Go Back   Honda Civic Forum > GENERAL > Honda Civic Fuel, Oil, Cleaners & Other Maintenance
Honda Civic Fuel, Oil, Cleaners & Other Maintenance Extending the life of your Honda Civic requires the proper fuel, oil, and cleaners, along with other regularly scheduled maintenance. Keep your Honda Civic fuel and oil at the right levels to keep your Civic on the road longer.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 3 Weeks Ago   #1 (permalink)
Engineer30
New Member
Engineer30 is an unknown quantity at this point
Replacing O2 Sensor
Hi!
I have a Honda Civic 2000 DX.
I'm trying to replace my O2 Sensor but first, I need to remove two bolts from the heat shield. Anyboyd knows what wrench size I need to remove them? I can't find the right size.
Thanks,
Engineer
Engineer30 is offline   Reply With Quote
Sponsored Links
Old 3 Weeks Ago   #2 (permalink)
Ironliftr3
New Member
Ironliftr3 is an unknown quantity at this point
Re: Replacing O2 Sensor
Just did this last week, although mine is a 98. Pretty sure it was a 12mm.
Ironliftr3 is offline   Reply With Quote
Old 3 Weeks Ago   #3 (permalink)
Engineer30
New Member
Thank you! Any recommendation to loose a stuck bolt?
Old 3 Weeks Ago   #4 (permalink)
04 Honda Civic
Super Member
04 Honda Civic will become famous soon enough 04 Honda Civic will become famous soon enough
Use liquid wrench or something like that. Do you really have to remove the heat sheild? They sell O2 sensor removers so u can do it easier without removing the heat sheild. BTW just so you know the bolts ARE going to snap if your talking about the catalyctic converter heatsheild. Mine did.
04 Honda Civic is offline   Reply With Quote
Old 3 Weeks Ago   #5 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
yeah just get an o2 sensor socket with a cut in the side for wires to fit thro.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 3 Weeks Ago   #6 (permalink)
Staninator
Member
Staninator's Avatar
Staninator is an unknown quantity at this point
Quote:
For the bolts on cats and headers, it will be very hard to remove them. Especially from the cat back. They rust over the years and the only way to remove them without breaking them or cutting the pipes is by taking it you a muffler shop and having them torch the bolts and them impact them off. If you have the equipment yourself you can do it too. The o2 sensor bolt may be rusted on there well but I don't recommend torching the sensor... You can try some type of rust lube otherwise try the socket gearbox is talking about.
Staninator is offline   Reply With Quote
Old 3 Weeks Ago   #7 (permalink)
04 Honda Civic
Super Member
If the sensor is bad does it really matter? They usually come off easy since they were greased from the factory. The sheild bolts however will probably still break even if you torch them because they are so weak and small.
Old 3 Weeks Ago   #8 (permalink)
Engineer30
New Member
Hi Guys... I need to replace the front sensor (I got a code P0135) .. so, do you think that I don't need to remove the heat shield? I have a o2 sensor wrench.
Thanks for your recommendations.
Engineer30
Old 3 Weeks Ago   #9 (permalink)
04 Honda Civic
Super Member
As said before you do not need to remove the heat sheild. Simply use the tool, the tool is able to get in there even though the O2 sensor is recessed. I remember doing it on my car. It was really easy. I broke one of the heat sheild bolts on my car before I decided I needed the O2 sensor tool. Its super fucking annoying, now when I idle its so loud from the vibrations in the heat sheild. I reccomend you dont mess with the heat sheild unless you have new bolts or want to remove it completely.
Old 3 Weeks Ago   #10 (permalink)
Ironliftr3
New Member
Like I said, I just did this last weekend on my 98 DX. I absolutely HAD to remove the heat shield, no way I would have gotten the O2 sensor tool around the sensor without removing the shield. I did borrow the correct tool, with the slot for the wires, from a local auto store. Even then, there was a minimum amount of 'turn space' available.
My heat shield bolts came out relatively easily, but my o2 sensor was a total bitch. I warmed the engine for a few minutes, soaked the sensor in WD40 (all I had), tapped it with a hammer a dozen or so times, and cranked the hell out of it until it broke free. The limited space is what made it the most difficult. By the way, I'm a weightlifter/bodybuilder, and by no means have a 'girls grip'....sometimes a 500 lb deadlift comes in handy outside of the gym...lol.
Old 3 Weeks Ago   #11 (permalink)
gearbox
Super Moderator
01-05 civic is easy with just the o2 socket. and you prolly need to jack up the front to get under there. shouldve used a breaker bar or cheater pipe on the end of the socket. i broke mine free in two tries and i have girly arms. you dont need muscle if you use a long enough pipe.
__________________
www.lubecontrol.com
Member 1025782
Old 3 Weeks Ago   #12 (permalink)
Ironliftr3
New Member
Quote:
Didn't have a breaker bar, just my standard 8 inch socket wrench. Breaker bar is on the list of 'to buy' items. And you're absolutely right, I'd take brains, and the correct tools, over brawn any day. But eh, we work with what we have..lol!
Old 3 Weeks Ago   #13 (permalink)
gearbox
Super Moderator
just get a $2 exhaust pipe to put on the ratchet.
__________________
www.lubecontrol.com
Member 1025782
Tags
02 , 1999 , 2000 , 2007 , 93 , 99 , civic , crv , honda , o2 , oxygen , replace , replacing , sensor , sensors , si , stuck
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
poll: what oil filter do you use?
FAQ about oil, fuel addatives, filters, and more
don't use premium gas
Honda Recommended Lubricant list
10,000 mile oil change
Double Gas Mileage (Update Pg.5)
100,000 Mile Service
How to siphon gas out of our cars?
41 mpg~!!!!!!!!!!!!!!!!!!!!!!
post your mileage
Site Supporters
aluminum radiator
Honda car spoilers
