Go Back   Honda Civic Forum > GENERAL > Honda Civic Fuel, Oil, Cleaners & Other Maintenance
Reload this Page
Too much oil?
Honda Civic Fuel, Oil, Cleaners & Other Maintenance Extending the life of your Honda Civic requires the proper fuel, oil, and cleaners, along with other regularly scheduled maintenance. Keep your Honda Civic fuel and oil at the right levels to keep your Civic on the road longer.
LinkBack Thread Tools
Old 11-09-2007   #1 (permalink)
smoothdriver
New Member
smoothdriver is an unknown quantity at this point
Too much oil?
When I bought my Civic 2 weeks ago I was told by a friend that they normaly take a quart of oil per cylinder. So when I changed the oil I placed 4 quarts and a new filter into the engine. I found shortly after the the car was 1/2 a quart over the full line. One week later I read in the civic manuel that they take 3.5 quarts and that I put in 1/2 a quart too much. A diffrent friend said that having too much oil is bad because it could place unnessisary pressure on the seals and break them. My question is would having a 1/2 quart over full cause any damage to my engine and if so would it cause damage in as little as the week that it was over full? If there would be damage would it be to the seals alone or any other part? Thanx
smoothdriver is offline   Reply With Quote
Old 11-10-2007   #2 (permalink)
TRIZ
Hey! Look At Me!! I'm a Supporting Member!!Administrator
TRIZ's Avatar
TRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to behold
Re: Too much oil?
First off take the half quart out. Second dont listen to your friend.
Manual > friends
A half quart is pretty much the limit on what you should worry about. If you fill it up too much you have to worry about the oil pressure, and will actually give you less lubrication, confusing right.. If you fill it up too much, aka half quart+, the oil will start covering the crankshaft and it'll get whipped up. The oil and the small air bubbles will get pushed around and decrease the oil pressure to the moving parts. Result is wear on parts and lower fuel economy amongst others. Yeah you can have problems with your seals as well. Also "hydrolock"- basically the oil prevents the compression/decompression of the cylinder.
Its easy to take oil out. You can try draining it from the bottom and make a mess, or you can put a small tube down the dipstick space and carefully suck it till u get a flow and drain into a pan or bottle, then just raise the bottle above the cylinder head to stop the flow for a messless way to reduce the oil. When you drain, make sure the oil cap is off so it doesnt glug. Also if u think ur good, wipe the dip stick off, stick it in (with the tube out) and check the level. Should be dead center.
TRIZ is offline   Reply With Quote
Old 11-10-2007   #3 (permalink)
Alpha 5
Ultimate Member
Alpha 5's Avatar
Alpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questioned
Re: Too much oil?
My experience has been that a small amount of overfill (<1/2 quart over) will not hurt anything.
It reaches a point though, where the oil reaches the height of the rotating crankshaft, and this whips the oil into a froth. Oil with lots of air in it does not lubricate well. The result can be the same kind of problems you would have running a car without oil...e.g. bearing failure, catastrophic damange.
I personally am not familar with leaks resulting from overfilling. Can anyone who has seen these first hand please give us any details.
Alpha 5 is offline   Reply With Quote
Old 11-10-2007   #4 (permalink)
Boilermaker1
Jap-Euro Fusion
Boilermaker1's Avatar
Boilermaker1 is a splendid one to beholdBoilermaker1 is a splendid one to beholdBoilermaker1 is a splendid one to beholdBoilermaker1 is a splendid one to beholdBoilermaker1 is a splendid one to beholdBoilermaker1 is a splendid one to beholdBoilermaker1 is a splendid one to beholdBoilermaker1 is a splendid one to beholdBoilermaker1 is a splendid one to beholdBoilermaker1 is a splendid one to behold
Re: Too much oil?
I overfill it for the track, because beating on the car will burn a little off and it keeps the pickup submerged even in hard corners. I dont see 1/2 a quart hurting anything, but for reference, rules of thumb are useless, especially when there's a precise amount of 3.4 quarts for LX/DX and 3.7 quarts for the EX written in the owners manual.
Boilermaker1 is offline   Reply With Quote
Old 11-10-2007   #5 (permalink)
smoothdriver
New Member
Re: Too much oil?
good stuff.... thanx
Old 11-10-2007   #6 (permalink)
ultimatetuner10
Technical Assistant
ultimatetuner10's Avatar
ultimatetuner10 should not be questionedultimatetuner10 should not be questionedultimatetuner10 should not be questionedultimatetuner10 should not be questionedultimatetuner10 should not be questionedultimatetuner10 should not be questionedultimatetuner10 should not be questionedultimatetuner10 should not be questionedultimatetuner10 should not be questionedultimatetuner10 should not be questionedultimatetuner10 should not be questioned
Re: Too much oil?
I alwyas put 4 quarts into my car...and no its not a quart per cylinder..my old v6 took 5 quarts for example
ultimatetuner10 is offline   Reply With Quote
Old 11-11-2007   #7 (permalink)
rutscivic
Senior Member
rutscivic's Avatar
rutscivic is an unknown quantity at this point
Re: Too much oil?
nothing wrong with 4 quarts
rutscivic is offline   Reply With Quote
Old 11-11-2007   #8 (permalink)
beadebaserr
Super Member
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
Re: Too much oil?
i always did 4 quarts in my d17 when i had it, and when i'd check it, the oil would be right on the top dot and not past.
beadebaserr is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
poll: what oil filter do you use?
don't use premium gas
FAQ about oil, fuel addatives, filters, and more
Double Gas Mileage (Update Pg.5)
10,000 mile oil change
post your mileage
41 mpg~!!!!!!!!!!!!!!!!!!!!!!
Cabin Filters
Honda Recommended Lubricant list
exxon/mobil vs chevron
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
