DIY:01-03 Headlight Aim Adjustment 56K WARNING
#31
Rep Power: 787 Re: DIY:01-03 Headlight Aim Adjustment 56K WARNING
well in this case hes talking about different beams from one side compared to the other which is due more from bad bulb design. glare will always be there but thats the light above the beam and not the beam itself.
#32
Rep Power: 0 Re: DIY:01-03 Headlight Aim Adjustment 56K WARNING
i cant figure out how to adjust my projectors. my driverside is way to low but i cant find the spot to adjust them if anyone has these same headlights let me know if you can help.
#33
there is a bolt you need to turn on the back of the projector part. but you have to take the light off the car to be able to turn it otherwise theres no room.
#36
well you turn the silver bolt behind the projector. you gotta try one way first and figure out if it raises or lowers it. obviously you have to install it back on the car each time to see what happened. once you figure out which way youre moving the beam, then aim both so that at 25 ft, the lower cutoff of each side is 2 inches lower than the height of the projectors from the ground. so basically a 2 inch drop from horizontal at 25 ft.
#38
Rep Power: 294 Re: DIY:01-03 Headlight Aim Adjustment 56K WARNING
i just got done correcting the aim on my passenger headlight..which makes the HID look alot better and give further lighting distance...i gotta adjust the drivers side now.
#39
Great DIY.
I have a Honda civic 2001 1.6 executive hatchback and I can't find the up/down adjust gear. (The L/R easy). Any suggestions / photos? The Haynes manual is not helping with this!
Thanks,
Sam
Thanks,
Sam
#40
what country is that from? usually the up/down is somewhere easily accessible. check to see if you have any holes in the metal frame above the headlamp. like big enough to stick a screwdriver into and turn the adjustment.
#41
It's from the UK.
I see the hole in the metal frame with U/D next to it, but it doesn't seem to lead to an adjust gear. Have looked at the bloody thing for hours!
#42
it should be there, here is a pic of the rear with arrow pointing to up/down. the plastic covered gear is for left/right and shouldnt be adjusted unless the car was in an accident or something and you need to reaim that part.
#44
Received 1,126 Likes
Rep Power: 190 Re: DIY:01-03 Headlight Aim Adjustment 56K WARNING
Your owner's manual should tell you how, you can download for free from Honda if you don't have it. Or search YouTube
Bricoleur
09-09-2015 12:23 PM
MamaBear2015
09-04-2015 09:04 PM
