Go Back   Honda Civic Forum > GENERAL > Honda Civic Fuel, Oil, Cleaners & Other Maintenance
Honda Civic Fuel, Oil, Cleaners & Other Maintenance Extending the life of your Honda Civic requires the proper fuel, oil, and cleaners, along with other regularly scheduled maintenance. Keep your Honda Civic fuel and oil at the right levels to keep your Civic on the road longer.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 04-29-2005   #1 (permalink)
robbclark1
Retired suspension supermod.
robbclark1's Avatar
robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold
Send a message via AIM to robbclark1 Send a message via MSN to robbclark1 Send a message via Yahoo to robbclark1
60k - what should be done?
In 10k I will be at 60k. I want to prepare for what I am going to have to do
Flush radiator and refill
Flush brake fluid - replace with ATE Superblue
Change MTF - replace with Honda MTF
Change rear pads - replace with Honda pads
Change clutch fluid - what should I replace it with??
Change power steering fluid - change to redline??
Oil changes are on a different schedule so what else do you suggest? Belts are good to 100k right? Plugs were changed at 20k with Iridium. What else? S2kman??
__________________
Life isnt a test drive, gotta live a little. (02fpcivic)
Suspension FAQ
Autocross FAQ
If you pretend that cars are moving cones, then the roads become your personal autocross course.
I live my life 1 cone at a time, for those 70 seconds or less, I'm free
Thanks to ALPHSTER for the sig!
robbclark1 is offline   Reply With Quote
Sponsored Links
Old 04-29-2005   #2 (permalink)
ImPulse
ImPulse's Avatar
ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse
no1 cares about your car
ImPulse is offline   Reply With Quote
Old 04-29-2005   #3 (permalink)
chrisleecool
Ultimate Member
chrisleecool's Avatar
chrisleecool has a spectacular aura about chrisleecool has a spectacular aura about
Send a message via AIM to chrisleecool Send a message via MSN to chrisleecool
Quote:
nah...j/k
I'm about to hit 60k soon
and i have no clue how to prepare ...
__________________
WTB
15'' steelies with tires /15'' alloy wheels (Si/EX)
16'' wheels/tires
willing to trade my 18'' adr db8 w/ HRII tires 215/40/18
cHris
chrisleecool is offline   Reply With Quote
Old 05-01-2005   #4 (permalink)
robbclark1
robbclark1's Avatar
bump...anyone?
__________________
Suspension FAQ
Autocross FAQ
Old 05-01-2005   #5 (permalink)
S2000man01
O RLY
S2000man01's Avatar
S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold
Send a message via AIM to S2000man01
If your manual says to change those fluids, then you should change them. Brake pads don't need to be changed unless they are actually low.
As for what fluids, honestly, your civic manual will tell you exactly what to use. There are specifications set by the API for example and other such agencies, and honda will specify which fluids to use.
__________________
S2000man01 is offline   Reply With Quote
Old 05-01-2005   #6 (permalink)
robbclark1
robbclark1's Avatar
bah, i lost my manual! haha
I was thinking about upgrading powersteering and clutch fluids if it won't hurt the car, because of autox. Rear shoes need to be changed. Front pads have plenty of time to go. Have to factor in the abuse from autox, so I want fluids to be good. I know MTF should be Honda.
__________________
Suspension FAQ
Autocross FAQ
Old 05-02-2005   #7 (permalink)
riceburnrex
First to spool
riceburnrex's Avatar
riceburnrex has disabled reputation
-Yes
-Good choice
- Actually, use Redline MTF. Your transmission will shift better and last longer.
- Only if needed.
-DOT 4 brake fluid, make sure you flush and bleed it properly
-Honda power steering fluid is just fine
- Stick with what you've been doing, around 3000 miles
- Look at them, if they look worn or are starting to fray, replace them. Gates belts work great as well as Honda belts
-NGK's are cheaper and work just as well. Just use NGK next time
What else?
- Tires, obviously. Alignment. Fuel filter if it hasn't been done already, check your intake air filter (clean it if it;s a K&N)
You should be good to go after that.
__________________
01 Civic EX Turbo, 10psi of fun.
If you haven't lifted the head off of the block, you're not racing fast enough.
riceburnrex is offline   Reply With Quote
Old 05-03-2005   #8 (permalink)
DestnationUnkwn
Senior Member
DestnationUnkwn's Avatar
DestnationUnkwn is an unknown quantity at this point
Put superblue in your clutch too, it uses the same fluid your brakes do why buy different fluids just use your leftover superblue to do the clutch too.
DestnationUnkwn is offline   Reply With Quote
Old 05-03-2005   #9 (permalink)
HondaLuver
Its a celebration bitches!
HondaLuver's Avatar
Send a message via AIM to HondaLuver
get a new engine, hehe, thats what i did at 60k...
__________________
01 SSM em2 k24 hybrid
06 Red CBR600RR
Status:
01 SSM em2 built k24bar'd NA tune(till turbo time)...240.7 hp and 190.9 tq
Stuff for sale
HondaLuver is offline   Reply With Quote
Old 05-03-2005   #10 (permalink)
robbclark1
robbclark1's Avatar
Quote:
-Yes
-Good choice
- Only if needed.
What else?
Thanks. Oil is every 7500k with Amsoil synthetic. Alignment is currently on the fritz since I had my coils taken off, but I get alignments mroe often than I probably need....damn autox. haha. Never thought of the fuel filter.
I was always told not to use redline in our trannies because the sychros will go bad...?
__________________
Suspension FAQ
Autocross FAQ
Old 05-04-2005   #11 (permalink)
Skunk2ner
Diamond Member
Skunk2ner's Avatar
Skunk2ner is an unknown quantity at this point
transmission fluid doesn't need to be changed till 120k miles (according to chiltons). but since you autox and drive hard, i suppose it would be nice to give a change.
check belts and hoses for wear.
Skunk2ner is offline   Reply With Quote
Old 05-04-2005   #12 (permalink)
scansel912
Platinum Member
scansel912's Avatar
scansel912 is just really nice scansel912 is just really nice scansel912 is just really nice scansel912 is just really nice
Send a message via AIM to scansel912
According to honda, coolant doesnt' need to be changed until 120,000 miles.
__________________
B18C1 Powered 1992 Honda Civic Si
scansel912 is offline   Reply With Quote
Old 05-04-2005   #13 (permalink)
robbclark1
robbclark1's Avatar
Ok, well my two questions are
What power steering fluid should I use? Honda or Redline...
What MTF should I use? Honda or Redline...
I have been told conflicting messages. Thank you.
__________________
Suspension FAQ
Autocross FAQ
Old 05-04-2005   #14 (permalink)
riceburnrex
First to spool
Quote:
Dad's commuter 2002 ex with 145k miles has used Redline for most of it's life, tranny is perfect. My 01 turbo that auto-x's and road course races has had redline since the day after I bought it, no problems. Honda says not to, but I haven't seen anyone using Redline have any problems that would be related to the fluid. A lot of the local road course guys that use various year Hondas swear by Redline MTF, same with the Porsche and Miata guys I race with.
Destinationunknown- The only reason I don't say to use ATE superblue in the clutch is that it is much more expensive than DOT4, and you have to use a decent amount to completely flush out the original fluid and bleed. The clutch line is not a line that you have to worry about boiling the fluid like the brakes (unless you ride the clutch like no other). Super Blue will work, but it's not necessary. But if you have enough left over- by all means use it.
__________________
Old 05-05-2005   #15 (permalink)
S2000man01
O RLY
S2000man01's Avatar
redline is good, but i think redline doesn't do well with CF synchros, which i dont think the civic has.
so use whichever you want. if you have not heard from anyone who actually USES redline tranny fluid then stick with honda.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
addicted to driving? gearbox Off Topic 31 04-13-2005 08:39 AM
a pretty good sign that the new Supra will have a V8 Hawk General Automotive Discussion 29 03-31-2005 07:47 PM
New BMW M5 pics!!! Silversleeper General Automotive Discussion 38 10-18-2004 01:54 AM
5 speed fluid change JDog Honda Civic DIYs and Civic Tech Chat 13 03-31-2003 08:51 PM
Trans fluid ? Hefe Mechanical Problems/Vehicle Issues and Fix-it Forum 8 12-25-2002 10:18 PM
User Login
Our Partners
used new
Top 10 Threads
poll: what oil filter do you use?
FAQ about oil, fuel addatives, filters, and more
don't use premium gas
Honda Recommended Lubricant list
10,000 mile oil change
Double Gas Mileage (Update Pg.5)
100,000 Mile Service
How to siphon gas out of our cars?
41 mpg~!!!!!!!!!!!!!!!!!!!!!!
post your mileage
Site Supporters
aluminum radiator
Honda car spoilers
