Gas tank cleaning (Civic LX 2002 2dr)
Old 06-08-2011
Moshe1010's Avatar
Moshe1010 is an unknown quantity at this point
Hello,
I was wondering if I need to clean my gas tank every X months/years?
I was at Jiffy Lube to change my oil and filters, they said because my car doesn't have cleaning system in its gas tank I'll need to clean it manually.
Is this true? Can I use one of the injector cleaners out there or should I take out the gas tank, clean it, and put it back?
Thanks.
Old 06-08-2011
lowlife9's Avatar
Re: Gas tank cleaning (Civic LX 2002 2dr)
lol i have never cleaned a gas tank in my life on any of my cars but you should replace the filter if need be. now if your storing the car for extended amounts of time you should keep the tank full of gas and ad some sta-bil fuel stabilizer to the gas. by the way your fuel filter is located in the tank which is a pain in the azz to replace but its well worth it.
Old 06-09-2011
Moshe1010's Avatar
Yea I was thkinking that this is BS to get more money, but you'll never know for sure till you ask.
What do you mean by "storing the car for extended amounts of time", I'm driving my car, at least 5 days a week for 10-15 miles.I was reading about BG 44K, any good?
Old 06-09-2011
lowlife9's Avatar
i mean if your storing your car for months at a time if you leave the tank empty and don't use sta-bil rust can form in the tank. and why exactly do you feel the need to use injector cleaner im assuming the mechanic suggested BG because most of them do. i personally only use LUCAS injector cleaner and upper cylinder lube on my car its not a harsh solvent like that bg stuff and it lubes the fuel pump. best of all you can get a large 32oz bottle at walmart for 10 bucks. i also have used AMSOIL products in the past including there oil but there really hard to find locally and cost an arm and a leg.
Old 06-09-2011
Moshe1010's Avatar
Thanks for your help.
Old 06-09-2011
sl33pyriceboi's Avatar
Your car has a fuel filter right after the fuel pump. But you don't need any kind of cleaning for it unless u leave the fuel unused for a year + (because mosisture gets in ur tank after a long period of time)
Old 06-12-2011
green01civic's Avatar
green01civic will become famous soon enoughgreen01civic will become famous soon enough
When you're looking for a fuel injector or fuel system cleaner, you want to be sure that it is high in PEA.
Techron Concentrate Plus: 30-60% PEA (according to MSDS)
Red Line SI-1: 30-50% PEA (according to MSDS)
Most other cleaners, fuel system or fuel injector cleaners, are a mix of aromatic hydrocarbons (xylene, toluene, etc.), alcohols, petroleum distillates (napthalene, etc.), and/or other garbage.
As for BG44k, it is allegedly high in PEA (that's the rumor), but they're either hiding it on their MSDS, or it's BS. Either way, I'd go with Red Line or Techron Concentrate, cause at least you know what you're getting there.
CarStuff
12-06-2020 12:52 PM
McD
04-29-2015 03:50 PM
chgofirefighter
04-18-2015 08:08 PM
Gunner
Engine DIY
10-06-2012 12:37 PM
jonavin
73
10-04-2004 07:18 PM
Quick Reply: Gas tank cleaning (Civic LX 2002 2dr)
