Go Back   Honda Civic Forum > GENERAL > Honda Civic Fuel, Oil, Cleaners & Other Maintenance
Honda Civic Fuel, Oil, Cleaners & Other Maintenance Extending the life of your Honda Civic requires the proper fuel, oil, and cleaners, along with other regularly scheduled maintenance. Keep your Honda Civic fuel and oil at the right levels to keep your Civic on the road longer.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 02-14-2008   #1 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
removing foam sticker from wheels
okay i have alot of that adhesive foam stuff that held on previous wheel weights for balancing, now they are stuck there and i cant get it to come off without scraping at it for hours. googone didnt do anything... so idk, any suggestions? To remove this ad, register today for free or log in if already registered!
__________________
________________________________________
Restore Performance, Reduce Costs
www.lubecontrol.com
LC20 - go 10k miles on a single oil change
Go Here For Real Medicine
http://www.youngliving.com
Member 1025782
The DX-Resource
http://bellz.sqweebs.com/
gearbox is offline   Reply With Quote
Sponsored Links
Old 02-14-2008   #2 (permalink)
pheaton
Post Master General
pheaton's Avatar
pheaton is a glorious beacon of light pheaton is a glorious beacon of light pheaton is a glorious beacon of light pheaton is a glorious beacon of light pheaton is a glorious beacon of light pheaton is a glorious beacon of light
Send a message via AIM to pheaton Send a message via MSN to pheaton Send a message via Yahoo to pheaton
Re: removing foam sticker from wheels
There is this home remedy:
http://www.ehow.com/video_13445_remove-stickers.html
Or there are a bunch of other chemical removers that might work such as:
http://www.valsparglobal.com/val/resident/goof-off.jsp
Good luck!
__________________
- Stay in front, that way you don't have to worry about passing anyone.
pheaton is offline   Reply With Quote
Old 02-14-2008   #3 (permalink)
gearbox
Super Moderator
hmm yeah something that wont damage the wheels lol. i should mention that its not just a small piece, its a total of about 12 inch of sticky stuff with foam on top. i guess i could try the alcohol that shouldnt ruin anything.
__________________
www.lubecontrol.com
Member 1025782
The DX-Resource
Old 02-14-2008   #4 (permalink)
pheaton
Post Master General
pheaton's Avatar
Quote:
Do you a pic of the stuff you're trying to get off? What is the finish on your wheels? I guess maybe I'm thinking about something else. Foam adhesive?
__________________
Old 02-14-2008   #5 (permalink)
gearbox
Super Moderator
you know the foam adhesive that is double sided sticky, well it sticks very well, but if you ever try and pull it off, the foam breaks before the adhesive does. so some of the foam sticks to the weight you pull off, but most is still stuck to the rim. rims are gloss black.
__________________
www.lubecontrol.com
Member 1025782
The DX-Resource
Old 02-14-2008   #6 (permalink)
pheaton
Post Master General
pheaton's Avatar
Next option:
WD-40 and a Hair Dryer.
Hit the area with WD-40 let it absorb for a few minutes. Get some heat on it and see if it will become plyable enough to remove. Use your fingernails and remember too much heat will mess with paint and make it easier to scratch so be careful.
WD-40 will not hurt paint, I promise.
A cold surface makes glue and crap hard to get off, so heat is important.
__________________
Old 02-14-2008   #7 (permalink)
pheaton
Post Master General
pheaton's Avatar
Oh look, here is a guy using the same technique on his motorcycle to get a sticker off of the fuel tank.
http://www.motorcyclecruiser.com/tec...int/index.html
Hope it works, sounds like you're dealing with some real crap there.
__________________
Old 02-14-2008   #8 (permalink)
Eyger
A long winded 7th genr
Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned
Send a message via AIM to Eyger
Take a wet rag, with warm water and soak it good. Let the rag sit on the foam for a while, 10-15 minutes to get it saturated. Then you should be able to scrape it off easily.
Eyger is offline   Reply With Quote
Old 02-14-2008   #9 (permalink)
gearbox
Super Moderator
maybe ill wait for summer lol
__________________
www.lubecontrol.com
Member 1025782
The DX-Resource
Old 02-14-2008   #10 (permalink)
burke420
The World Is Yours!
burke420's Avatar
burke420 should not be questioned burke420 should not be questioned burke420 should not be questioned burke420 should not be questioned burke420 should not be questioned burke420 should not be questioned burke420 should not be questioned burke420 should not be questioned burke420 should not be questioned burke420 should not be questioned burke420 should not be questioned
Send a message via AIM to burke420
goto a local parts supplier of 3M and get an adhesive remover from them... its called 3m adhesive remover! i use it at my job...Discount tire and it's wonders... it's like $12 a can!
__________________
I MY Honda
Enkei RPF1
Type 1 Racing SPL exhaust
TEIN Hood Damper
Cusco front strut bar
FUNCTION7 LCA
burke420 is offline   Reply With Quote
Old 02-14-2008   #11 (permalink)
bomerman19
Super Member
bomerman19's Avatar
bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned
^I have some of that stuff in my frame shop its great it's also usually relabeled as paint thinner, or mineral spirits which will take off most adhesives in a couple of sec when applied with a towel or rag
bomerman19 is offline   Reply With Quote
Old 02-14-2008   #12 (permalink)
burke420
The World Is Yours!
burke420's Avatar
thats why its prolly $12 retail.... so try it gearbox and you know what to do! b/c itlll work once the fluid is soaked into the adhesive.... itll Bounty away!
__________________
I MY Honda
Enkei RPF1
TEIN Hood Damper
FUNCTION7 LCA
Old 02-15-2008   #13 (permalink)
gearbox
Super Moderator
nice ill search around for that
__________________
www.lubecontrol.com
Member 1025782
The DX-Resource
Old 02-15-2008   #14 (permalink)
02BLKCIVIC
Official Rattlesnake Hunter
02BLKCIVIC's Avatar
02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of
sweet info here!!!
__________________
02BLKCIVIC is offline   Reply With Quote
Old 02-15-2008   #15 (permalink)
burke420
The World Is Yours!
burke420's Avatar
you betcha... i promise itlll work.. unless you got some painty areas on it too! but it's pretty durable and strong stuff...and just dont let it get into flames... it fun stuff and i accidentally blew up my old can...lol
__________________
I MY Honda
Enkei RPF1
TEIN Hood Damper
FUNCTION7 LCA
Old 02-15-2008   #16 (permalink)
pheaton
Post Master General
pheaton's Avatar
Gearbox your wheels are painted though right? You don't want something that is relabled paint thinner do you?
__________________
Old 02-15-2008   #17 (permalink)
gearbox
Super Moderator
i need to read the ingredients yea. if theres anything like there is in paint thinner/laquer thinner, i wont get it. like no acetone, etc.
__________________
www.lubecontrol.com
Member 1025782
The DX-Resource
Old 02-15-2008   #18 (permalink)
djmota
djmota's Avatar
djmota is just really nice djmota is just really nice djmota is just really nice djmota is just really nice
Just find somebody with a heat gun, borrow it. Get things nice and hot and scrape. it will come off nice and easy.
__________________
133.48 whp 117.57 tq all motor untuned dynojet
188.87 whp 187.99 tq 75 shot n20 untuned dynojet
147.5 hhp 130.5 htq all mtr tuned church's dynapack
my old d17 set up.
now swapped k20a2 4.7fd lsd kpro
djmota is offline   Reply With Quote
Old 02-15-2008   #19 (permalink)
pheaton
Post Master General
pheaton's Avatar
I'm thinking heat is a definate necessity. And like I said WD-40 might help things along.
__________________
Old 02-15-2008   #20 (permalink)
gearbox
Super Moderator
okay thanks. i have heat gun but no way to plug it in.. ill wait til summer then
__________________
www.lubecontrol.com
Member 1025782
The DX-Resource
Old 02-15-2008   #21 (permalink)
burke420
The World Is Yours!
burke420's Avatar
im telling you gearbox... we always use it and just dab it on the paper towel(bounty) and wipe away...dont try and splash it on there!
__________________
I MY Honda
Enkei RPF1
TEIN Hood Damper
FUNCTION7 LCA
Old 02-15-2008   #22 (permalink)
gearbox
Super Moderator
okay well if it strips the rims you can buy me new ones
__________________
www.lubecontrol.com
Member 1025782
The DX-Resource
Old 02-15-2008   #23 (permalink)
burke420
The World Is Yours!
burke420's Avatar
what are the sticker weights on the spokes... comeon... use lightly on a paper towel or rag...and rub till gone! when ive used it... ive never removed the paint from the wheels
__________________
I MY Honda
Enkei RPF1
TEIN Hood Damper
FUNCTION7 LCA
Old 02-16-2008   #24 (permalink)
gearbox
Super Moderator
okay will give it a try. i need to check a few more places.
__________________
www.lubecontrol.com
Member 1025782
The DX-Resource
Old 02-16-2008   #25 (permalink)
gearbox
Super Moderator
great +1 to you, 3m stuff stripped the whole foam and sticker right off lol. took about 10 mins for all four rims then i got sad when i saw all the screwdriver chips and scratches from the shop trying to pry the weights off
__________________
www.lubecontrol.com
Member 1025782
The DX-Resource
Old 02-17-2008   #26 (permalink)
Da1lyDr1ver
Platinum Member
Da1lyDr1ver has a spectacular aura about Da1lyDr1ver has a spectacular aura about
Send a message via AIM to Da1lyDr1ver
where did you end up findning the 3M remover? i need some of that for the same reason as you.
__________________
FOR SALE:
***OEM Honda Engine Block Warmer BNIB
***'01-'05 B&G S3 Full Coilovers
***RSX Front/Back Leather Seats (Tan)
***Autoguage Monster Tach
http://www.civicforums.com/forums/19...eats-tach.html
PM ME!!!
Da1lyDr1ver is offline   Reply With Quote
Old 02-17-2008   #27 (permalink)
gearbox
Super Moderator
farm and fleet, in the glue/epoxy section. i think a hardware store may have it in the paint section with all the other containers of acetone and stuff.
__________________
www.lubecontrol.com
Member 1025782
The DX-Resource
Old 02-18-2008   #28 (permalink)
02BLKCIVIC
02BLKCIVIC's Avatar
coooool
__________________
Tags
adhesive , civic , foam , honda , omaha , removal , remove , rims , si , sticker , stickers , tein , weight , wheel , wheels
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
poll: what oil filter do you use?
FAQ about oil, fuel addatives, filters, and more
don't use premium gas
Honda Recommended Lubricant list
10,000 mile oil change
100,000 Mile Service
Double Gas Mileage (Update Pg.5)
How to siphon gas out of our cars?
Fuel Pressure Regulator Installation
41 mpg~!!!!!!!!!!!!!!!!!!!!!!
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
