Which transmission fluid 93 Del Sol auto
Rep Power: 0 Which transmission fluid 93 Del Sol auto
Just bought a 93 Del Sol auto. trans What is the best fluid to use when changing? Book says Dex II will Z1 or newer Honda fluid be better? thx
Re: Which transmission fluid 93 Del Sol auto
Dexron 2, 3, or 6 (6 replaces all previous versions and is synthetic AFAIK)
Or Hondas DW-1. Also synthetic, and replaces all previous versions of ATF for Hondas.
All can work ok.
All can work ok.
Oh, I need to backpedal here.
Direct quote from another professional forum:
"Dexron VI was specifically developed to be backwards
compatible with previous GM transmissions. It was NOT
developed or tested to replace dexron III or any previous
dexron fluids in any or all of the many other applications
where dexron III is used."
Sorry about that.
Use at your own risk.
mattdoc
03-14-2017 12:10 PM
Datsun82
07-09-2015 03:34 PM
