You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Fuel, Oil, Cleaners & Other MaintenanceExtending the life of your Civic requires the proper fuel, oil, and cleaners, along with other regularly scheduled maintenance.
I just turned over 120,000 miles. I just got my timing belt, water pump, and battery changed out. Besides that nothing but oil change every 3-5k. What else am I needing to change or fluids that need flushed. BTW my blinkers stopped working after I hit a pole with my left front headlight and the turning signal is now busted. Now none of my turning signals work. Would it have something to do with the hit or is it something else?
prolly shorted out the turn signal in the front and blew a fuse. also you should be at least changing the other fluids that are all way overdue. brake fluid every 3 yrs (does not depend on mileage), PS fluid every 50k, trans fluid every 10k-30k, coolant every 50k, etc.
Yeah. I need to get on that PS flush myself. That's like the only fluid in my car that hasn't been changed yet in the year I've had it.
__________________ 2000 Civic Si- Short ram intake. Yeah. Rollin' in the mods, kid.
Brakes-These slow the car down!
Break-This is what twigs and sticks do!
Quote:
Originally Posted by lazlong
*Before any of ya say "WTF does VTEC have to do with a hard start?" I'll tell ya I got it straight from the manual and have no idea.
since 50% of the fluid is in the reservoir, its much easier to just pull one hose and pour the reservoir fluid into a cup. then fill up with new honda fluid. go for a drive until car warms up and make several full turns in each direction to bleed the air out, then leave the car overnight. in the morning, check the fluid level and most likely it will be at min. just fill to max and youre done. a week later you can do it a second time to replace more fluid. alot of guys also just use a turkey baster to suck the old fluid out instead of disconnecting the hose.
