What Antifreeze
Rep Power: 252 Antifreeze is pretty much antifreeze. I always buy Prestone just because i know the name, make sure you mix it 50/50 with water. Prestone makes a premixed version too if your lazy.
Prince of Persia
Rep Power: 240 ahaha, not that lazy, and i'm bored so more things to do is better. i got some preston layin around, left over from mom's 96 suburban (that car leaks antifreeze like crazy).
Prince of Persia
Originally Posted by AlienX
rain-x and a 26er of vodka works but only resort to this in emergencies..
Prince of Persia
Originally Posted by ***** Fn FBM 85
Is this even in the right section?
Prince of Persia
Memebers ride section has the coolest people to talk to. I understand, lol.
Rep Power: 246 i use honda coolant cause my coolant color is blueish green color instead of the standard green coolant. i would see wat color your car uses first before you add any coolant.
Rep Power: 0 stick to blue honda coolant ... green is okay too.
do NOT use Dexcool or red coolant ...
http://autorepair.about.com/cs/gener.../aa052601a.htm
Prince of Persia
Originally Posted by Yoshiemaster
ahaha come on, autozone ain't that bad. i just got some $4 accent lights from there.
J/K
Prince of Persia
Originally Posted by pon55
But they don't handle Honda stuff
J/K
J/K
Although there are only a few antifreeze manufacturers, Honda specified a lower Borate and Silicate formulation for use in all late model Hondas. The lower level of these minerals minimizes the wear rate on the waterpump seal and bearing. There was an old article I'd read a few years ago about this on the internet. I'm sure for those who really wanted to know more can find it with a bit of searching.
Use Honda All-Season/Type 2 coolant. There are 2 colors now. Blue and green.
The new coolant is long lasting and is blue in color. It comes in a black 4 litre jug with a blue cap on top.
The factory long life coolant in the car is green. The old Honda All-season/Type 2 coolant is green in color.
The blue coolant can be mixed with the old green or green long life.
