Go Back   Honda Civic Forum > GENERAL > Honda Civic Fuel, Oil, Cleaners & Other Maintenance
Honda Civic Fuel, Oil, Cleaners & Other Maintenance Extending the life of your Honda Civic requires the proper fuel, oil, and cleaners, along with other regularly scheduled maintenance. Keep your Honda Civic fuel and oil at the right levels to keep your Civic on the road longer.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-24-2009   #16 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: 2004 honda civic transmission fluid
thats because shes a girl. if you go and ask, i doubt they would quote you any higher than $90-100.
Quote:
Originally Posted by ihave2guns View Post
my gf was told by a shop that an oil change and transmission fluid flush would cost $330. something told me this was too much. so who is right between the one guy that says there's an internal filter and those who say there isnt a filter at all? no filter at all is what they told us at the dealership in annapolis. if there is one, maybe they actually did take it out and change it, thereby legitimately incurring the huge cost?
bummer.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Sponsored Links
Old 09-24-2009   #17 (permalink)
Running Riot
Senior Member
Running Riot's Avatar
Running Riot will become famous soon enough
Send a message via AIM to Running Riot
DIY FTW. They may have been what the dealer meant when he said it wasn't designed to be replaced, they didn't replaec it in my friends chris's 2000 and I was standing there when the guy said it doesn't get replaced. It sounded kinda retarted to me why you wouldn't change the atf filter after a what? 60k change interval? then again the trans is enclosed and not open to elements like the crankcase therefore maybe it doesn't get as dirty? Since it's a sealed system and only the fluid is going around the gears?
__________________
B16 10.4:1 JDM Pistons ITR Manifold 70.2mm Throttle Body Skunk2 Stage 1 Pro Cams AEM FPR DC Header Magnaflow Custom 2.5" exhaust BDL Fuel Rail Nology Individually Grounded Wires Fidanza 7.5lb Flywheel Exedy Clutch Goodridge Braided Steel Clutch Line Fidanza Short Shifter Skunk2 knob JUN Chip
IM SO JDM I EVEN HAVE SARS
Running Riot is offline   Reply With Quote
Old 09-24-2009   #18 (permalink)
Devani
Diamond Member
Devani's Avatar
Devani should not be questioned Devani should not be questioned Devani should not be questioned Devani should not be questioned Devani should not be questioned Devani should not be questioned Devani should not be questioned Devani should not be questioned Devani should not be questioned Devani should not be questioned Devani should not be questioned
it only cost me $20 for fluid and washer.....pick up at the dealer and change the fluid and drive back to dealer to drop off used fluid...
mine was manual and it's harder to change manual....i've done it on my mother's accord, super easy and she noticed it too...
__________________
2001 EX Coupe Rally Red 5 Speed..(RIP)
2009 Civic SI Alabaster Silver Metallic Sedan
A wiseman fears and departs from evil but a fool rages and is self-confident.
Proverb 14
Devani is offline   Reply With Quote
Tags
2002 , 2003 , 2004 , 2005 , atf , auto , change , check , civic , drain , filter , fluid , honda , trans , transmission
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
poll: what oil filter do you use?
FAQ about oil, fuel addatives, filters, and more
don't use premium gas
Honda Recommended Lubricant list
10,000 mile oil change
Double Gas Mileage (Update Pg.5)
100,000 Mile Service
How to siphon gas out of our cars?
41 mpg~!!!!!!!!!!!!!!!!!!!!!!
post your mileage
Site Supporters
aluminum radiator
Honda car spoilers
