Go Back   Honda Civic Forum > GENERAL > Honda Civic Fuel, Oil, Cleaners & Other Maintenance
Honda Civic Fuel, Oil, Cleaners & Other Maintenance Extending the life of your Honda Civic requires the proper fuel, oil, and cleaners, along with other regularly scheduled maintenance. Keep your Honda Civic fuel and oil at the right levels to keep your Civic on the road longer.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-27-2009   #16 (permalink)
bomerman19
Super Member
bomerman19's Avatar
bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned
Re: is Ethanol at 10% safe on a 6th generation civic?
ethanol won't cause you to lean out, it does not burn as efficiently as regular gas so you get worse gas mileage. It has an octane rating some were between 105 and 110 so it is starting to pop up at the track more and more. the big problem with running e85 in the hondas is not the the injectors or the engine it's the tank and the fuel pump cause E85 eats through plastic and the gas tanks and stock pump is plastic I know a couple built k-series that only run on e85 the only thing they had to change out was the tank and the stock pump.
crazy note: you pop the head on those cars and the pistons are still shiny from running e85
also if you do run e85 and you are running too rich even thought they are technically two different systems you can soak the oil with e85 same thing can happen with gas if it is too rich but w/ e85 if you soak the oil you have to worry about your valve guide seals and cam seals.
bomerman19 is offline   Reply With Quote
Sponsored Links
Tags
06 , 10 , 2001 , 2004 , 2008 , civic , convert , e10 , e85 , ethanol , gas , honda , premium , put , safe
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
poll: what oil filter do you use?
FAQ about oil, fuel addatives, filters, and more
don't use premium gas
Honda Recommended Lubricant list
10,000 mile oil change
Double Gas Mileage (Update Pg.5)
100,000 Mile Service
How to siphon gas out of our cars?
41 mpg~!!!!!!!!!!!!!!!!!!!!!!
post your mileage
Site Supporters
aluminum radiator
Honda car spoilers
