Go Back   Honda Civic Forum > GENERAL > Honda Civic Fuel, Oil, Cleaners & Other Maintenance
Honda Civic Fuel, Oil, Cleaners & Other Maintenance Extending the life of your Honda Civic requires the proper fuel, oil, and cleaners, along with other regularly scheduled maintenance. Keep your Honda Civic fuel and oil at the right levels to keep your Civic on the road longer.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-15-2009   #1 (permalink)
astaroth26
New Member
astaroth26 is an unknown quantity at this point
Honda Civic 1995 1.3 starting problems.
Hello,
I am from the UK and i am having a starting problem with my Civic.
The other day i was driving home and it felt like the engine lost power from the gearbox. Eventhough it was in gear it felt like it had been put into neutral. I came to a stop and the engine cut out.
When i tried to start it again it cranked over and started but cut out after about 2 seconds.
I called the breakdown people and the guy came had a look, he said that it may be the fuel pump and he told me how to check if this was the problem.
I did what he said and the fuel pump is working fine.
The only way i can get the engine to start is by cranking it over and pump the gas pedal. as soon as i stop this the engine dies again.
I dont know what the problem is. I was told it may be electrical but all the lights on the dashboard work and everything else, so i dont think its that, unless the engine electrical system is different from the others.
Please help.
thanks
astaroth26 is offline   Reply With Quote
Sponsored Links
Old 06-15-2009   #2 (permalink)
wallydude03
Senior Member
wallydude03's Avatar
wallydude03 will become famous soon enough
Send a message via AIM to wallydude03
Re: Honda Civic 1995 1.3 starting problems.
I would check the fuel pressure as well as the sparkplugs.
wallydude03 is offline   Reply With Quote
Tags
1995 , 1996 , 2003 , civic , civis , fuel , honda , ignition , intermittent , intermittently , problem , problems , start , starter , starting
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
poll: what oil filter do you use?
FAQ about oil, fuel addatives, filters, and more
don't use premium gas
Honda Recommended Lubricant list
10,000 mile oil change
Double Gas Mileage (Update Pg.5)
100,000 Mile Service
How to siphon gas out of our cars?
41 mpg~!!!!!!!!!!!!!!!!!!!!!!
post your mileage
Site Supporters
aluminum radiator
Honda car spoilers
