removing headlights
Rep Power: 0 removing headlights
does anyone have a detailed version of removing ur headlights??
or where i can find one..?
and do u need to remove ur front bumper to remove ur headlights?
Thanks-In-Advanced.
Yang
Thanks-In-Advanced.
Yang
www.ImportFactor.Com
Rep Power: 0 No you dont need to remove the bumper to get to them. Look in your manual it says it detailed with pics inside of it...Don't people ever read their manuals any more?!?
Rep Power: 0 Well now that all depends on whether you just want to change bulbs, or remove the whole assembly. There is a light clearing and bumper removal DIY in the DIY section.
Rep Power: 559 Do you want to take the bulb out? thats easy.
taking out the whole assembly does require takeing the bumper off. the DIY couldnt give any more explanation. which makes that easy too
Rep Power: 0 You don't have to remove the whole bumper!! I have removed my headlights several times this is how: first remove a philips screw from each front wheel well. then remove 4 plastic clips above the front upper grill. then carefully pull the bumper forward letting it hang down. be careful not to scratch anything. then look for 4 bolts on each headlight, 2 on top, 1 on side, and 1 on front. the front one you will need a pretty long extension. you should be able to do this in about 10-15 minutes if you are good with tools. I hope this helps, later.
Whachya lookin at?
Rep Power: 288 Re: removing headlights
I think you just set the record for the oldest revived thread. A whopping 9 years... or close to it anyways.
Congrats
Now, to make up for it, make your own thread with some pictures!
Congrats
Received 1,144 Likes
Rep Power: 485 Re: removing headlights
I was in my senior year of high school driving a 1992 Toyota Paseo when this thread was done and over with..
07-12-2015 11:54 AM
OptimisticWay
07-10-2015 04:31 PM
ballmich
07-09-2015 11:59 AM
