u love hondas? lol
loboelprofugo is offline
Old 02-11-2010
  #236
Maple50175's Avatar
Maple50175 is an unknown quantity at this point
I have 233,000K Miles & Boosted 8PSI
teehee
Maple50175 is offline
Old 02-11-2010
  #237
juannyboy's Avatar
juannyboy is an unknown quantity at this point
125k on my 04 civic lx. If you're wondering I put maybe 5,000 of those miles onto it
juannyboy is offline
Old 02-11-2010
  #238
tehstriker88's Avatar
tehstriker88 is an unknown quantity at this point
i gots 197,000 kilometers on my 01
tehstriker88 is offline
Old 02-12-2010
  #239
geetee03's Avatar
geetee03 is an unknown quantity at this point
Also the type of fuel makes a big difference. I ONLY use Shell or PetroCanada Premium. 91 in the states. When gas lept up to $2.30/gal and I was positive I would never pay that, I used generic gas. This ate my mileage like none other, and endup up costing more. So even through the $4/gal periods I used Shell's premium and it is worth it everytime. And if the marketing hype about it cleaning your engine junk is true, then sweet. But I do it for the mpgs...
You've actually wasted a ton of money, higher octane does not equal better gas mileage. Higher octane is less combustible than regular. Boosted and high compression motors require premium to avoid pre-ignition.
geetee03 is offline
Old 02-12-2010
  #240
Trance Addict
MelJ's Avatar
2000 Si. Almost 130k. Love this car so much. Besides the POS Valucrap battery I replaced with something much better, she runs well.
MelJ is offline
Quick Reply: Hi-milage cars. Who's got 100k miles +
