timing belt broke! what to do!
Old 03-05-2004
jonny9508's Avatar
jonny9508 is an unknown quantity at this point
Angry timing belt broke! what to do!
My timing belt broke. My dad an i have gotton a new one on. but i can't seem to get it time just right. I know i have to have the cam shaft at tdc. The cam gear has up on it so i can figur that one out. but it is the crank shaft that i just don't know. Of course i have an rvm crank pulley on so i can see any the one the outside. If i take it off. Not all the way just the bolt so i can see the carter key would i have that one facing up as well to have it time? I need input asap. I have no car
jonny9508 is offline
Old 03-06-2004
I R T3H 1338
auto84's Avatar
auto84 will become famous soon enoughauto84 will become famous soon enough
if its still under warranty id have honda fix that s**t.
auto84 is offline
Old 03-06-2004
Not sure, but I think the piston or something has to be in the center when you remove sparkplug #1 and look inside.
gearbox is offline
Old 03-06-2004
manu's Avatar
manu is an unknown quantity at this point
hey Jonny9508 i just looked at my civic service manual , and if u had one it would help you but im not sure what ur problem is . But i think that this might help u , this it what it says "To set the crankshaft to TDC , align the TDC mark on the timing belt drive pulley with the pointer on the oil pump" the pointer on the oil pump is like a little arrow thing. I dont know if that is what u were looking for or not but I'll check this thread back tomorrow and see if i cant help u a little more , cause everything u need is in the manual . bye
manu is offline
Old 03-06-2004
I love my Honda
D17a2-EM2's Avatar
D17a2-EM2 is an unknown quantity at this point
Correct, look at your oil pump.
There should be a mark.
If anything call up Honda, ask for a service tech.
D17a2-EM2 is offline
Old 03-06-2004
sw388integra's Avatar
CHECK THE HEAD BEFORE PUTTING THE BELT ON!!!!!!! my brother broke his while driving and it bent some valves and it wasn't much of a bend either...just a thought...we had a hell of a time getting it started and we finally took the head off and got it looked at and 2 valves were bent... you can check by taking the head off and spraying wd-40(or gasoline) in the valve pockets and seeing if it drips through to the other side
sw388integra is offline
Old 03-06-2004
Project2k2's Avatar
It would be a good idea to check the rest of your engine. I'd take it to Honda and have them figure their own mess out.
Project2k2 is offline
Old 03-06-2004
jonny9508's Avatar
I have a rvm crank pulley and of course it doesnt have any marks on the pulley. what service man do you have? I have looked at 5 diffrent stores for one.
Old 03-06-2004
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
when should you start changing your belts?
Injen
injencivic is offline
Old 03-06-2004
Jeff's Avatar
Jeff is an unknown quantity at this point
You need to either a buy the service manuel from
http://www.helminc.com or go to your honda dealer and ask to see the manuel. It tells you step by step on how to remove and to install a new belt. I would scan mine in for you but its over 7 pages.
Jeff
Jeff is offline
Old 03-07-2004
civicstreetrcr's Avatar
civicstreetrcr is an unknown quantity at this point
Scan It for him I will paypal you 2 Bucks....Any More Donations For Him to scan I mean everyone can use that info
civicstreetrcr is offline
Old 03-07-2004
Injen
75,000 miles
Old 03-07-2004
sakabatou's Avatar
sakabatou is an unknown quantity at this point
You can’t just do it your self for one thing when a belt brakes it puts your timing all off. If you try to start your car without having the right timing you will bend valves or worst. Sorry man, if your timing belt is under warranty or less than 100,000km have Honda fix it. Put back your old pulleys.
sakabatou is offline
Old 03-08-2004
Support your local 81
bhaz413's Avatar
Location: In the land of milk and butter, Massachusetts, US
bhaz413 is an unknown quantity at this point
Injen
i changed my timing belt at 110k miles. let just say it wasnt hard, just time consuming because it is real tight to get in there. Took me 12 hours w/ 2 people.
bhaz413 is offline
Old 03-08-2004
djmota's Avatar
how many miles did you have on your engine when it broke?
djmota is offline
Old 03-09-2004
Your Parts Guy
StreetLevelPerformance's Avatar
StreetLevelPerformance is on a distinguished road
When changing a timing belt the pulley should be removed so it doesn't matter if there are marks on it or not. You need to look at the mark for the crank and line it up, then line up the cam gear to TDC. Put the belt on and tighten the tensioner. Double check to make sure the cam gear is still at TDC and the crank is too. Be patient it is not easy to get it right the first time. Oh and please check the head for bent valves, you wouldnt want to have to take it all apart again.
StreetLevelPerformance is offline
Old 03-09-2004
Your Parts Guy
There are marks for the cam gear and crank for TDC you don't need to check the #1 cylinder piston position.
Old 03-09-2004
87carrera's Avatar
87carrera is an unknown quantity at this point
if it broke, my advise is repair it
87carrera is offline
Old 03-09-2004
JayFReaZy's Avatar
when you had to replace the belts, did you have to take off your front bumper? Or were you able to work with just taking off the driver side front wheel, and the covering for the pulley?
JayFReaZy is offline
Old 03-10-2004
bhaz413's Avatar
ok here is what you have to remove.
jack up the driver side car, make it secure. remove wheel
remove junk on top and around valve cover
remove valve cover
unbolt and push out of the way the power steering pump
remove alternator
remove the dust shields for the water pump and cam gears
jack up engine a little
remove driver side motor mount bracket
set TDC,
loosen the crank pully bolt
set tdc again
remove the tensionor
remove the crank pully (there is a small key that is in it, dont loose it)
at this time remove the water pump and repalce it, the tensionor will need to be replaced as well.
re-assemble in reverse order, tq everything to spec, and youi are golden.
bhaz413 is offline
Old 03-10-2004
phatcyclist's Avatar
phatcyclist is an unknown quantity at this point
people are all talking about bent valves.... but honda grooves the tops of the pistons so that if you DO break the belt, it wont mess up your engine, so you really shouldnt worry about it. Now if you drove a mitsubishi, it would be a completely different story.
phatcyclist is offline
Old 03-10-2004
orso's Avatar
orso is an unknown quantity at this point
ok well if you can not see the marks on the pulley or oil pump etc... then you need to take out the spark plugs. get a long screw driver and stick it in the #1 cylinder and rotate the crank counter clockwise until the screw driver stops going up. then you should be at TDC. it may take you a little while to get it dead on but this is how me and my friend put is on.
orso is offline
Old 03-10-2004
JayFReaZy's Avatar
hey jonny9508, just wondering, how many miles did you have on your car before the belt broke?
Old 03-10-2004
Just Be
MangoEX's Avatar
MangoEX should not be trusted
always know what your oding before attempting something w/ that level of seriousness
MangoEX is offline
Old 03-10-2004
02ciVike's Avatar
02ciVike is an unknown quantity at this point
Move the car onto the road. Call the automobile club (AAA) if you are a member. Get the car flat bedded to the nearest Honda service center. Say that it happened while driving and have them fix it under warrenty. Hide any evidence of you tampering with the car (don't mess with things you don't know).
02ciVike is offline
Old 03-25-2004
MarkM01's Avatar
MarkM01 is an unknown quantity at this point
Can we get an answer to this please?
MarkM01 is offline
Old 03-25-2004
JimTruett's Avatar
JimTruett is an unknown quantity at this point
That is not totally true. Most Honda engines (B and D series especially) will bend valves when the belt breaks.
JimTruett is offline
Old 01-06-2005
stylin2k1's Avatar
stylin2k1 is an unknown quantity at this point
timeing belt
change it
stylin2k1 is offline
Old 01-06-2005
opto_isolator's Avatar
Originally Posted by stylin2k1
change it
WTF? You revived a 10 month old thread to say nothing?
What a waste....
opto_isolator is offline
Old 01-06-2005
Senior Member
profuse007's Avatar
profuse007 is an unknown quantity at this point
i guess this model of honda is the first to have the non-interference then.......
profuse007 is offline
mattdoc
03-14-2017 12:10 PM
EdGasket
05-25-2015 01:06 PM
MN-02-CivicEx
28
05-02-2015 09:11 PM
dano2005
04-14-2015 01:58 AM
Gunner
Engine DIY
10-06-2012 12:37 PM
Quick Reply: timing belt broke! what to do!
