Troubleshoot Help
Rep Power: 0 Troubleshoot Help
I recently purchased an 03 civic ex coupe, has the d17a2. Here is the problem, it has trouble starting up initially. Sometimes I have to turn it over 3-5 times for extended periods before it will start. If I pump the gas pedal, you can hear it attempting to fire. When I get it to fire, it runs rough until I give it some throttle. After that, it runs like a dime, no idle issues, no loss of power. If I shut it down after it has been running, it will fire back up right away with no problem. If I let it sit for longer than 5 minutes, it gives me trouble starting again. I got the guys at the auto parts store to pull the engine codes, and I had a misfire in cyclinder 3, so I replaced the plugs. Also I had a code for engine coolant temp sensor. I proceeded to check the thermostat, which was gutted, so I replaced that as well. I believe I have eliminated possibly of fuel delivery issues by shooting some starter fluid into the intake, which made no difference in the starting issue. Any and all help is appreciated.
Re: Troubleshoot Help
Side question: Is the radiator low, and the reservoir high?
JetsterDajet
52
05-08-2016 12:11 AM
redej2
04-29-2015 01:47 PM
909
03-26-2005 10:31 PM
