Can i change oil filter without changing oil
Old 08-11-2003
manu's Avatar
manu is an unknown quantity at this point
Hey whats up guys . Alright last night i changed my oil but i had the wrong filter so i had to leave the filter i had on . Now that i have the right filter , can i change the filter without changing the oil ? Cause i dont know that if i take the filter out with the oil still inside the engine , if the oil is just gonna come out the oil filter hole or not . thanks for all the help.
manu is offline
Old 08-11-2003
Samoan<^>(-_-)<^>Power
krayziebonet4l's Avatar
krayziebonet4l is an unknown quantity at this point
you can, some oil WILL come out. the filter is positioned on the block and not the oil pan, so all of the oil is below the filter
krayziebonet4l is offline
Old 08-11-2003
A descendant of 2k1civic.com
pheaton's Avatar
yeah .. it'll be okee .. just make sure to check your oil afterwards though . You might loose some. . Not too much though. .
pheaton is offline
Old 08-11-2003
Unleaded's Avatar
Unleaded is an unknown quantity at this point
if it were me, i'd change the oil again even if it was 1 day old. new oil + dirty filter = dirty oil.
Unleaded is offline
Old 08-11-2003
civic01vtec's Avatar
i agree
civic01vtec is offline
Old 08-11-2003
Bellz's Avatar
When you left the old filter in there, it had maybe half a quart in it of dirty oil. As soon as you cranked the car, it circulated that dirty oil with the new oil. But there's not that much oil in the filter. They're really small.
Check the oil with the dipstick before swapping the filter and changing it all over again. If you think it's really dirty, change it and the filter. I doubt the little bit in the filter would justify changing 4 quarts again.
Regardless, if you put a new filter on there, you'll need to add some oil to replace what was in the old filter.
Bellz is offline
Old 08-11-2003
Green Civic's Avatar
^^ Yes, what he said. Im more leaning on just changing everything.
Green Civic is offline
Old 08-11-2003
Cracka
xtiszx's Avatar
xtiszx is an unknown quantity at this point
same here, look at the color of your oil after a day, or a few hr's of drivin, i bet its dirty looking still
id change it all again
xtiszx is offline
Old 08-11-2003
Euro-Spec
tripledoublegs's Avatar
change the oil and the filter again. There was some old oil in the filter and it mixed with the fresh one, so... yeah, change the whole thing.
tripledoublegs is offline
Old 08-11-2003
manu's Avatar
cool
allright guys thanks for all the replys
manu is offline
Old 08-11-2003
opto_isolator's Avatar
Man Honda made those filters a PITA to get off! I remember the first time I changed mine I had to puncture it with a screwdriver just to get leverage - the chain wrench I had kept slipping off......bastards!
opto_isolator is offline
Old 08-12-2003
Woodster's Avatar
Woodster is an unknown quantity at this point
haha, PITA, took me awhile to figure that one out. I would change both the oil and the filter, no point in having a new filter and dirty oil is there?
Woodster is offline
Old 08-12-2003
Renamazazo's Avatar
Renamazazo is an unknown quantity at this point
Am i the only one who thinks this is kinda pointless? If you put in a new filter, it will FILTER out the dirt and contaminants in the oil. The reason why you change the oil, is to put fresh oil in with all of the addatives that come with it. You can just chage your oil filter, without chaging the oil, the filter will get all that crap out of there. Plus, it wasn't very much oil to begin with. Modern Oils are much better then the oils of old... The 3k change limit and such aren't really necessary, if you look in the civic manual is says to change every 10K miles, BUT this is only if your car burns a quart every 3000 miles. (so basicaly you're replaceing your oil at least once before you change it)
I would just like to say once again, it's addatives, that are so important. If the addatives didn't burn off, then you'd basically never have to change your oil.
-Mark
Renamazazo is offline
Old 08-12-2003
I paid too much money for my civ to not take care of it, some of u may flame me for this, but i change my oil every 2,000 miles. Yes, it may be pointless, but for as cheap as an oil change is, i will continue to change it every 2K. As for taking off the filter, yes, it is a PITA. I used a big pair of channelocks to get it off and tightened it by hand when i put it back on. Gotta love engerneering !!!
Old 08-12-2003
Bellz's Avatar
I man-handled my filter off. Fear the bellz death grip!!
Anyway, the fram that I got to replace it with has a non slip edge to it that makes it easier to tighten and easier to break loose. It's #PH7317 if anyone wants to try it.
Bellz is offline
Old 08-12-2003
AudioQuest's Avatar
AudioQuest is an unknown quantity at this point
I think the factory torques the filters on and because of the extended drain intervals now, the gasket really sticks to the block. I sprayed some WD-40 around the gasket, let it sit for 10 minutes and then the factory filter finally came off.
AudioQuest is offline
Old 08-14-2003
old beater's Avatar
old beater is an unknown quantity at this point
you guys know your supposed to put new oil on the rubber seat part of the filter, right. when i change my oil, about every 2500k i pour one quart through the engine to "Wash" out and metal shavings or dirt. i can always get the filter off with my bare hands, i think you guys are doing something wrong if its that hard to get off.
old beater is offline
Old 08-14-2003
Yeah, i always take my finger and rub new oil around the seal to lubricate it. I never did try "flushing" it with new oil though. I don't know if that would do anything or not, maybe it is just personal comfort knowing that u did that.
Old 08-15-2003
old beater's Avatar
well, me and my older brother have the same car (01 ex manual) his is red mine is black. my dad buys oil by the case and we always have one left over so i just got in the habit of doing it. but usually you can see it start out dark and get lighter as you pour it through. so it might do something. you just never know.
RIPSAW
11-06-2015 04:36 AM
Unleaded
06-26-2007 09:25 PM
Grey
16
01-27-2002 11:34 PM
02Si
Bolt-on Engine Performance
01-07-2002 11:35 PM
02Si
01-06-2002 09:18 PM
Quick Reply: Can i change oil filter without changing oil
