Honda Civic Fuel, Oil, Cleaners & Other MaintenanceExtending the life of your Honda Civic requires the proper fuel, oil, and cleaners, along with other regularly scheduled maintenance. Keep your Honda Civic fuel and oil at the right levels to keep your Civic on the road longer.
Welcome to civicforums.com!
Welcome to civicforums.com.
just a friendly reminder, change youre damn coolant. its so easy to do, takes like five minuets. dont even have to jack the car up. drain on the bottom of the radiator in front of the driver. Open it up and open the cap, with the engine cold of course. let it drain into a catch pan or something. while thats draining change your cabin air filter, its probably gross as hell, instructions are in your owners manual, you need two filters and they are cheap you can even get them at napa if you dont like your dealer. I would recommend sticking with honda coolant, nothing else is better. Once the radiator is drained (it takes a few minuets) close the drain and fill from the top. It takes less then one gallon, once it gets full leave the cap off and start the car, let it run for about 30 secconds and top it off. put the cap back on, take the old coolant to an auto zone or something to get it recycled, and youre done. max time including getting stuff and gatting rid of the coolant, 1 hour. have fun
Sponsored Links
What about coolant in engine block? No need to drain it?
If you can get that bolt off the back of the block then go ahead. Otherwise once the old fluid is drained from the radiator, fill it with water, let it run for about 10 minutes, then drain it, fill it again with water, let it run 10 min, then drain and fill with coolant. This way it should remove most of the coolant from the block.
__________________
Quote:
Originally Posted by AggressiveAdam
hah yes the K series will make your car fly.
Quote:
Originally Posted by McFLYsi
just got pulled over the other day for having JDM yellow headlights, the cop told me it was illegal to have yellow lights, only white, any comments on this. i was just sittin in my slab with trunk poppin and my candy paint drippin off my doors.
benificial but not really necesary, you should be doing a radiator drain every two years tops anyway so getting most of it out (around 80%) is plenty good. youre doing the same thing with oil when you change that
Manual says to replace coolant every 120,000 miles (192,000kms) or 10 years,
then every 60,000 miles (96,000 km) or 5 years. Why are you changing it so often? I assume you are using Honda type II coolant which is premixed. Used to be green now blue in color.
The engine block drain bolt is tight like a bitch.
Can I only drain the radiator and refill without draining the engine block?
