ground control replacement parts
Old 11-29-2001
my2k1vic's Avatar
my2k1vic is an unknown quantity at this point
I just called to get my replacement parts for the ground control coilovers. What sucks is that GC isn't going to cover the $70 dollers that it is going to cost me to re-install the rear coilovers. They said that they give out the directions to install them and therefore I chose to get them installed and not do it myself. Should I install them myself or pay the $70 to get them re-installed?
my2k1vic is offline
Old 11-29-2001
LuvMyCivic's Avatar
LuvMyCivic is an unknown quantity at this point
The rear ones are pretty easy to do yourself. I posted a DIY for the coilovers about 3 or 4 days ago in this forum.
http://www.2k1civic.com/forum/messag...threadid=17084
The only tool you need that you might not have is a spring compressor, but you can get those relatively cheap. Good luck, however you choose to take care of the problem.
LuvMyCivic is offline
Old 11-29-2001
0100010's Avatar
0100010 is an unknown quantity at this point
Do you already have your GC's installed? Cause if you already do, then you don't need anyone to install them for you, or a spring compressor. Just some time to do it yourself. If you still have your stock springs on, then either pay someone to do it for you, or you will need the spring compressor to do it yourself.
0100010 is offline
Old 11-29-2001
rhyno's Avatar
rhyno is an unknown quantity at this point
yeah, the rear is ral easy. you could have them off and on in about 45 minutes assuming they have already been installed once before. what are you having to replace??
rhyno is offline
WorldsSlowestEm2
11-27-2001 07:25 PM
1028CiViC
11-27-2001 02:45 PM
1028CiViC
11-24-2001 02:14 PM
duyaknow
11-23-2001 07:28 PM
TOOLOWCIVIC
11-18-2001 10:17 AM
Quick Reply: ground control replacement parts
