Speed sensor location
Rep Power: 0 Speed sensor location
Hey i need to change my speed sensor clip, can anyone tell me where it is? a pic would be very helpful. thx..this is for a 01 civic lx (non-vtec). ps. im new.
Rep Power: 0 no man, not disconnect it. my guages turn off on my..like the needles just drop to 0...the only thing i was told that could fix this is
1) make sure the cluster is plugged in
2) check the speed sensor clip
3) check ecu wires
i have done 1 and 3 and everything is plugged in so the last thing i need to check is my speed sensor clip.
3) check ecu wires
Rep Power: 444 hey mines does the same thing except my cruise control light flickers and everytime it flickers my speedo drops to zero and then will go back to normal then back t ozero again bye they way!!! where is the CLUSTER, SPEED SONSOR CHIP AND ECU WIRES?
Jap-Euro Fusion
Rep Power: 399 I'm guessing here... so if I'm wrong oh well. Lift up the car and look on the back side of the hub on the right front. There's a probe of some sort that is directed at a "gear" that isn't hooked up to anything, but it rolls on the hub. That might be it. Maybe you can trace it back somewhere.
I'm trusting that you're doing this to fix the problem and not creating an illegal one.
1 Post
Rep Power: 286 Are you referring to the VSS(Vehicle Speed Sensor)? If you looking to replace it, its not illegal to. In my Helms manual, it says:
1. Remove the intake resonator.
2. Disconnect the 3P connector from the VSS.
3. Remove the mounting bolt, then remove the VSS.
4. Install the VSS in the reverse order of removal.
From the pic it looks like its on top of the tranny, under the intake resonator.
97-DX-Lover
06-14-2015 06:07 PM
Touge
05-20-2015 10:53 PM
dragonsblood
04-27-2015 12:28 PM
dooner24
04-14-2015 07:51 PM
