Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
Help!! Fuel Door won't open!!!
Old 11-20-2007
qfinger's Avatar
qfinger is an unknown quantity at this point
Angry Help!! Fuel Door won't open!!!
I tried to gas up my 2005 Civic but the door won't open. I pressed the lever at the gas station and felt the click like normal, but the fuel door never opened. I tried plying the door open with a credit card while my friend is pressing the lever but no good. The latch doesn't seem to give. But now when I press the level nothing happens, I hear or feel the normal "click". Damn, is there a emergency release for the fuel door on a civic? I checked inside the trunk but did not find anything. Help, I really low on gas too.
qfinger is offline
Old 11-20-2007
RHCP0801's Avatar
Re: Help!! Fuel Door won't open!!!
search
RHCP0801 is offline
Old 11-20-2007
get in through the trunk and pull the cable yourself for now. then later, www.fueldoorfix.com
gearbox is offline
Old 11-21-2007
qfinger's Avatar
Red face Re: Help!! Fuel Door won't open!!!
Thanks gearbox, I managed to get the door opened now. The car is still under warranty, I'm bringing it back to the dealership to get this fixed.
qfinger is offline
Old 11-21-2007
civiccontend34's Avatar
civiccontend34 has a spectacular aura aboutciviccontend34 has a spectacular aura aboutciviccontend34 has a spectacular aura about
same happened to me, it must be a faulty thing cuz i know it has happened to alot, and there is always that stupid ad for the fix lol so it must be bad. I had to bring it in 4 times before the finally fixed it properly, make sure you request they replace the WHOLE SYSTEM because everytime they gave it back within a few fills up it screwed up again. If you havnt figured it out, reach in on the side of the gas cap behind the trunk carpeting and twist the **** at the end of the wire until it comes out, much like you switch a headligh bulb, it will open.
civiccontend34 is offline
Old 11-21-2007
the problem with fixing the whole system is, youre back to the beginning and its only a matter of time before the same thing happens. they dont have a new stronger cable, its the same spec as the one you had before.
gearbox is offline
Old 11-21-2007
qfinger's Avatar
Well, not 100% of the whole system is defective otherwise Honda would have issued a recall. You might get lucky and get a good one. If not, then spend 20 some bux for the fueldoorfix.com product.
qfinger is offline
Nalmonte
06-03-2015 11:01 AM
MamaBear2015
05-18-2015 07:37 PM
werdnahall
05-17-2015 11:37 AM
maaronia
05-14-2015 10:46 PM
Gunner
Engine DIY
10-06-2012 12:37 PM
Quick Reply: Help!! Fuel Door won't open!!!
