Honda Civic Fuel, Oil, Cleaners & Other MaintenanceExtending the life of your Honda Civic requires the proper fuel, oil, and cleaners, along with other regularly scheduled maintenance. Keep your Honda Civic fuel and oil at the right levels to keep your Civic on the road longer.
Welcome to civicforums.com!
Welcome to civicforums.com.
honda actually uses 3 different filters.. altho there are 1 variants of 1 style...
the s2000/legend/nsx filter is larger and has a single part number, and then theres the other filter which is for every other car but there are 2 styles of this, both are pretty much identical internally, but manufactured by different companies
i forget which companies make which, but one is from honeywell and the other is filtech or something
15400-PLM-A02
15400-PLM-A01
you can visually tell which one is which by the base, the a01 has a protruding sealing bead around the base where the diameter is slightly larger than the case wheras the a02 does not
from what ive noticed, brand new cars off the trucks get the a01 filters, and the dealers use the a02's
15400-PCX-004, this is the s2000 filter, its significantly larger in diameter than the above 2, however it will fit on any honda, since its larger in diameter, it has a larger capacity, so add extra oil if you want to use this filter
__________________ 01 ES2, if you dont know what that is.. SEARCH
78 X1/9, if you dont know what that is.. i dont blame you
Honda Trained Technician
Project 5lug: Coming Soon
okay because the honda has two part numbers. one of them is the same as the $2 frams in the store. .
If you look at the ADBV on Honda's (Made by Fram) you can clearly see that it's not the same as the orange fram. The Honda OEM is silicone and the orange Fram is nitrite. Just because Honda's OEM is made by fram, it's not the same as the ones you find in the auto parts store.
i just used the oem honda filters when i had my civic since they were relatively cheap. If i let the oil drain and sit there for awhile usually there was no oil in the filter. If i drained and switched out the filter right away, oil will ooze out of the filter.
Thats why i use to just let it sit there and grab so lunch so nothing would come out of the filter. Having hot oil oozing down to your arm pit isn't fun.
__________________ 04 Civic Coupe with aero kit =sold
94 Integra 3dr= sold
02 c32 mercedes amg = new project
one of the oem filters is exactly the same as the $2 fram in stores, i saw pics side by side and couldnt tell a difference.
was it cut open?
also u sure it wasnt 2 fram filters side by side and one painted blue like the honda filters? ive seen it done before.. where some guy makes their filter LOOK like the competition and cut open the guts
yeah it was on this site i just cant find it cause the search sucks now. there is actually a really bad s2k oem filter too, compared to the "new" revised model, it sucks ballz. i think you can still find both tho at dealers. that i saw on s2ki forums.
__________________
Restore Performance, Reduce Costs www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
