pump or relay?
Rep Power: 0 pump or relay?
I have a 92 civic hatchback. It was running fine when I last left it 3 years ago. Of course it's been a long time, but now back and trying to get it to crank. I can't seem to get anyone local to find time to help. I've replaced gas, battery, spark plugs, distributor rotary button, oil change and filter. The starter and everything seems to try but no full start. I've pretty much narrowed it down to the fuel pump and relay as even suggested talking with a friend. So how can I tell which I need to deal with. Any help would be greatly appreciate before I spend more time and money on something not needed fixed. Lastly if I need to replace the pump, should I go with a performance fuel pump? Suggested brand and best place to order from? I got a b16a for now but no big mods to it yet. Thanks
Re: pump or relay?
Pop a fuel line loose from the filter and have someone turn the key on briefly. If the pump runs it should spray fuel out.
Are the plugs wet with fuel? If they are wet then it's getting fuel into the engine. If dry, then not.
Then see if the injectors are clicking? Maybe they are stuck from sitting.
Maybe you have a main relay shot.
Maybe the ECM can't turn the main relay on.
Voltmeter checks at the tank connection should give the answer about if the pump is getting powered up.
Re: pump or relay?
Pull the back seat up, there should be an access cover for the pump and wiring.
Re: pump or relay?
There's a couple different versions of the main relay. I can't tell which would be in that car. Here's a very basic
Rep Power: 0 Re: pump or relay?
I pulled the relay and looks like one on the left. Without a number 4 pin. But its been so long since i was in electronics class, so I'm gonna sound like a fool but how can i check it? I know thiis. Bad but pretty much need a step by step, hold my hand thing here lol. I just still dont see what be problem when it was fine before. Just been years not cranked :/
Re: pump or relay?
#1) did the fuel spray out when the line was loosened at the filter and key cycled?
If it did, then the pump runs, the main relay may be ok, and your problem is something completely different?
^^^Maybe you don't need to do anything yet--See the first line above^^^
It's like falling off a bicycle, once you learn you aren't supposed to forget it!
I do almost all testing on live circuits, by backprobing the connector. I do very little out of circuit.
First step is getting a wiring diagram and see how it all works.
Find the pump feed terminal at the relay, it supplies B+ to the pump when the relay is turned on...... I'd connect a test light on that terminal and leave the light on it for now (I have several test lights)
Smack the bottom of the tank a few times, maybe the pump motor is stuck from sitting.
But if fuel sprayed under pressure like in the first line of this reply, the pump is not stuck.
I know thiis.
mjdiaz89
06-21-2016 09:26 PM
Kyles24
07-12-2015 09:15 PM
