Go Back   Honda Civic Forum > GENERAL > Honda Civic Fuel, Oil, Cleaners & Other Maintenance
Honda Civic Fuel, Oil, Cleaners & Other Maintenance Extending the life of your Honda Civic requires the proper fuel, oil, and cleaners, along with other regularly scheduled maintenance. Keep your Honda Civic fuel and oil at the right levels to keep your Civic on the road longer.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 05-24-2009   #1 (permalink)
Earthson
New Member
Earthson's Avatar
Earthson is an unknown quantity at this point
Heat issues in 2001 Civic
I'm having issues with my heat, and need some new ideas please.
Recently I noticed that my civic is blowing cold, possible lukewarm air when the heat dial is cranked to full hot. If the engine has been running hard, it will be on the higher end of lukewarm...otherwise, just cold.
I cannot see it being the thermostat, as it was just replaced a few months ago when my water pump was replaced. And, the temp gauge in the instrument panel stays at normal running temp - no fluctuations.
Coolant levels are topped up, and don't fall.
I opened up the rad cap, ran the engine, and got rid of a few air pockets in the system...didn't help.
All hoses get very hot when running - BUT - one that returns from the heater core didn't really warm up at first. I had to work it a little before the temp/pressure seemed to come up - problem??
Anyone have any ideas? Thanks.
- oh, and I'm not really mechanically inclined...so talk slowly and simply
Earthson is offline   Reply With Quote
Sponsored Links
Old 05-25-2009   #2 (permalink)
04 Honda Civic
Super Member
04 Honda Civic will become famous soon enough 04 Honda Civic will become famous soon enough
Re: Heat issues in 2001 Civic
hmm u dont overheat? Sounds like a bad heater core or clogged hoses or something
04 Honda Civic is offline   Reply With Quote
Old 05-25-2009   #3 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
okay did you do that first step with the heater on HOT and fan blowing at max? thats the only way to get rid of bubbles in the heater core, which must be done any time coolant is changed (like when doing timing belt/water pump).
otherwise you could have a clogged heater core.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 05-25-2009   #4 (permalink)
04 Honda Civic
Super Member
good idea..make sure you do what gearbox said. Open the rad cap park on a hill or jack up the front of the car nose up and run the car for some time with your heat on full blast. Make sure that your car is topped off on coolant before you do this. After you do this you may have to add some coolant so dont forget to check your level.
Old 05-27-2009   #5 (permalink)
Earthson
New Member
Earthson's Avatar
Thanks for the responses.
Yes, I did have the dial to FULL HOT and ran the fan at FULL with the cap off. I jacked up the passenger side. Maybe I'll try doing it again right in front and see if that helps.
...hope it's not the heater core. Is that a costly fix?
Old 05-27-2009   #6 (permalink)
lowlife9
Super Member
lowlife9's Avatar
lowlife9 will become famous soon enough
very costly mostley labor cost because the entire dash needs to be disasembled .
__________________
lowlife9 is online now   Reply With Quote
Old 05-27-2009   #7 (permalink)
Earthson
New Member
Earthson's Avatar
Awesome...
Old 05-28-2009   #8 (permalink)
edwin101988
New Member
edwin101988's Avatar
edwin101988 is an unknown quantity at this point
Does your car ever overheat? I know my car was doing this but it also was overheating, found out it was a blown head gasket so I got Honda to replace it, gotta love Honda Care!
edwin101988 is offline   Reply With Quote
Old 06-17-2009   #9 (permalink)
Earthson
New Member
Earthson's Avatar
Nope, never overheats. Temp gauge is steady
Old 06-17-2009   #10 (permalink)
redrocket600
Senior Member
redrocket600's Avatar
redrocket600 has a spectacular aura about redrocket600 has a spectacular aura about redrocket600 has a spectacular aura about
Quote:
I had the same issue....never overheated but had horrible heat in the winter. Turned out the headgasket was leaking a TINY TINY bit...
You say the heater hoses get hot (to the core). Are you sure the valve is opening completely? It's between the engine and heater core, next to the firewall....
redrocket600 is offline   Reply With Quote
Old 06-17-2009   #11 (permalink)
Earthson
New Member
Earthson's Avatar
Quote:
No, I'm not sure...my mechanic did mention it and wiggled it, but wasn't sure what it's movement range was supposed to be...then it detached and he swore for about 10 minutes trying to put it back on...I assume that is what you are talking about...
So, how would I know if it is opening completely?
Old 06-18-2009   #12 (permalink)
Earthson
New Member
Earthson's Avatar
If it is the valve, is that a hard thing to get to to fix? Does it still require all the work of the heater core? Or can it be done without gutting the car?
Old 06-18-2009   #13 (permalink)
redrocket600
Senior Member
That would be the one...sucks to put the line back on. I believe it has about 90* of movement but am not positive. Have someone in your car with the key on, flip the (temp) knob from hot to cold and vice versa, and see if it moves completely. If it does, then it's probably not your problem. If it were me, I'd just wait 'til winter and worry about it then
BTW, I highly doubt the valve would fail. If anything, the motor/switch would no longer be moving the valve as it's supposed to. Not sure how to fix that, but I'd imagine you'd have to take the dash apart...
Tags
05 , 2001 , 2003 , 2004 , bad , blowing , civic , clogged , cold , core , heater , heats , honda , issues , overheating , replace
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
poll: what oil filter do you use?
FAQ about oil, fuel addatives, filters, and more
don't use premium gas
Honda Recommended Lubricant list
10,000 mile oil change
Double Gas Mileage (Update Pg.5)
100,000 Mile Service
How to siphon gas out of our cars?
41 mpg~!!!!!!!!!!!!!!!!!!!!!!
post your mileage
Site Supporters
aluminum radiator
Honda car spoilers
