Go Back   Honda Civic Forum > GENERAL > Honda Civic Fuel, Oil, Cleaners & Other Maintenance
Honda Civic Fuel, Oil, Cleaners & Other Maintenance Extending the life of your Honda Civic requires the proper fuel, oil, and cleaners, along with other regularly scheduled maintenance. Keep your Honda Civic fuel and oil at the right levels to keep your Civic on the road longer.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-02-2009   #1 (permalink)
devolic
New Member
devolic is an unknown quantity at this point
Send a message via AIM to devolic
P1456
Hello I have a 2005 Civic DX the check engine light came on. It came out to be a P1456. I tightened the fuel cap what else would cause this code? To remove this ad, register today for free or log in if already registered!
devolic is offline   Reply With Quote
Sponsored Links
Old 07-03-2009   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: P1456
well usually youre supposed to replace the fuel cap with a new one, cause it still has the pressure seal inside that could just be worn out. get a new oem honda cap first and try that. if that doesnt fix it, youre gonna have a hard time finding where the leak is. the evap recovery system is huge and there are alot of lines that could have a small leak. this is the actual code: sounds like a new gas cap will fix it tho.
P1456 EVAP Emission Control System Leak Detected (Fuel Tank System)
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 07-04-2009   #3 (permalink)
MidnightCivic
MidnightCivic's Avatar
MidnightCivic is a glorious beacon of light MidnightCivic is a glorious beacon of light MidnightCivic is a glorious beacon of light MidnightCivic is a glorious beacon of light MidnightCivic is a glorious beacon of light MidnightCivic is a glorious beacon of light
Send a message via Yahoo to MidnightCivic
Re: P1456
How far did you drive after tightening the fuel cap?
__________________
Current Mods
• DIY BOH • Progress Rear Sway
• Yellow Fogs • Altezza Grill
• 16 red/black te37 replicas • ep3 side markers
• Hayame Cat Back • K&N fipk intake
• D2's • 04 Smoked Taillights
• Cf Hood • Neuspeed Strut Bar
• Aero Sides • Oem Rear Lip
• Type B Front Lip • D3S Retro Headlights
Future Mods
• CF Trunk
MidnightCivic is offline   Reply With Quote
Old 07-04-2009   #4 (permalink)
lilmidget08
Member
lilmidget08's Avatar
lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned
Send a message via AIM to lilmidget08
Re: P1456
was the cap loose at all. most likely just re tighten the cap clear the code and be on your way. i see them come into the shop all the time. especially if the cap was loose from the gas station guy.... if you re tightened it and cleared the code and it comes back on with the same code then you have a real evap problem, in that case it does get complicated. good luck let us know if it comes back on. but well all hope that it doesnt.
lilmidget08 is offline   Reply With Quote
Tags
2001 , 2005 , auto , cap , check , civic , code , engine , gas , hinda , honda , loose , p1456 , service , si
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
poll: what oil filter do you use?
FAQ about oil, fuel addatives, filters, and more
don't use premium gas
Honda Recommended Lubricant list
10,000 mile oil change
Double Gas Mileage (Update Pg.5)
100,000 Mile Service
How to siphon gas out of our cars?
41 mpg~!!!!!!!!!!!!!!!!!!!!!!
post your mileage
Site Supporters
aluminum radiator
Honda car spoilers
