Go Back   Honda Civic Forum > GENERAL > Honda Civic Fuel, Oil, Cleaners & Other Maintenance
Honda Civic Fuel, Oil, Cleaners & Other Maintenance Extending the life of your Honda Civic requires the proper fuel, oil, and cleaners, along with other regularly scheduled maintenance. Keep your Honda Civic fuel and oil at the right levels to keep your Civic on the road longer.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 03-25-2005   #136 (permalink)
Jrfish007
Jrfish007's Avatar
Jrfish007 is a name known to all Jrfish007 is a name known to all Jrfish007 is a name known to all Jrfish007 is a name known to all Jrfish007 is a name known to all Jrfish007 is a name known to all Jrfish007 is a name known to all
Send a message via AIM to Jrfish007
Quote:
Originally Posted by gearbox
My car shakes back and forth at idle in drive when I slightly let go of the brake. Is this due to octane or just a higher compression problem with the head? Can you feel knocking or detonation?
detonation=knocking=pre-ignition, more or less the different words to describe all the same thing.
As for feeling it, I felt it once in my Camaro, but thats a 393 ci (6.4L) motor and it really wasn't that much, so I would guess with a 1.7L motor you wouldn't feel it, but at low RPM (below 3000) you will hear it. You say this is when you put it in gear and let go the brake and start moving, this sounds more like the engine is bogging down to me. If I remember your car right, you have an auto with a built head. My guess is that the idle needs to be brought up a tad. Sounds like the idle is to low, so when you put it in drive and give it gas, the engine just not producing enough power to push the car at the RPM it's at. That just what I think it sounds like, I had that problem on an older truck I had.
Jrfish007 is offline   Reply With Quote
Sponsored Links
Old 03-25-2005   #137 (permalink)
pon55
Ultimate Member
pon55's Avatar
pon55 is just really nice pon55 is just really nice pon55 is just really nice pon55 is just really nice
Send a message via AIM to pon55
Quote:
Originally Posted by Jrfish007
^^^lol, that's not like to give up that easily. Anyway, most people think all Hondas run lean, you are not alone. I must have explained this to 25 people now, no big deal.
I never give up! I talked to the honda factory tech that told me this. He said the engine should run lean, Lean meaning opposite of rich. Not as in very lean.
He says the computer is designed to provide a mixture of perfect mixture to lean, but not to rich except if the temperature goes very high!
__________________
Civic minded old man/ low-loud-loven it!
http://www.myspace.com/pon55
RIP Diana,forever in our hearts and prayers.
pon55 is offline   Reply With Quote
Old 03-25-2005   #138 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Jrfish007 that's right. If I turn the ac on and the rpm goes up 100-200, the shaking stops completely. I've tried to up the idle from stock 700rpms, but I can only do 50rpms higher before the cel comes on.
pon55, this is my a/f ratio before and after tuning. Also note the car is not stock. That rich spike in the lower rpms is still there after pnp head work and header. So yes it does run very rich in stock form. Others who had tuning said the same thing. Around 3k is when it starts to lean out, so if you do alot of driving in the city and only take it to 3k, you'll always be running rich.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 03-25-2005   #139 (permalink)
Jrfish007
Jrfish007's Avatar
Yeah, I wouldn't trust a tech with more than a my dog's chew bone. Some of them really do know what they are doing, others are not that bright. I used to have a B16A in a '94 civic. I blew the head gasket in the middle of winter, figured I didn't want to deal with it in the middle of winter (about 10F out side), so I took it the dealer to have it done. I told the tech it needed a head gasket from a 1999 Civic Si, he said "but you have a '94 DX." I said I swapped the motors, he told me that was impossible, so I took him out side, showed him the engine in the car, he told me "you have preformed to many modifications to that D15 (D15 is the stock motor and it was a stock B16) and because of that they could not work on it." I went home and did it myself, I decided then that I would never let them do anything to my cars unless they showed me they knew something about cars. Sorry for the rant, but it still bugs me 4 years later, that the tech could even tell it was a B16A.
Old 03-25-2005   #140 (permalink)
Jrfish007
Jrfish007's Avatar
what's the cel?
How did you try to up the idle? There are a couple of way to do it.
Old 03-25-2005   #141 (permalink)
gearbox
Super Moderator
Check engine light (malfunction). I turned the idle screw to make the throttle plate open more.
__________________
www.lubecontrol.com
Member 1025782
Old 03-25-2005   #142 (permalink)
Mrs014dr
Super Member
Mrs014dr's Avatar
Mrs014dr is an unknown quantity at this point
Send a message via AIM to Mrs014dr Send a message via Yahoo to Mrs014dr
Now I dont feel bad for using 87
__________________
Rolling on Mugens All Day, What Do You Got??
Mrs014dr is offline   Reply With Quote
Old 03-25-2005   #143 (permalink)
S2000man01
O RLY
S2000man01's Avatar
S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold S2000man01 is a splendid one to behold
Send a message via AIM to S2000man01
most hondas, due to their higher revving nature, run quite rich in the top rpm range. the S2000 itself runs a very rich 11.5:1 in the last 1000rpm or so.
at idle, the cars run VERY lean, as much as 17:1.
in general they run a bit rich if you mash the gas starting low rpm, lean out in the middle, and back to rich in the top end.
__________________
S2000man01 is offline   Reply With Quote
Old 03-25-2005   #144 (permalink)
S2000man01
O RLY
S2000man01's Avatar
lol did you show him the big ass engine stamp that said B16?
__________________
Old 03-25-2005   #145 (permalink)
gearbox
Super Moderator
Ha oops I misread the a/f on that dyno. It's lean below 3k then starts to get rich in higher rpms
__________________
www.lubecontrol.com
Member 1025782
Old 03-25-2005   #146 (permalink)
Derek-CEO
7thGen Junkie
Derek-CEO should not be questioned Derek-CEO should not be questioned Derek-CEO should not be questioned Derek-CEO should not be questioned Derek-CEO should not be questioned Derek-CEO should not be questioned Derek-CEO should not be questioned Derek-CEO should not be questioned Derek-CEO should not be questioned Derek-CEO should not be questioned Derek-CEO should not be questioned
if ur a premium member, check out this weeks premium news
http://www.7thgencivic.com/forums/sh....php?p=2889819
some inetersting tips in there about gas mileage, especially the one about using acetone?
Derek-CEO is offline   Reply With Quote
Old 03-25-2005   #147 (permalink)
gearbox
Super Moderator
Hmm maybe but acetone eats away plastic...but if it's diluted enough it might not. I sure wouldn't try it. Okay after reading some of that, I would not really try any of those things. Nothing has been proven to last, just to give better mileage. Best thing you could do is throw in some water remover like iso heet to take care of that. I wouldn't go nuts adding stuff to your gas and oil like that.
__________________
www.lubecontrol.com
Member 1025782
Old 03-25-2005   #148 (permalink)
Derek-CEO
7thGen Junkie
rather discuss those findings in that thread.
Old 03-25-2005   #149 (permalink)
senseiturtle
Senior Member
senseiturtle's Avatar
senseiturtle is an unknown quantity at this point
huh? lean makes the engine heat up?
I was sorta wrong, and sorta right.
The air injection system doesn't put air in the engine... it puts it into the exhaust tract.
Quote:
Originally Posted by VW service training self-study program. Booklet number 406
The purpose of the air pump is to reduce exhaust emissions during engine warm up when the engine management system is in open loop. When the engine is first started and the engine coolant temperature is between 15 degrees and 35 degrees C (58 degrees and 95 degrees F), the air pump will operate. The air pump operates for 65 seconds and then shuts off. The pump forces a calibrated amount of air into each exhaust port. The additional air provided by the pump helps the catalytic converter to reach operating temperature faster. This enables the catalytic converter to reduce exhaust emissions during the engine warmup phase even though the Motronic engine management system is in open loop."
They go through a description about open-loop operation, but I'm not sure they employ it on later MKIV VW's. This manual was from 1993.
Therefore, you're right. You don't run lean when the air pumps on. I was right on the purpose of the system, to warm up the cat faster.
__________________
2006 Scion tC
With header and hacked airbox- 15.36@89.15
new setup, in progress- injen/CCspipe/magnaflow/NST pulley/hotchkis springs, sways/ingalls/race rubber... An STS car that runs 14's in the 1/4, while staying emissions legal and dead quiet.
senseiturtle is offline   Reply With Quote
Old 03-25-2005   #150 (permalink)
pon55
Ultimate Member
pon55's Avatar
__________________
Tags
1995 , 2001 , 2002 , civic , crv , fuel , gas , honda , kind , preminum , premium , put , putting , recommended , turbo
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
Terrible Gas Mileage dustin_samuel Mechanical Problems/Vehicle Issues and Fix-it Forum 21 06-16-2005 03:06 PM
Premium gas is a treat for our cars, right? FurBall Canada East 11 06-15-2004 08:09 PM
Sorta rough idle when first started in morning flotsamm Mechanical Problems/Vehicle Issues and Fix-it Forum 12 12-29-2003 03:31 AM
horsepower please realitycheck Other Honda Civic Parts and Products 30 10-05-2003 07:42 PM
6100 miles gas mileage report - dissapointing Roosbok General Automotive Discussion 24 06-17-2002 04:57 PM
User Login
Our Partners
used new
Top 10 Threads
poll: what oil filter do you use?
FAQ about oil, fuel addatives, filters, and more
don't use premium gas
Honda Recommended Lubricant list
10,000 mile oil change
Double Gas Mileage (Update Pg.5)
100,000 Mile Service
How to siphon gas out of our cars?
41 mpg~!!!!!!!!!!!!!!!!!!!!!!
post your mileage
Site Supporters
aluminum radiator
Honda car spoilers
