Go Back   Honda Civic Forum > GENERAL > Honda Civic Fuel, Oil, Cleaners & Other Maintenance
Honda Civic Fuel, Oil, Cleaners & Other Maintenance Extending the life of your Honda Civic requires the proper fuel, oil, and cleaners, along with other regularly scheduled maintenance. Keep your Honda Civic fuel and oil at the right levels to keep your Civic on the road longer.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 11-14-2008   #1 (permalink)
motofabio
New Member
motofabio's Avatar
motofabio will become famous soon enough
Coil vs. Ingiter
Sorry for the newb subject matter here, but I lean towards bikes rather than cars. Anyway, the mechanic is telling me that the igniter is bad. But the coil was just replaced.
WTF is the igniter? Is it another name for the ignition coil?
2000 Civic EX
Thanks!
motofabio is offline   Reply With Quote
Sponsored Links
Old 11-15-2008   #2 (permalink)
DsevenEm2
This is Myspace
DsevenEm2's Avatar
DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold
Send a message via AIM to DsevenEm2
Re: Coil vs. Ingiter
Ok basically, your Ignition Coil builds up voltage created by your engine, while its running.
Your Igniter tells the Ignition Coil when to release that voltage, through the leads, onto the spark plug.
Just because you replaced the coil, doesn't mean that the igniter can't still be bad. You can test resistance on the igniter with an ohm meter, but you'd have to look in a service manual to find out how to do it correctly.
__________________
"We are defined by the choices we make"
MMI Gradutate - 11-21-08
Yamaha 5-star~Honda Level1~Mercury/Mercruiser Level1~Suzuki EntryLevel1~Volvo/Diesel EntryLevel1 -- Certified
Next step: United StatesCoast Guard - BC 12-06-08
DsevenEm2 is offline   Reply With Quote
Old 11-15-2008   #3 (permalink)
motofabio
New Member
motofabio's Avatar
Makes sense. Thanks!
__________________
Old 11-17-2008   #4 (permalink)
motofabio
New Member
motofabio's Avatar
So will a bad igniter burn out the coil?
__________________
Old 11-17-2008   #5 (permalink)
DsevenEm2
This is Myspace
DsevenEm2's Avatar
It won't "burn out" the coil, but it will cause it to not act right. They work in conjunction with each other. When one's not working right, the other will act funny, and vice versa.
Since you replaced the coil, I'd say replace the igniter.. but you might have to replace the whole assembly.. I can't remember but you have a distributor right? I'm pretty sure the Igniter is in the distributor as a small module, if not its in an external "ignition module" type deal.. I'm not too sure on your car though.
You need a service manual lol.
__________________
Old 12-04-2008   #6 (permalink)
motofabio
New Member
motofabio's Avatar
Follow up -- igniter replaced. Runs great again. Thanks!
__________________
Tags
ignition , module , replacement
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
poll: what oil filter do you use?
FAQ about oil, fuel addatives, filters, and more
don't use premium gas
Honda Recommended Lubricant list
10,000 mile oil change
Double Gas Mileage (Update Pg.5)
100,000 Mile Service
How to siphon gas out of our cars?
41 mpg~!!!!!!!!!!!!!!!!!!!!!!
post your mileage
Site Supporters
aluminum radiator
Honda car spoilers
