Go Back   Honda Civic Forum > GENERAL > Honda Civic Fuel, Oil, Cleaners & Other Maintenance
Honda Civic Fuel, Oil, Cleaners & Other Maintenance Extending the life of your Honda Civic requires the proper fuel, oil, and cleaners, along with other regularly scheduled maintenance. Keep your Honda Civic fuel and oil at the right levels to keep your Civic on the road longer.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-25-2009   #1 (permalink)
2006 honda coup
New Member
2006 honda coup is an unknown quantity at this point
Help
Hello. I purchased a 2006 Civic Coupe 14 days ago from a dealer. The oil indicator came on last night (15%). I ended up adding 4 quarts of oil to get it back to full. Is the engine toast? It seems fine and the oil is not leaking out. I do like the car - it looks like the dealer drained the oil and forgot to refill -- is this possible? I have about 1000 miles on the car since I purchased it 14 days ago -- thks for your input To remove this ad, register today for free or log in if already registered!
2006 honda coup is offline   Reply With Quote
Sponsored Links
Old 06-25-2009   #2 (permalink)
04 Honda Civic
Super Member
04 Honda Civic will become famous soon enough 04 Honda Civic will become famous soon enough
Re: Help
I would probably bringing that car back to the service center and tell them what happened. If your oil was that low you probably have shortened the life of that motor dramatically
04 Honda Civic is offline   Reply With Quote
Old 06-25-2009   #3 (permalink)
CraigW
Platinum Member
CraigW's Avatar
CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light
Re: Help
Did you check the level on the dipstick before adding ??
The indicator inside is the life not the level.
And yes, if it did indeed take 4 quarts you need to get back in touch with the seller.
CraigW is offline   Reply With Quote
Old 06-26-2009   #4 (permalink)
TRIZ
Hey! Look At Me!! I'm a Supporting Member!!Administrator
TRIZ's Avatar
TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of
Send a message via AIM to TRIZ
Re: Help
Hmm.... where did you add the oil?
TRIZ is offline   Reply With Quote
Tags
10 , civic , honda , indicator , oil
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
poll: what oil filter do you use?
FAQ about oil, fuel addatives, filters, and more
don't use premium gas
Honda Recommended Lubricant list
10,000 mile oil change
Double Gas Mileage (Update Pg.5)
100,000 Mile Service
How to siphon gas out of our cars?
41 mpg~!!!!!!!!!!!!!!!!!!!!!!
post your mileage
Site Supporters
aluminum radiator
Honda car spoilers
