Engine runing but car the won't go anywhere - Honda Civic Forum
Go Back   Honda Civic Forum > GENERAL > Fuel, Oil, Cleaners & Other Maintenance
LinkBack Thread Tools Search this Thread
Old 11-21-2010   #1
shanksnorth is an unknown quantity at this point
Hi,
I have a 2002 honda civic automatic transmission and I was driving yesterday and everything was OK. But in the middle of the drive, when i tried to accelerate to faster speeds say from 40 to 60 the the engine would just rev up but i could not get the speed. I could feel as though it did not shift into a higher gear. I did not give much importance thinking it may be due to icy roads.
So I drove further for 10 mins and I had stopped at an intersection. Then I tried to drive but the car won't move enven though the engine was running. So I was stalled in the middle of the road during which i called the tow truck. But after say 15 mins I tried to run and i was able to drive for another 5 mins and then stalled. The engine was still running but car wont move. It was also not the case of tires spinning in ice. So finally I had to get it towed.
So can someone suggest what's the problem with the car stopping but engine still runing? I checked the transmission fluid and its OK. Thanks in advance!!
shanksnorth is offline   Reply With Quote
Old 11-21-2010   #2
Live for the Twisties
MindBomber's Avatar
Re: Engine runing but car the won't go anywhere
The 7thgen civics auto trans is defective, this exact problem has happened to many members. Unfortunately, your looking a repair that will cost thousands.
Search around a bit, you'll see this has happened to many many people.
MindBomber is offline   Reply With Quote
Old 11-23-2010   #3
FrAnKeNsTeIn
BluJay's Avatar
BluJay is an unknown quantity at this point
Failsafe mode? have you tried resetting the ECU and seeing if the problem comes back?
OBII? What codes have you thrown?
Checked the trans fulid? does it look like milkshake or dark and dirty?
It might be defective but its worth checking and trying to save it for as long as you can.
BluJay is offline   Reply With Quote
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
2008 crv Ac issues... usajags84 General Automotive Discussion 5 05-10-2015 08:11 AM
My 7th Gen 1 year anniversary bsmiley 7th Generation Civic 3 04-27-2015 01:27 PM
Turn the key, doesn't even crank TheCrimsonKing Mechanical Problems/Vehicle Issues and Fix-it Forum 12 04-25-2015 09:40 PM
06 Civic EX Not Starting - Any Suggestions SSMatey Mechanical Problems/Vehicle Issues and Fix-it Forum 4 04-13-2015 06:09 PM
DIY. Check for spark / Car won't Start. Gunner Engine 3 10-06-2012 12:37 PM
Tags
2000, 92, anymore, automatic, car, civic, control, drive, engine, gears, honda, move, rev, running, runs, trans, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
vBulletin Skin by ForumTemplates.com
All Content Copyright 2007 CivicForums.com
