Go Back   Honda Civic Forum > OFF TOPIC > Off Topic > Fitness
Fitness A place to discuss topics concerining physical fitness.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 02-22-2007   #136 (permalink)
electric130
I.C.E. Mod
electric130's Avatar
electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned
Quote:
Originally Posted by blouisgod View Post
ths
run 30 mins
did deadlifts again today. i was able to do 3 x 10 with 65lbs! i feel it more in my legs right now than my back. is that normal? it's mainly my hams and glutes. last week, i was on the verge of getting cramps in my upper, outer hams while i doing them. today wasn't that bad. i don't want to push it yet since it's a new exercise for me.
electric130 is online now   Reply With Quote
Sponsored Links
Old 02-23-2007   #137 (permalink)
blouisgod
Life Begins > 6800rpms
blouisgod's Avatar
blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold
Send a message via AIM to blouisgod
yeah its normal to feel it in your legs. once you do them for a little while, youll really start to climb in weight fast. i started at 105 and am at 205 within a month
__________________
2008 ASM Si Sedan w/ Navi and Summer Tires
blouisgod is offline   Reply With Quote
Old 02-23-2007   #138 (permalink)
electric130
I.C.E. Mod
what is the biggest benefactor from dead lifts? legs? back? both? other?
Old 02-23-2007   #139 (permalink)
blouisgod
blouisgod's Avatar
id say depending on if you use your legs, i personally try not to, its great for total legs and lower back, as well as arms, people say. its almost a whole body workout. I see it in traps, arms, lats, and lower back and a whole lot in grip strength too.
friday
smith bench press
135 x 12
275 x 8
275 x 6
275 x 6
palms in smith bench
205 x 8
215 x 8
225 x 6
incline dumbell press
70 x 3 x 8
flat dumbell fly
65 x 3 x 10
seated dumbell curl
45 x 3 x 8
preacher curl
120 x 8
125 x 8
140 x 6 (put 10s on and not 5s like I was supposed to)
8 min sprint.
__________________
Old 02-23-2007   #140 (permalink)
electric130
I.C.E. Mod
how can you avoid using your legs? you have to bend at the knees and squat some to do them correctly, right?
Old 02-24-2007   #141 (permalink)
blouisgod
blouisgod's Avatar
you can, but i just lean over. i think its a romanian deadlift if you use your legs and keep your back straight. im just so tall with long arms that i can get the bar to the floor without bending my legs, i keep them slightly bent throughout the whole motion.
__________________
Old 02-24-2007   #142 (permalink)
robbclark1
Retired suspension supermod.
robbclark1's Avatar
robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold
Send a message via AIM to robbclark1 Send a message via MSN to robbclark1 Send a message via Yahoo to robbclark1
You need to use your legs with a real dead lift. You push off the ground using your feet then pull with your back. The first part of the motion will be upper back and legs. the second part will be mid back and lower back.
YouTube - Deadlift 455 x 15
Straight leg deadlifts your legs should be slightly bent because you don't want to tear your hamstrings or ligaments behind your knee.
YouTube - Romanian Deadlift
YouTube - Romanian Deadlift Demonstration
__________________
Life isnt a test drive, gotta live a little. (02fpcivic)
Suspension FAQ
Autocross FAQ
If you pretend that cars are moving cones, then the roads become your personal autocross course.
I live my life 1 cone at a time, for those 70 seconds or less, I'm free
Thanks to ALPHSTER for the sig!
robbclark1 is offline   Reply With Quote
Old 02-25-2007   #143 (permalink)
blouisgod
blouisgod's Avatar
thanks rob, looks like i use the romanian deadlift.
sat
run 20 mins
tennis/ bball for about an 1.5 hrs
__________________
Old 02-25-2007   #144 (permalink)
electric130
I.C.E. Mod
Quote:
Originally Posted by robbclark1 View Post
that's more of what i'm doing, but i keep my back straighter. of course, i'm not even breaking 100lbs yet.
oh and rob, the pic in your sig doesn't work. i only see a red x.
Old 02-25-2007   #145 (permalink)
robbclark1
robbclark1's Avatar
Yeah I know...I'm too lazy right now to fix it. It worked fine until we switched over to civicforums
Straight legs work hamstrings and lower back. Should be done on leg day.
Full deads work a little legs and all of back, plus some traps. Should be done on back day.
I have learned to really love full deadlifts. They I want to develop my mid back more and they really help. I like them so much better than squats at least in terms of full body lifts. I would highly suggest learning good form and doing them. My grip is limiting me at the moment...time for some wraps or something.
__________________
Suspension FAQ
Autocross FAQ
Old 02-25-2007   #146 (permalink)
blouisgod
blouisgod's Avatar
Sunday, shoulders, elbow tendons hurt so no tris.
Military Press
135 x 10
185 x 6 x 3
barbell raise
135 x 3 x 6
bent over flys
40x 3 x 8
seated side raise
20 x 3 x 8
cable side raise, for rotators
20 x 3 x 8
cable lateral pull down
25 x 3 x 8
abs a lil
10 min run
__________________
Old 02-25-2007   #147 (permalink)
robbclark1
robbclark1's Avatar
getting a little tennis elbow? Maybe time to take a week or so off...
__________________
Suspension FAQ
Autocross FAQ
Old 02-25-2007   #148 (permalink)
blouisgod
blouisgod's Avatar
yeah its been kinda buggin me. i did the preacher curl on this thing where you more so lean over it and your arms are almost perpindicular to the floor. it just didnt feel right. im going to take time off next week, sat im getting a deep tissue massage and will probably be sore for several days from that.
__________________
Old 02-25-2007   #149 (permalink)
robbclark1
robbclark1's Avatar
mmmm massage! drink lots of water before and after.
I feel like I am constantly highjacking your thread, but it is the only one that we talk in...
__________________
Suspension FAQ
Autocross FAQ
Old 02-26-2007   #150 (permalink)
blouisgod
blouisgod's Avatar
ha no problem. your right, its the only one really that we talk in. ill be sure to drink a ton of water, my shoulder blade muscles are killing me... the scapulas i think they are called?
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
my log
Get in shape "Question Thread"
Dymatize Xpand
Tips on gaining weight.
Pre-workout pump
Possible to lose 32 lbs in a week?
Capoeira
Official Get In Shape '06 Thread
Lean-Gainer Meal Plan for those looking to gain weight!
white2K2EX's Doggcrapp log!
Site Supporters
aluminum radiator
Honda car spoilers
