Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
Finding the ECU error codes
Old 03-05-2006
CG99's Avatar
CG99 is an unknown quantity at this point
This comes from my little Civic notebook on my PC too.
All this info I gathered some time ago, glad to put it to good use now!
Here is how you get the ECU to spit out its error codes-
Locate the ECU under the carpet in the passenger foot well.
Find the red LED in the center of the ECU.
Turn the ignition to ON. The red LED should flash once when this happens to indicate that the ECU has power.
If there are no further flashes then there are no error codes.
If there are further flashes then there are one or more error codes.
CG99 is offline
Old 03-05-2006
Darth's Avatar
Darth is an unknown quantity at this point
Thanks again for this great info.
Is this the same on all civic years and models, or just specific to one civic?
I imagine most of them are similar if not the same.
Darth is offline
Old 05-09-2006
vargasr66's Avatar
vargasr66 is an unknown quantity at this point
This is true for 85-91 civics i believe...92 on up are different..
vargasr66 is offline
Old 05-09-2006
TomH's Avatar
TomH is an unknown quantity at this point
How does one find the error codes on the newer cars?
Perhaps we need a sticky on this
TomH is offline
Old 05-10-2006
Tayler's Avatar
Tayler can only hope to improve
There is the paper clip check. Turn the ignition on and off 3 or four times and the cel should flash giving you the code(not sure if it works on civics but the neons i work on work like that).
Tayler is offline
Old 05-10-2006
anteater's Avatar
anteater is an unknown quantity at this point
To be honest I never check the codes.
How accurate are they in really diagnosing the problem?
anteater is offline
Old 05-10-2006
Tayler's Avatar
All they do is give you a close guess really. It will not pin point the error but will lead you in the right direction most of the time from my experience.
Tayler is offline
Old 05-11-2006
GT_1's Avatar
GT_1 is an unknown quantity at this point
Or the wrong one in my case sometimes
Sometimes something is wrong that sets off a code, but its something else wrong down the chain thats the real problem - makes it hard to find.
GT_1 is offline
Old 05-14-2006
CG99's Avatar
Thats a quicker and probably easier to follow description than mine, thanks for that
CG99 is offline
Old 05-27-2006
vargasr66's Avatar
On 92-95 civic there are two plugs above the ecu (in a green soft plastic holder) the one with two pins can be jumpered with a paper clip or just a piece of wire with the engine running or stopped after the cel comes on. It will start to flash codes using the cel . one long flash followed by four short flashes is code 14. two long and one short is code 21, two short is code 2 and one long is code 10. that is how it is read by the flashes. once codes flash it will give all codes that it has at that time(separated by about 2 second intervals) then stop for about 4 second and the repeat all codes over and over until you remove the jumper.
Old 05-27-2006
fivespeed's Avatar
fivespeed is an unknown quantity at this point
I wonderd why this was called the paper clip test. God to know. I always tried to see how to get in the machine, yes the little computer does make mistakes but if they are tied into the rest of the car operation it might be a sympton of something else going wrong.
remember Murphy;'s law: a $600 computer circuit "brain" will blow its charge and burn out to protect a $15 fuse.
fivespeed is offline
Old 03-22-2010
michaelbell's Avatar
michaelbell is an unknown quantity at this point
Re: Finding the ECU error codes
hay i've tried all of this and still nothing I don't have a an "led" on the ecm and the check engine light just stays on.
the problem Im have'n is no start. I have fuel weak spark and compression. Ive put in 2 different distributors and still no dice. all fuses are good battery is good , grounds ......WTF....... help...
Mike
michaelbell is offline
Old 05-27-2010
craw76's Avatar
craw76 is an unknown quantity at this point
can anyone help get my radio code please. had battery off and cant get it anywhere all i have is the serial no 30006922 is a y reg civic if anyone can help u can email me at craw76@googlemail.com
craw76 is offline
Old 06-14-2010
harrynow81's Avatar
harrynow81 is an unknown quantity at this point
i think this is a bit different on later models. have a 95 civic which i got some years back and while using this step to check the error codes it did not show. finally had to show it to the mechanic for getting the proper work done. although overall a reliable car that week was a bit off as several things went off at the same time. hope it does not bother again.
harrynow81 is offline
Old 08-17-2010
beckyjerk's Avatar
beckyjerk is an unknown quantity at this point
my car has had problems starting for a while. i have a '91 civic and it turns over, just doesn't start. the light blinks 4 times, then after blinks 8. does anyone know what error code this may be?
beckyjerk is offline
Old 08-17-2010
Low and slow!
02civicsi02's Avatar
Just go get the code read at autozone or where ever.
02civicsi02 is offline
Old 08-17-2010
beckyjerk's Avatar
it's free right?
forgive me if someone posted that it is in this thread before.
Old 08-17-2010
Low and slow!
it's free right?
Ya its free.
Default_Slayer
Electrical DIY
12-04-2022 07:56 AM
davidpaustin
05-07-2015 05:08 PM
davidpaustin
04-30-2015 11:20 PM
dooner24
04-14-2015 07:51 PM
Gunner
Engine DIY
10-06-2012 12:37 PM
Quick Reply: Finding the ECU error codes
