Go Back   Honda Civic Forum > MARKETPLACE > Buy, Sell, & Trade
Register Forgot Password?
Register Photo Gallery FAQ Members List Search Today's Posts Mark Forums Read Experience GarageVendors TSB & Recalls
Welcome to Honda Civic Forum
Buy, Sell, & Trade Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
LinkBack Thread Tools
Old 10-01-2006   #1 (permalink)
willy1980 is an unknown quantity at this point
engine oil smells like gasoline.
2001 civic sedan automatic very low mileage. Engine oil changed in late June, drove 1500 or so miles on that oil...
I noticed a drop in the fuel economy and the engine sounded "different" (engine sounds a little noisier during acceleration) only after driving it for 6~8 miles (varies).
Checked the oil dipstick and noted that the engine oil is above the full mark, about 1/3 of an inch. Smelled the dipstick. Smelled of gasoline.
Car seems to run fine. There is no smoke of any color coming out of the tail pipe. Tail pipe emissions smell normal. No smell of gasoline there.
Check Engine light is NOT on.
Went to the dealer to see what the problem might be. Told them that the engine oil smells like gas and that the car ran rough (To me anyway). They checked the codes (Twice), checked emissions (Twice), Mechanic did a road test by himself and found nothing wrong with it. I did a drive with the mechanic and asked if the engine sounded normal. He said it did. I must be paranoid but it sounded just a bit noisy.
I don't know if they bothered to check to see if there was a fuel leak. Would a fuel leak show up in a diagnostics? or would you have to take a peek at the pump, fuel injectors or what have you?
They changed the oil, filter for free. Didn't charge me for diagnostics or anything. They put in four quarts, but didn't bother to check the oil level. I checked the engine oil in a parking lot after leaving the dealership and noted once again that the oil is above the full mark, about a third or so of an inch above. Could this be because they just put too much oil in or is fuel leaking into it?
Yes it still smells like gas.
Is the oil used in the Honda dealers supposed to smell like that? Not sure what they used. Sorry. But I assume all dealerships use the same stuff.
The next time I'm at the honda dealer what should I tell them to look for so that they can pinpoint the problem. Should I ask for a used oil analysis or something next time to verify my paranoia?
What are the possible problems, besides fuel pump, regulator and injectors?
Thanks for any info anyone can provide.
willy1980 is offline
Old 10-01-2006   #2 (permalink)
05blkrs is an unknown quantity at this point
have them send the oil off to get analyzed, and also have them do a compression check... if the compression rings on a cylinder are out, gas could seep through to the oil but the oil control ring would stop it from throwing any oil up to the combustion chamber... this will not cause a check engine light, andit will cause the car to run rough and waste a lot of gas..... just a thought.. but that's what i'd have them do.
__________________
just here lookin for info for the girlfriend's civic
05blkrs is offline
Old 10-01-2006   #3 (permalink)
Wadely is an unknown quantity at this point
Send a message via AIM to Wadely Send a message via Yahoo to Wadely
yea piston rings and valve seals if toasted enough can have that effect as well
__________________
2006 white 5 speed coupe, tinted windows, painted brakes, aero kit, 17 inch motegi tracklites (14 lbs a piece), 225/45/17 kumho ecsta MX tires, eibach springs, eibach camber kits, AEM Cold Air Intake, MagnaFLow 2.25in custom Exhaust, Comptech Short Throw Shift Kit, Counter Weight Shift Knob, Mugen Ground Cables, Progress 22mm Solid Rear Sway Bar, Corsport adjustable Rear Sway Bar Links.
Wadely is offline
Old 11-15-2006   #4 (permalink)
dk miller is an unknown quantity at this point
If you really are getting gasoline in your oil it will have serious consequences to the engine bearings,camshaft lobes, and all other mechanical components that are lubricated by crankcase oil. Oil cut with fuel just cannot lubricate adequetly.
You may have a leaky fuel injector dripping fuel into a cylinder, then past the rings into the crankcase when the engine is shutdown. This would not necessarily cause driveability problems or emissions. That diluted oil will sure as heck damage the internals though. Ask for a leakdown test on the fuel rail as a first troubleshooting check. Good luck
dk miller is offline
Old 11-16-2006   #5 (permalink)
sorry bro but NO LEAKY FUEL SYSTEM COMPONENT would cause gas to get into the oil in a car w/ an electric fuel pump... that's just a fact there.. i thas to be either valve seals, piston compression rings, or a cracked component either head or block.. if a compression test comes back as fine, there's nothing wrong with the car as far as there is no fuel in the oil.. almost guaranteed.. but like i said before, get the oil analyzed.. and dont waste your time trying to find a fuel system leak because you wont find one..
__________________
05blkrs is offline
Old 11-16-2006
CivicForums
Honda Civic
Paid Advertisement
Tags
car , check , civic , engine , gas , gasoline , honda , light , odor , oil , on , rough , run , smell , smells
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Replacing Headlight Assembly/Bulbs
Finding the ECU error codes
ignition coil
Help!! Fuel Door won't open!!!
b16 vs b18??
2010 Honda Accord Diesel
ECT Sensor location
Window Tinting Question
Synthetic Oil Debate
1/4 mile times! add yours!!!
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Emails Backup
