Go Back   Honda Civic Forum > OFF TOPIC > Off Topic > Fitness
Fitness A place to discuss topics concerining physical fitness.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 03-15-2006   #1 (permalink)
D17thgen
Diamond Member
D17thgen's Avatar
D17thgen has a spectacular aura about D17thgen has a spectacular aura about D17thgen has a spectacular aura about
powerlifting technique on bench press
i been lifting for few months working with compound movements like the squat, deadlift, and bench press. i decided to change things up a bit and go for power and speed. today was the first time i ever attempted a power lift style bench press. i warmed up with 115lb doing speed reps, then 135, then bumped it up to 185lb where i did 5 reps of that. i had my hips/butt in the air off the bench like i was humping the sky, supported with the ball/toes of my feet (heels off ground), shoulders stayed on the bench, bar positioning was below nipple level, and my grip was wider than shoulder width. whenever i go heavy, my whole body would shake like im about to collapse. is it because my triceps and calves are lacking?
id like to hear some advice on the bench press powerlifting technique hopefully some links or videos
thanks
D17thgen is offline   Reply With Quote
Sponsored Links
Old 03-15-2006   #2 (permalink)
IronFist
IronFist's Avatar
IronFist has a reputation beyond repute IronFist has a reputation beyond repute IronFist has a reputation beyond repute IronFist has a reputation beyond repute IronFist has a reputation beyond repute IronFist has a reputation beyond repute IronFist has a reputation beyond repute IronFist has a reputation beyond repute IronFist has a reputation beyond repute IronFist has a reputation beyond repute IronFist has a reputation beyond repute
Shoulder blades together.
Ass ON THE BENCH.
You can go up on your toes if you want, but KEEP YOUR ASS ON THE BENCH.
You can arch your back as much as you want, but keep your shoulder blades on the bench and KEEP YOUR ASS ON THE BENCH. In fact, arching your back is good and will help you develop more power, but you need to keep your shoulders and ass on the bench.
Don't bounce.
Your body shakes because you're not used to the heavy weights.
And don't waste your time with "speed reps" or whatever. Even if they do have a place (which is another subject for debate), there is no reason for a n00b to be doing them. They will not contribute much and your time would be better spent doing other things that will develop your form and strength.
__________________
The best uncensored weightlifting community online
eZine
Forum
Corporate Life Sucks
K&N FIPK II / HP Top Portion Header / Neuspeed Front Upper Strut Bar / RSX 19mm Rear Sway Bar
Generic Rear Upper Strut Bar / 15" Silver Rota Slipstreams (11.8lbs) / 205/60/15 Falken ZE-512's
IronFist is offline   Reply With Quote
Old 03-15-2006   #3 (permalink)
white2K2EX
I sure wish my car was newer
white2K2EX is a glorious beacon of light white2K2EX is a glorious beacon of light white2K2EX is a glorious beacon of light white2K2EX is a glorious beacon of light white2K2EX is a glorious beacon of light
Send a message via AIM to white2K2EX
IronFist to the rescue
Oh, and if anyone tells you to keep your feet on the bench, do yourself a favor and don't keep your feet on the bench. Feet on the floor = balance. Do you want to be unbalanced while you have 200+lbs above your head? I don't.
__________________
Memento Mori
white2K2EX is offline   Reply With Quote
Old 03-15-2006   #4 (permalink)
D17thgen
Diamond Member
D17thgen's Avatar
when you say shoulder blades together, do you mean like pinching them together throughout the lift?
i know feet positioning varies, but should i keep them close or spread out for a noobie?
Old 03-15-2006   #5 (permalink)
5.0calypso93lx
Senior Member
5.0calypso93lx's Avatar
5.0calypso93lx is an unknown quantity at this point
Send a message via AIM to 5.0calypso93lx
I like to put my feet on the bench or even in the air sometimes. It has always helped me with my stabilizers and my balance.
__________________
1993 Mustang LX 5.0, bone stock motor with basic bolt ons, 4 wheel cobra discs, an aftermarket suspension, 14.05@99.35 w/ a 2.18 60 foot
2004 Nissan Sentra SE-R Spec V, Blackout on black, bone stock daily with butterflies loctited
5.0calypso93lx is offline   Reply With Quote
Old 03-15-2006   #6 (permalink)
white2K2EX
Quote:
Caution: frat-boy question time.
And how much do you bench? If it was anything over 135, there's no way I'd have my feet anywhere but firmly planted on the floor. Past that, I have yet to see anyone with a bench I consider impressive (>315lbs) bench with their feet on the bench or in the air.
If you like putting your feet up, go for it, but I think it's a bad idea.
__________________
Memento Mori
Old 03-16-2006   #7 (permalink)
IronFist
IronFist's Avatar
If you lose your balance with your feet on the bench, you're fvcked.
It's a common misconception that putting your feet on the bench helps isolate the pecs or some shit like that. It doesn't. It also doesn't help you lift more. It will also get you disqualified from a powerlifting meet before you even unrack the weight. It also hinders your ability to arch your back, which is a) safe and b) helps you lift more.
Did I mention keep your ass on the bench?
__________________
eZine
Forum
Old 03-16-2006   #8 (permalink)
5.0calypso93lx
Senior Member
I usually cross my legs in the air and do 175 about 10 times. Since i have done this, i notice that i am much less shaky when doing higher weight, and i feel much more comfortable doing the bigger weight, since i have done this. I've been doing this for about a year now, and i can really tell a big difference from when i started.
__________________
Old 03-16-2006   #9 (permalink)
D17thgen
Diamond Member
D17thgen's Avatar
jesus christ, its the day after i attempted that bench press technique and im sore as shit here. my entire back, rear delts, traps, ass, and hamstrings feel like the day i first started deadlifts
as soon as i recover, im gonna try it again with my ass on bench this time. thanks for the advice ironfist
Old 03-16-2006   #10 (permalink)
IronFist
IronFist's Avatar
You can probably tell a big difference because it's been a year
It's not like if you have bad form you won't see results, it's just that if you have good form you will see better results, faster, over time, and potentially be safer.
__________________
eZine
Forum
Old 03-18-2006   #11 (permalink)
blouisgod
Life Begins > 6800rpms
blouisgod's Avatar
blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold
Send a message via AIM to blouisgod
i didnt see this mentioned, but grip also seems to be pretty important. you want to go a little more than shoulder width and drop the bar to your chest. for a while i was actually going with a wider grip and not hitting my chest because my damn arms are about 4 ft long and it was just hard to actually bench (people with shorter arms have it easier ). i recently switched to a more narrow grip and by keeping my elbows in, im actually able to touch the bar to my chest and have noticed more gains in a shorter amount of time. i had to drop a lil weight for a few weeks, but im back at 235 now. all in my opinion of course.
__________________
2008 ASM Si Sedan w/ Navi and Summer Tires
blouisgod is offline   Reply With Quote
Old 03-18-2006   #12 (permalink)
white2K2EX
^ Werd. Powerlifters keep those elbows in, yo.
My arms nearly drag the ground, too. Only gorillas are supposed to have arms like this, but oh well.
Grip does make a big difference though. I can bench about 20lbs more with my ring fingers on the rings of the bar than with my index fingers on the same rings. I'm not sure what the regulation in PL'ing is for grip.
__________________
Memento Mori
Old 03-24-2006   #13 (permalink)
muscletrainee
Member
muscletrainee will become famous soon enough muscletrainee will become famous soon enough
Ditto what IronFist posted. All good advice.
I train at 2 different gyms where competitive bodybuilders and powerlifters train. These guys are putting up huge lifts, and I never see them with their feet up in the air or on a bench. None of my fellow pro trainers let their clients do it, either. It's dangerous and it's bad form.
__________________
Personal trainer, nutritionist, pre-contest specialist, and consultant.
muscletrainee is offline   Reply With Quote
Old 03-24-2006   #14 (permalink)
D17thgen
Diamond Member
D17thgen's Avatar
today was chest day and i feel that i can push more weight with my ass off the bench rather than keeping it on the bench. if im just trying to accomplish a goal of pushing a big weight for a PR, would this be acceptable? or is keeping the ass on bench for a precaution for safety?
Old 03-24-2006   #15 (permalink)
IronFist
IronFist's Avatar
^ Keeping your ass on the bench will:
a) Allow you to arch your back, which is a good technique (and legal in powerlifting meets), that will let you generate more tension and lift more weight. It's one of those things that won't really come into play until you're used to doing it.
b) Keep you safer.
c) Keep you from being disqualified in a powerlifting meet,
d) Keep serious lifters from laughing at you.
__________________
eZine
Forum
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
Launch technique!!! sie7e Honda Civic Racing, Street Encounters and Competition Racing 39 02-11-2006 05:12 PM
A 10 for style...0 for technique redvtec04 Off Topic 17 06-08-2005 05:35 PM
FS: Autometer C2 Fuel Press., Oil Press., Water Temp. gauges XJZA80TTX Honda Civic Parts for Sale 2 07-17-2004 08:24 PM
Immortal Technique KaizerSoze Movies, TV & Music 2 02-25-2004 07:39 PM
Trojan Games video 2 (powerlifting) NWS IronFist Off Topic 15 11-21-2003 06:45 PM
User Login
Our Partners
used new
Top 10 Threads
my log
Get in shape "Question Thread"
Dymatize Xpand
Tips on gaining weight.
Pre-workout pump
Possible to lose 32 lbs in a week?
Capoeira
Official Get In Shape '06 Thread
Lean-Gainer Meal Plan for those looking to gain weight!
white2K2EX's Doggcrapp log!
Site Supporters
aluminum radiator
Honda car spoilers
