How many quarts?
Rep Power: 222 How many quarts?
Well I'm going to be changing my oil in about 30 min. I have a 2003 Honda Civic EX 5SPD. Does anyone know how many quarts goes in? I searched and got different answers like 3.5, 3.7, 3.8, and 4.0 quarts. So I was really unsure on how much oil goes in. I bought 4 quarts of Mobil 1 5w30 and fram oil filter. I pmed some of the mods and one of them recommended me to start a thread.
The World Is Yours!
Originally Posted by burke420
exactly what i used in my last oil change at 4 qts, i always use 4, for 75000 miles so far. and a Fram oil filter, gray one.
Rep Power: 583 I can't remember, but I think my manual says 3.4. I just dump in 3 1/2 quarts. Start it up and let it run for about 20 seconds. Let it sit for about 30 min. check the oil level, if it needs any, then add. Check it again the next morning after sitting overnight.
Don't be a n00b, search ftw
Rep Power: 322 I used to work at Wal-Mart Tire and Lube. The D17A2 (VTEC) D17 takes 3.8 Qts Including filter. I just dump 4 quarts in it. It won't hurt to have .2 more quarts in it.
Rep Power: 285 i just put 4 w/filter. having .2 more wont hurt, as it will build more pressure and go through the pcv soon anyway. but if you dumping in half a quart to a quart too mcuh that could cause some ****, especially if your putting more than that extra.
Rep Power: 246 i put 3.25 quarts of Mobil 1 5w-20 in my 05 civic nd its right or just below the full mark and use honda filter. frame is a death trap filter cause i think it causes problems not exactly sure...guys at my work would know. yea u def dont want to add like a quart more if its really close to the full mark or it will cause some serious problems. seen a couple come in b.c they really over over filled and the car is smoking big time and some caught on fire...some how....not sure how....
Re: How many quarts?
3.7 Quarts 5W-20 (5W-30 is too heavy) Full Synthetic.
i run Royal Purple oil filter and oil in my car. Best decision I've ever made. And I've blown up 3 other hondas but this one is lasting me.
Click Here
Received 1,154 Likes
Rep Power: 99 Re: How many quarts?
Royal Purple is not the reason your car is lasting. If you blew up three previously, it means you’re probably not maintaining them adequately.
The following users liked this post:
Colin42 (05-02-2021)
Received 1,126 Likes
Rep Power: 190 Re: How many quarts?
They put some purple food colouring in synthetic oil and suddenly people think it's made of unicorn blood.
A filter is a filter, they're made to meet or exceed the standards set by the OEM manufacturer.
And if you've blown up 3 different cars clearly the problem is somewhere between the driver's seat and the steering wheel.
jackoncruzpr
09-29-2015 07:59 PM
Q-Bert
07-19-2015 09:09 PM
hayden55
07-02-2015 06:12 PM
