Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > 7th Gen Honda Civic Do It Yourself Articles > Lighting
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 03-02-2005   #46 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
The ONLY gauges that will be black and white are on the 2001 SEDAN. You can look on ebay, and yes if you get that it will fit in your 02 lx. Just make sure you get manual and not auto (it has the P R N D letters on it). And the lighting is different. Sedans have green/yellow backlight, coupes have red/amber. But it won't matter if you're getting it for lighting. You can even swap just the gauge face like I did. My cluster is 02 but I'm using 01 faces. To remove this ad, register today for free or log in if already registered!
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Sponsored Links
Old 03-02-2005   #47 (permalink)
AlienX
Diamond Member
AlienX's Avatar
AlienX will become famous soon enough
Send a message via ICQ to AlienX Send a message via MSN to AlienX
like gear said...
bout the 5spd thing...you CAN probebly use a 5spd console, but i might give u a SRS.
AlienX is offline   Reply With Quote
Old 03-02-2005   #48 (permalink)
ncirom2003
ncirom2003's Avatar
Send a message via AIM to ncirom2003
i wasnt going to swap the whole console just the gauges so ill have to search cus i doubt honda sells it spereate
so where you did all those led's on the climate control and on the gauges is it in parallel or series. i figure u just missed my earlier question but incase someone here has done it and dont know what i mean i drew a picture of a circuit to explain
__________________
03 nissan 350Z
02 honda civic turbo----for sale, check below.
TURBO AND ELECTRONIC GOODIES FOR SALE.
I NEED TO SELL ASAP SO I HAVE LOW LOW PRICES.
[/color]
http://www.civicforums.com/forums/19...ool-d17er.html
MYSPACE
ncirom2003 is offline   Reply With Quote
Old 03-02-2005   #49 (permalink)
gearbox
Super Moderator
I wired all mine in series and tapped the wires off the illumination wire coming to the gauge cluster. It's a big mess, and that wire is tiny, but it should be okay since leds don't use much power.
__________________
www.lubecontrol.com
Member 1025782
Old 03-02-2005   #50 (permalink)
AlienX
Diamond Member
AlienX's Avatar
all the LEDs i have setup are in parallel. Its a lot harder doing it in series, even though it will take less resistors to construct but will clutter everything. Not only that but you have redundancy if you use parallel.
LOL and nice schematic :P looks too funny
LEDS have a circle around them and little arrows to indicate that its an LE Diode, not just a diode.
Old 03-02-2005   #51 (permalink)
ncirom2003
ncirom2003's Avatar
i know that the led symbol is diff but i am not good with ms paint so oh well... i thought led's were a diode with three diagonal arrows pointing off the arrow... w/e
i would think parallel is better because the bulbs will shine alot brighter and series seems easier to me. can someone tell me if they remember what the three color bands are on the resistor there should be the three next to each other on the left then on the far right silver or something. those four colors in order would help. rep points for everyone lol. i dont feel like bustin out my electric book
__________________
03 nissan 350Z
[/color]
MYSPACE
Old 03-02-2005   #52 (permalink)
AlienX
Diamond Member
AlienX's Avatar
the far right is the tolerance level, you will only find LEDs with gold now a days because they are soo easy to make.
Black
Brown
Red
Orange
Yellow
Green
Blue
Violet
Gray
White
Old 03-02-2005   #53 (permalink)
AlienX
Diamond Member
AlienX's Avatar
sorry, white didnt come out.. but its 9 :P
Old 03-02-2005   #54 (permalink)
AlienX
Diamond Member
AlienX's Avatar
http://xtronics.com/kits/rcode.htm
Old 03-02-2005   #55 (permalink)
AlienX
Diamond Member
AlienX's Avatar
for the type of resistance you need varies on the LEDs ampage rating. LEDs are NOT voltage driven, no matter what someone tells you...
Old 03-02-2005   #56 (permalink)
ncirom2003
ncirom2003's Avatar
thanks... new the tolerance thingy ... but for the resistors u used i meant waht is tolerance and the other three bands... i believe i read 400 ohms
__________________
03 nissan 350Z
[/color]
MYSPACE
Old 03-02-2005   #57 (permalink)
ncirom2003
ncirom2003's Avatar
so that would be yello white brown then silver tolerance is 5% i believe
__________________
03 nissan 350Z
[/color]
MYSPACE
Old 03-02-2005   #58 (permalink)
AlienX
Diamond Member
AlienX's Avatar
you dont want to use silvers anymore.. you can't even get silver anymore from what I know..
yellow = 4
white = 9
brown = multiplier = 1 so thats 1 "0" at the end..
= 490 Ohms
and with silver, it can vary 5% up or Down..
Old 03-02-2005   #59 (permalink)
AlienX
Diamond Member
AlienX's Avatar
I dont remeber the values I used, you would have to look though the thread where gearbox first did the LED thing, i posted it somewhere in there.. I remeber I was somewhere in the 360 or 340 range, but it all depends on your LEDs and its always better to add more resistance then not enough, it wont change the intesity.
Old 03-02-2005   #60 (permalink)
ncirom2003
ncirom2003's Avatar
cool thanks... im probably gonna run to radioshack or somethin tomorow. so i hope my mind will be straight when i go cus i know this stuff but maybe im tired right now. anyways thanks ill go for 380-400 ohms resistors and run each bulb socket in parallel with the two leds per socket in series using the blue led's you described. this sounds alot easier than screwing with it like in the ledautomotive.com diy
__________________
03 nissan 350Z
[/color]
MYSPACE
Tags
blue , calibration , car , civic , clusters , console , dash , diy , gauge , gauges , honda , led , lights , needle , remove
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Blue LED gauge and dash lights
Hyperblinker
Installing Sidemarkers
DIY: EBAY FOG LIGHTS w/ EBAY BUTTON
Sidemarkers from MB SLK Compressor
Installing LED Washers
Bulb guide for 01-03
Aiming 01-03 Coupe Headlights
Brightest Legal Bulb?
brighter bulbs
Site Supporters
aluminum radiator
Honda car spoilers
