Go Back   Honda Civic Forum > GENERAL > General Honda Civic Forum Archive.
Register Forgot Password?
Register Photo Gallery FAQ Members List Search Today's Posts Mark Forums Read Experience GarageVendors TSB & Recalls
Welcome to Honda Civic Forum
LinkBack Thread Tools Search this Thread
Old 09-19-2004   #1 (permalink)
Arlof is an unknown quantity at this point
Pinout For 14 Pin Connector On Stock HU
I'm looking for someone with a Helm's manual that would possibly have the pin out's for the stock headunit cd changer input. I believe it's 14 pins.
Regards,
David
Arlof is offline
Old 09-19-2004   #2 (permalink)
Got Boost???'s Avatar
Images: 36
Got Boost??? has a brilliant future Got Boost??? has a brilliant future Got Boost??? has a brilliant future Got Boost??? has a brilliant future Got Boost??? has a brilliant future Got Boost??? has a brilliant future Got Boost??? has a brilliant future Got Boost??? has a brilliant future Got Boost??? has a brilliant future Got Boost??? has a brilliant future Got Boost??? has a brilliant future
Send a message via AIM to Got Boost???
I believe this is it
Click the image to open in full size.
1 - Yellow/Green - Antenna Modeule (coupe only)
2 - Yellow/Red - ACC (Main stero power supply)
3 - NOT USED
4 - NOY USED
5 - Pink - Right rear speaker (+)
6 - Blue/White - Left rear speaker (+)
7 - Green/Yellow - Passenger door speaker (+), right tweeter (+) couple only
8 - Green/Black - Drivers door speaker (+), left tweeter (+) coupe only
9 - Red/Black - Lights-on signal
10 - White/Red - Constant power
11 - NOT USED
12 - NOT USED
13 - NOT USED
14 - NOT USED
15 - Blue/Yellow - Right Rear speaker (-)
16 - Blue Black - Left Rear speaker (-)
17 - Grey/Red - Passenger door speaker (-), right tweeter (-) couple only
18 - Light Green - Drivers door speaker (-), left tweeter (-) coupe only
19 - Red - Dash Lights Brightness controller
20 - Black - Ground (G503)
this is from the honda service manual
Got Boost??? is offline
Old 09-19-2004   #3 (permalink)
Images: 36
heres a more colorful picture
Old 09-20-2004   #4 (permalink)
Hrm Thats not it the one I'm looking for...
It's 14 pins and it's the CD Changer Input into the head unit. I believe what you have listed here is the head unit's main connector. But I might be wrong can you just confirm that thats infact the CD Changer Pin Out Boost?
Thanks for your time.
Arlof is offline
Old 09-20-2004   #5 (permalink)
Images: 36
yeah i thats the main head unit.
But by CD changer do you mean an extrenal one?
Old 09-20-2004   #6 (permalink)
Images: 36
Ok I know what your talkins about now. However its not covered in the Honda service manual (odd considering its 3 inches thick)
But Im gonna keep searching this for ya
Old 09-20-2004   #7 (permalink)
Well, I haven't had much luck so, I hope you have better luck. I've found it listed as a bus cable on the installation instructions for the cd-changer.
Arlof is offline
Old 04-28-2005   #8 (permalink)
P64
P64 is an unknown quantity at this point
This is the board of an european Pioneer-made HU. Everything is marked on it. So if you believe that yours is different, take it appart and compare.
1 BU
2 SWDACC
3 GND
4 SGND
5 RP
6 LP
7 BU
8 ILM
9 BUSP
10 BUSM
11 GND
12 NC
13 RM
14 LM
Oh by the way, how do I enable the AUX function? I want to connect an Ipod.
Have a nice day.
ID:	52727   Click image for larger version
P64 is offline
Old 11-27-2006   #9 (permalink)
adrianpglover is an unknown quantity at this point
I'm wondering if you were able to get this to work or not. I'm about to order the cable required and try testing some things out myself. I suspect you have to jumper either pins 1 and 7, 9 and 10, or 2 and 4. I have a strong suspicition that it is one of the first two combinations. If i get anything I'll let you know sometime next week.
adrianpglover is offline
Old 11-27-2006   #10 (permalink)
christmaspie's Avatar
Points: 8,964, Level: 63
Points: 8,964, Level: 63 Points: 8,964, Level: 63 Points: 8,964, Level: 63
Level up: 72%, 86 Points needed
Level up: 72% Level up: 72% Level up: 72%
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Images: 5
christmaspie is a glorious beacon of light christmaspie is a glorious beacon of light christmaspie is a glorious beacon of light christmaspie is a glorious beacon of light christmaspie is a glorious beacon of light christmaspie is a glorious beacon of light
The following info is from an 05 Accord but I think it'll be pretty close.
01 - 12V constant
02 - accessory
03 - ground
04 - ground
05 - Right Channel (+)
06 - Left Channel (+)
07 - 12V constant
08 - illumination (+)
09 - BUS (+)
10 - BUS (-)
11 - ground
12 - illumination (-)
13 - Right Channel (-)
14 - Left Channel (-)
Have fun...
__________________
MECP Master
ASE Electrical
Tech Support Specialist
Directed Electronics
christmaspie is offline
Old 04-22-2009   #11 (permalink)
nemiath is an unknown quantity at this point
Re: Pinout For 14 Pin Connector On Stock HU
Quote:
Any luck activating the aux in ? Any tips you can provide since i been trying to do the same thing for my civic?
nemiath is offline
Old 04-22-2009   #12 (permalink)
Points: 5,494, Level: 47
Points: 5,494, Level: 47 Points: 5,494, Level: 47 Points: 5,494, Level: 47
Level up: 72%, 56 Points needed
Activity: 0%
mdawg is on a distinguished road
I'm gonna bump this too, untill I get my carpc back into this car I need some aux in haha.
__________________
New Ride:
2k1 EM2 Coupe EX 5 Speed
Current Project:
CarPC
Xenarc 700TS 7" Touchscreen
1.2Ghz Celeron
Asus Mobo
512mb Memory
120GB HD
150wat PS
Custom Built Startup/Shutdown Controller
mdawg is offline
Old 06-12-2009   #13 (permalink)
Points: 2,953, Level: 33
Points: 2,953, Level: 33 Points: 2,953, Level: 33 Points: 2,953, Level: 33
Level up: 36%, 97 Points needed
Level up: 36% Level up: 36% Level up: 36%
Activity: 2.6%
Activity: 2.6% Activity: 2.6% Activity: 2.6%
bmnot will become famous soon enough
BUMP
So I would totally rather wire up my own 1/4" jack as aux instead of buying an aux unit.
Does anyone have confirmed details on what to jumper and what to wire into for the audio?
(7th gen 2005 civic btw)
edit:
similar to what this guy did on his mazda: http://www.geocities.com/blhobbs.rm/...o_details.html
bmnot is offline
Old 06-12-2009
CivicForums
Honda Civic
Paid Advertisement
Tags
14 , 2005 , accord , cd , changer , civic , connector , em2 , head , honda , jumper , pin , pinout , pinouts , setting , unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dictionary Of Automotive Terms
60,000 mile Transmission fluid change
Looking for a 7th gen manual for free? (UPDATED!!!)
SOHC VTEC Explained
AC Recharge kit overcharged my system! What now?
ALL of Grey's DIY's...
Oil Changes
Detailed smoked out taillights DIY w/ pictures
Removing door panel from a 2002 civic
Automatic Transmission Flush
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Emails Backup
