Go Back   Honda Civic Forum > GENERAL > Honda Civic Fuel, Oil, Cleaners & Other Maintenance
Honda Civic Fuel, Oil, Cleaners & Other Maintenance Extending the life of your Honda Civic requires the proper fuel, oil, and cleaners, along with other regularly scheduled maintenance. Keep your Honda Civic fuel and oil at the right levels to keep your Civic on the road longer.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 01-01-2009   #1 (permalink)
Hunt4Steve
New Member
Hunt4Steve's Avatar
Hunt4Steve is an unknown quantity at this point
Oil Filter and the anti-drain back valve
I have a 2003 Civic HX with the 1.7L 4Cyl engine, a 5spd tranny and about 120k on the engine.
I've recently been using Mobil 1 synthetic from Walmart for my motor oil, and Napa Gold filters (made by Wix) from Napa.
I usually run about 7 thousand miles between oil changes, and the oil filter is changed every 3500 miles.
Here is the interesting part and what I'm seeking help on:
During my last oil filter change, I jacked up the front end of the car, slide under there and removed the old oil filter. I expected some oil to come out of the filter as I removed it....but nothing came out. Needless to say, I was surprised. I though the anti-drain valve would have kept some of the oil in the filter, but from what I could visually see, no oil was accumulated in the filter, at least not enough to poor out.
So, is something wrong, or is this normal? This is the first Civic I've had of this year and engine, so I'm not quite sure if this behavior is accurate.
Any help would be greatly appreciated.
Hunt4Steve is offline   Reply With Quote
Sponsored Links
Old 01-01-2009   #2 (permalink)
greeen01civic4d
balls in ur mouth
greeen01civic4d's Avatar
greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold
Re: Oil Filter and the anti-drain back valve
was the oil warm, or was the car cold
__________________
signature courtesy of speedfoos(Thanks Clint)
go here for 7thgen resource
greeen01civic4d is offline   Reply With Quote
Old 01-01-2009   #3 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
i usually dont get oil coming out but i do mine cold. i dont like getting burned all over lol.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 01-02-2009   #4 (permalink)
Hunt4Steve
New Member
Hunt4Steve's Avatar
Quote:
The engine was cold.
I kinda figured with the ant-drain back valve, there should have been "some" oil in there.....guess not.
The car runs great, despite this, what appears to be an irregular issue here........
When I change the oil, I make sure the engine has reached normal operating temperature, so that the oil will flow out of the oil pan more easily. But, when I'm just changing the oil filter, it seems like it shouldn't matter if the engine is hot or cold, its just the filter that is being changed. The next time I start to drive it, I let it warm up, and ensure there is enough oil in the engine before I drive down the road.
Old 01-02-2009   #5 (permalink)
gearbox
Super Moderator
im sure there was some, afterall the filter is much heavier than the new one right? alot of it stays absorbed in the pleats. just keep using quality filters (napa gold, mobil1, K&N) and youll be fine. they all have anti-drain valves.
__________________
www.lubecontrol.com
Member 1025782
Old 01-02-2009   #6 (permalink)
ragingSPAM
I just burnt my tongue
ragingSPAM's Avatar
ragingSPAM is just really nice ragingSPAM is just really nice ragingSPAM is just really nice ragingSPAM is just really nice ragingSPAM is just really nice
Send a message via AIM to ragingSPAM Send a message via Yahoo to ragingSPAM
when the engine has sat for long enough for the oil to be cold the filter usually drains if its a cheap filter...the napa one is on the cheaper side...when i took automotive engineering classes we dissected oil filters and few were very high quality. AMSoil, mobil1, Honda OEM for the s2000/nsx, and a few others but some of the cheaper ones like fram, bosch, purolator, etc. were pretty crappy internally. Plastic bypass valves instead of metal and paper filters instead of a cotton based like Mobil1 or amsoil.
__________________
2006 RSX-S NHBP
2004 Civic LX coupe SSM sold... ....i miss it...
1984 AE86 sold
1987 AE82 corolla fx-16 (redtop swapped) no longer have
1993 K20A2 swapped EG sedan no longer have
1995 Eclipse (sold)
1986 AE86 Corolla (sold)
ragingSPAM is offline   Reply With Quote
Old 01-02-2009   #7 (permalink)
gearbox
Super Moderator
last time i changed my mobil1 no oil came out of it. im using K&N now.
__________________
www.lubecontrol.com
Member 1025782
Old 01-03-2009   #8 (permalink)
Hunt4Steve
New Member
Hunt4Steve's Avatar
hmmmm..
I figured that Wix (Napa Gold) filters were pretty good, better than most.....
incorrect thinking????
Old 01-03-2009   #9 (permalink)
greeen01civic4d
balls in ur mouth
i use honda filters, and dont get much oil out when i change my oil, if the car is hot, its a different story, some oil will come out, try it sometime
__________________
Old 01-03-2009   #10 (permalink)
gearbox
Super Moderator
napa gold is excellent filter. i hope you're using the "good" honda filter part and not the junk fram ones.
__________________
www.lubecontrol.com
Member 1025782
Old 01-04-2009   #11 (permalink)
Hunt4Steve
New Member
Hunt4Steve's Avatar
For those of you who are interested in reading some pretty good info about Oil-filters (and why I use readily available WIX filters), check out the following site:
http://minimopar.knizefamily.net/oilfilters/index.html
Here is the biggest reason I don't use Fram Oil filters: an email from one of the Fram engineers:
Russell,
I obtained great satisfaction from reading your oil filter survey.
I worked for two years as the oil-filter production line engineer in
an Allied-Signal FRAM facility and I can confirm every bad thing you
have said about FRAM automotive filters. That's from the horse's
mouth, as it were.
I'm also a quality engineer and can confirm that FRAM applies no
quality control whatsoever to any of the characteristics for which we
buy oil filters. I frequently saw filter designs which were barely
capable of meeting J806. Many of FRAM's designs will block and go to
bypass after trying to filter very little contamination. There were
often leakage paths at the paper end discs when these were not
properly centered on the elements. Some designs had the pleats so
tightly packed against the center tube that they would block off in no
time. I had discovered that the FRAM HP1 that I had been buying for
about $20 Cdn was EXACTLY the same as a PH8 inside - the only
difference being a heavier can - no advantages in flow capacity. The
paper filtration media was of apparently poor quality and the process
of curing the paper resin was very inconsistent - elements would range
from visibly burnt to white. FRAM's marketers admitted that there was
just about no way the public could ever prove that an oil filter
contributed, or did not prevent, engine damage. The only thing FRAM
tested for was can burst strength. Another problem that they have from
time to time is in threading the filter base - often there are strands
of metal left behind on a poorly formed thread.
I have not used a FRAM filter since I started working there. Their
claims are entirely and completely marketing bullshit.
If people really want to protect their engines, a good air filter is
vital (which excludes FRAM from that list as well) and a combination
of one depth and one full-flow hydraulic filter, together in parallel,
will do the job of filtration to perfection.
Thanks for doing a great job in trying to get the truth out! You can
quote me anytime.
[name omitted to protect submitter]
Link for above text: http://minimopar.knizefamily.net/oilfilters/fram1.txt
I can't determine the date of this email, but with the current economy and the way corporations are looking to save money, I wouldn't expect Fram to have improved their manufacturing quality.
After looking at my Napa Gold (Wix filter) filter a little closer, I used a precision dental pick and pulled the Nitrile anti-drain seal loose; some oil seeped out. Indeed, there was oil in there, I guess I was expecting more. I may have to go to the Stealership and pick up a Honda filter and cut it open to see how much media is in there, as opposed to the Napa Gold filter I'm using. Since I commute in my car about 90 miles a day (80% hwy/ 20% city), I put on some considerable mileage. I want to be sure I'm getting the best filtering I can get to help my engine last as long as possible. And for those who are into hyper-mileing, my best MPG to date is 49mpg.....needless to say, I'm a happy camper with my little HX model.
cheers.
Old 01-04-2009   #12 (permalink)
Hunt4Steve
New Member
Hunt4Steve's Avatar
After doing some more research and reading, I think I'm going to switch over to a Purolator PureOne:
Part# PL14610
Specifications:
Anti-Drain Back Valve Yes Height 3.52
O.D. 2.69 Relief Valve P.S.I. 14-18
Threads M20-1.5 Type of Filter Spin-on
Weight 6.9
I can get two of these from the Amazon site for $9.48
http://www.amazon.com/Purolator-PL14...1080041&sr=1-1
Old 01-04-2009   #13 (permalink)
Silver02EX
Super Member
Silver02EX's Avatar
Silver02EX is an unknown quantity at this point
Send a message via MSN to Silver02EX
Quote:
I wouldn't call the Bosch or Purlolator (Pure One) "cheap" Those are some of the best filters on the market. Both of them has silicone ADBV compared to others such Fram, Super Tech or other house brand.
Silver02EX is offline   Reply With Quote
Old 01-04-2009   #14 (permalink)
greeen01civic4d
balls in ur mouth
wix is one of the best, and im using the "good" honda filters, never had a problem, used mobil 1 filters for a while, as well as k&n filters. a filter is a filter
__________________
Old 01-04-2009   #15 (permalink)
gearbox
Super Moderator
okay because the honda has two part numbers. one of them is the same as the $2 frams in the store. the pure one is pretty good too, i can usually find those for $4-5. i just play it safe and buy a filter that i know wont fail (K&N, mobil1, wix). prolly purolator does a good job too, i just wouldnt use it personally.
__________________
www.lubecontrol.com
Member 1025782
Tags
anti , antidrain , antidrainback , back , bad , dissected , drain , drainback , filter , filters , fram , mobil , no , oil , valve
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
poll: what oil filter do you use?
FAQ about oil, fuel addatives, filters, and more
don't use premium gas
Honda Recommended Lubricant list
10,000 mile oil change
Double Gas Mileage (Update Pg.5)
100,000 Mile Service
How to siphon gas out of our cars?
41 mpg~!!!!!!!!!!!!!!!!!!!!!!
post your mileage
Site Supporters
aluminum radiator
Honda car spoilers
