DTC P0947 EVAP system low purge flow
Old 05-08-2011
metalshredder's Avatar
metalshredder is an unknown quantity at this point
Uhh.....WTF?
So, Autozone shows an EVAP valve.... nobody really shows the evap canister, and by the way, is the canister that little filter thingy by the gas tank that Gearbox cut open in his "forgotten tune up" thread?
I changed the gas cap, since I looked and it WAS bad; EVAP code still came back.
Any suggestions?
Old 05-08-2011
Re: DTC P0947 EVAP system low purge flow
no, that is the air filter. the charcoal canister is a different part to trap fuel vapors. low purge is usually related to a faulty evap valve (not opening to send gas vapors to the engine) located near the throttle body.
Old 05-08-2011
Is that the 50 something dollar part that AZ is showing me here?
http://www.autozone.com/autozone/par...79057_0_0_1095
Old 05-08-2011
yup.
Old 05-09-2011
Could I possibly clean this thing with some carb cleaner and have a chance of it working again?
Old 05-09-2011
carb cleaner will ruin plastics. you could try electric parts cleaner or MAF sensor cleaner.
Old 05-09-2011
A friend may have a can of MAF cleaner...
Old 05-17-2011
Passed emissions yesterday!!!!!!
It only took a downstream O2 sensor, a set of (the right) plugs, and a purge valve.
Not a new cat, like some of the mechanics told me.
Old 05-17-2011
sweet. did you need a new purge valve or was the old one fine after cleaning...
Old 05-17-2011
I just bought a new one. it was like $35 at the dealer, I figure if it's that cheap why screw around?
Oh, I took some pics too, just gotta get off my lazy *** and post them...
Old 11-30-2011
kamran123's Avatar
kamran123 is an unknown quantity at this point
HELLO I HAVE A 2006 HONDA CIVIC AND IM TRYING TO FIGURE OUT WHERE DOES THE EVAP PURGE VALVE SOLENOID LOCATES AT, I LOOKED ALL OVER THE CAR CAN U HELP ME OUT, PLEASE i need to replace the part help me
Old 11-30-2011
If the 06 car is the same body as the 04, then this part is attached to the throttle body, you'll have to remove the complete air cleaner. If I remember right, it was a pretty straight forward part swap.
Cajunkev1
04-03-2017 04:32 PM
7thgensurvivor
38
08-29-2015 11:50 AM
lilrob1213
37
06-29-2015 06:45 PM
Reverb2005
06-26-2015 06:22 PM
plastikman
Bolt-on Engine Performance
12-13-2001 03:18 PM
Quick Reply: DTC P0947 EVAP system low purge flow
